tips on dousing a spin? #120817
10/23/07 07:23 PM
10/23/07 07:23 PM
Largo, Florida
papayamon2 Offline OP
Largo, Florida
I don't have a sock and am simply trying to capture & bag a spinnaker on a small cat. The problem is that, when I release the halyard and try to pull the tack in from the tip of the pole, everything seems to want to drop in front of the boat and then "shrimp" under. I know that heading directly downwind w/ the main out is supposed to help, but are there any other tips as far as technique goes (besides buying a sock <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />)? Is there some other line to attach to help? (Seems like I've heard of one used on the "belly" of the spin...) When dousing, should I release the sheet and let it blow free, or try to use the clew corner to help get it onto the boat? Any help would be greatly appreciated!
Re: tips on dousing a spin? [Re: papayamon2] #120818
10/23/07 08:21 PM
10/23/07 08:21 PM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
Bring the tack in first, gather both of the lower corners of the sail in and then let go of the head. The head should then com striaght down the mast between your legs where you can bundle it up and stuff it into the bag. Or something like that.....
Re: tips on dousing a spin? [Re: arbo06] #120819
10/23/07 09:33 PM
10/23/07 09:33 PM
Will_R Offline
Will_R  Offline
just before dousing, grab the sheet at the tack and as the previous poster said, get the foot first, then go for the vertical material. Gather it into your lap or between your knees.
Re: tips on dousing a spin? [Re: Will_R] #120820
10/24/07 05:42 AM
10/24/07 05:42 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Grab the sheet at the clew. other than that- spot on!
Re: tips on dousing a spin? [Re: papayamon2] #120821
10/24/07 07:16 AM
10/24/07 07:16 AM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
Just before dousing, I would throw the halyard off the back of the boat, this would eliminate any kinks in the line that would cause it to jamb while dousing, and provide just enough resistance to keep the spin from falling too fast and getting away from you.
Re: tips on dousing a spin? [Re: ksurfer2] #120822
10/24/07 10:45 AM
10/24/07 10:45 AM
Largo, Florida
Largo, Florida
Thanks for the input, everyone. I think we've got her solved.
Re: tips on dousing a spin? [Re: papayamon2] #120823
10/24/07 11:41 AM
10/24/07 11:41 AM
Will_R Offline
Will_R  Offline
Oops, sorry... doped up on cold meds.... tack... clew... what's the difference, lol.
Be careful throwing the halyard off the back b/c if it does not straighten out, it will hit the cleat in a big knot, then you're doubally screwed.
Re: tips on dousing a spin? [Re: Will_R] #120824
10/24/07 06:52 PM
10/24/07 06:52 PM
arbo06 Offline
arbo06  Offline
You really need to be sure that the crew has been doing housekeeping on the deck to be sure that the halyard is not tangled or impinged by a butt cleat.
0 registered members (), 477 guests, and 37 spiders.
