| Re: Backing up catamarans and monohulls
[Re: 16nut]
#122018 11/01/07 02:10 PM 11/01/07 02:10 PM |
Posts: 12,310 South Carolina | pretty easy on the cat. I've raced people backwards before and it is great fun! It is difficult to maintain the backwards course if the jib is pulled out. It's much easier if you point up and let the sails flog. Stay directly into the wind while watching the water flow over the rudders. As soon as the water flow begins to reverse remember that steering is now backwards! (also useful for sailing in substantial surf). Just keep the boat headed straight downwind and it will slowly start to pick up speed and actually get to a pretty good clip this way. (also, if you have them, lift the daggerboards at least halfway).
Once you have some headway, the crew can pull the mainsail boom out gradually without upsetting the rudders...but the foils aren't meant to steer that way and they are supper sensitive!
Jake Kohl | | | Re: Backing up catamarans and monohulls
[Re: DanWard]
#122021 11/01/07 04:03 PM 11/01/07 04:03 PM | Anonymous
| Anonymous
Unregistered | 16nut:
Here is what we do. The wind is mostly offshore where we sail most of the time. We raise the rudders and sit on the bows. If you don't touch the rudders or go to the back of the boat till you get where you want to be, then go back and push the rudders down this will work fine. We use this to get out past the swimmer at the Dike. Works like a charm.
Doug | | | Re: Backing up catamarans and monohulls
[Re: Will_R]
#122022 11/01/07 04:19 PM 11/01/07 04:19 PM |
Posts: 12,310 South Carolina | also make sure to have your weight forward to get the transom(s) up. That's cheating. Real men steer backwards (and it's faster if you can start to pull your sails out). If you both sit on the bows in front of the main beam, raise the rudders, raise the boards, and loosely sheet the main the boat will back perfectly and stay positioned into the wind. It's a nice beaching technique.
#122023 11/01/07 04:50 PM 11/01/07 04:50 PM |
Posts: 1,203 uk | To liven things up whilst coaching youth on H16, we have started a race, round a windward mark and then reverse back to the start line as the finish. Pretty exciting when you get 6 or so boats doing it at once. But a good excercise in getting concentration and team work back on a slow day.
#122024 11/01/07 05:47 PM 11/01/07 05:47 PM |
Posts: 334 Seattle,Wa | If you both sit on the bows in front of the main beam, raise the rudders, raise the boards, and loosely sheet the main the boat will back perfectly and stay positioned into the wind. It's a nice beaching technique.
That sounds like a cool trick. One that will identify you as a real racer to be sure. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" /> Hobie Tiger 2003 | | | Re: Backing up catamarans and monohulls
[Re: Don_Atchley]
#122026 11/02/07 08:30 AM 11/02/07 08:30 AM |
Joined: Jun 2001 Posts: 733 Home is where the harness is..... Will_R
Posts: 733 Home is where the harness is..... | That sounds like a cool trick. One that will identify you as a real racer to be sure. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" /> IF both the skipper and crew sit on the bows, the boat will back almost straight down wind. It's a trick we've used for years. Comes in really handy at races when the wind is straight off shore. | | |
657
guests, and 123
