| Re: how to point a sloop higher?
[Re: jaybird1111]
#123204 11/12/07 02:08 PM 11/12/07 02:08 PM |
Posts: 12,310 South Carolina | I won't make the mistake of posting, much less travelling to this site again. newbie out
now look, you called "BS" first and started the name calling...and now YOU'RE mad? Seriously though - don't go away...I didn't mean anything to be hateful.
Jake Kohl | | | Re: how to point a sloop higher?
[Re: Robi]
#123206 11/12/07 02:53 PM 11/12/07 02:53 PM |
Posts: 829 Charleston, SC | Wouter, are you really Jaybird? Wouldn't that mean you were arguing with yourself? <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />
Trey
[Re: pepin]
#123207 11/12/07 03:29 PM 11/12/07 03:29 PM |
Posts: 12,310 South Carolina | Jaybird, I have a suggestion. Instead of just leaving the forum, log out, create a new account under different name, lurk for a while and then post.
You'll see by just reading for a while that there was nothing personal in this conversation, just normal honest banter. And don't think you are unlucky, getting in a heated discussion with Wouter and Jake on your first post, that's a really common occurrence <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> Geeesh...am I THAT bad? <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
#123208 11/12/07 05:10 PM 11/12/07 05:10 PM |
Posts: 757 japan | wow! think a posting is dead and then it suddenly flares back into life with lots of life, who needs sailing anarchy
but as the original poster i just want to say thanks for all the replies, i know a lot more now than i did before
the reason i asked the question in the 1st place was to get an idea about the ultimate pointing ability of my 5.2 regardless of what it costs me in speed
next summer when i try to tempt my wife and 2 kids on board, (8yo and 6yo), speed will not be important. in fact they'll probably like it slow as they can count the times they have sailed on 1 hand.
without a jib the tramp will be much cleaner and give more space for kids to get out of my way without getting tangled in lines. as a newbie sailor i'll have 1 less thing to worry about. we reduce the already small chance of flipping the boat to an even smaller chance as i'd have to have the jib cleated and maybe most important on our small lake just a few degrees of better pointing means lots less tacks will all the bays, wind shadows and an island to get round
but then i may blow a tack and end up screaming at everyone while i try to stop backing onto the rocks
whatever, the info has been great and it'll be great fun to experiment with both rigs and mast rake and then compare all the gps tracks to work out what works best, in that lake with it's winds and me at the helm.
[Re: erice]
#123209 11/12/07 05:27 PM 11/12/07 05:27 PM |
Posts: 1,383 Kingston SE South Australia | If the day is quiet enough for you to leave the jib on, the kids will love doing the jib it will give them some involvment regards
[Re: JeffS]
#123210 11/12/07 07:14 PM 11/12/07 07:14 PM |
Posts: 757 japan | good point, they do get bored in anything approaching safe sailing but my daughter and i start to worry when the wind picks up and it gets interesting
on my dingy i could quickly turn around to pick up a man overboard or even just dive out for them and the boat would round up quickly
but on the nacra it'd take me much more space to stop and come back and if i dived off the cat while it would round up eventually it would be too far away to tow a child
[Re: jaybird1111]
#123211 11/12/07 09:04 PM 11/12/07 09:04 PM |
Jaybird,
Your statements about the jib are wrong and you are wrong in continuing to reference to them.
Taking one example out of possibly many : A jib DOESN'T create more drag then lift as you claim.
[Re: erice]
#123216 11/13/07 02:04 AM 11/13/07 02:04 AM |
Joined: Oct 2005 Posts: 951 Brisbane, Queensland, Australi... ncik
Posts: 951 Brisbane, Queensland, Australi... | You posted a photo recently which showed your jib clearly (atleast I think it was you). You need to pull the wrinkles out of your jib with some luff tension, then you need a little more rig tension (I think that was the topic of your last question). Both of these should help with pointing.
Do a search on mast rake in this forum, it's been discussed heaps before. The basics of mast rake are that it will not noticeably help pointing no matter what the rake is (ignoring extreme rake positions, usually negatively). What it will significantly affect is helm on the rudders(weather or lee helm) You want to set your rake so that you have a little bit of weather helm while sailing upwind (if you release the tiller, the boat will round up into the wind steadily). Not so much that it is ripped out of your hand. This won't help your pointing but will reduce your leeway angle, which is another aspect of achieving height while sailing upwind. (The angle of your sails to the wind and the angle your boat slips sideways through the water both impact your height and are tricky to distiguish between.)
There is nothing tricky or "mystical" about rake and pointing, it is all about balancing forces and moments generated by the sails and hull (including appendages). | | | Re: how to point a sloop higher?
[Re: Karl_Brogger]
#123217 11/13/07 10:08 AM 11/13/07 10:08 AM |
Posts: 321 Albuquerque NM | Jay, if you don't want to waist your time being bashed by Wouter on how a jib effects your ability to point, you can waist a few days on this. I do not believe anybody got bashed in this thread (although the Catter should have for starting it) Waist of time
[b] Sail Like you have a Pair
[Re: blockp]
#123219 11/13/07 01:08 PM 11/13/07 01:08 PM |
Posts: 321 Albuquerque NM | Somebody else is going to have to post to it tho, I will not be guilty of waisting everybody else's time with such non-sense (Yet)
1 registered members (FredL),
626
guests, and 80
