| Drysuits. #124223 11/20/07 09:18 AM 11/20/07 09:18 AM |
Posts: 976 France | It's cold in the UK in November. Really cold. So I have to go out and buy me a drysuit. Before sailing in the UK I used to sail in sunny California, and before that in the south of France and in Corsica. I never had to buy a dry suit before, so it is completely unknown territory for me. So I'd like to collect some of the collective wisdom before I buy...
I've read the previous threads on the subject, but the most recommended manufacturer (kokatat) has only one distributor in the UK, and they are asking £750 for the privilege of getting a drysuit with socks from them. As it is 2 times the price of the nearest offer, I consider that ridiculous so I've removed them from my selection.
I've done some research into the various models and brands available in the UK and approximate prices. If you own one of those models, or if I overlooked one, I would be grateful if you can give me a quick review of what you think are their plus or minuses.
Gul Infra: 225 Gul Ion: 325 Gill front zip 400 drysuit: 310 Crewsaver Hyperdry pro: 240 Crewsaver Hyperdry men: 300 Musto MP goretex one design dry suit: 380 Typhoon XTS Pro: 300 Typhoon TY Racer: 230 Lomo tornado drysuit MkII: 175 (available end of december) Trident with front opening: £230 Henri Lloyd TP1 Stealth Dry Suit: 260
I think what I want in order:
- breathable, - front entry (because I usually sail without a crew to open my suit for me!), - latex seals (I must admit I'm curious about the 'eelskin seals' on the Typhoon XTS Pro), - integrated boots - good resistance, - as cheap as possible - available now | | | Re: Drysuits.
[Re: _flatlander_]
#124227 11/20/07 09:48 AM 11/20/07 09:48 AM |
Posts: 976 France | Care to comment a bit? your link (that I fixed there) points to a 'semi-dry suit' whatever that is. If a dry suit is not dry, what's the point of it? Just curious, since you linked to it... | | | Re: Drysuits.
[Re: pepin]
#124228 11/20/07 10:46 AM 11/20/07 10:46 AM |
Posts: 1,187 38.912, -95.37 | If it's breathable (priority #1), it's a "semi-dry" suit, right? Maintaining a balance between the heat your body produces and the heat you lose to the outside environment is essential, and an integrated multi-layered clothing system that fits well, doesn't restrict movement and weighs as little as possible is the key.
A light polyester layer next to the skin will wick moisture away from the body and a fleece mid-layer will protect you from the cold. Both fabrics dry very quickly, and maintain warmth without weight even when damp. Protective outer shells in Gore-Tex® or Tropos fabric are absolutely waterproof and windproof from the outside, yet allow moisture and perspiration vapour to escape from the inside. The result: you stay drier and more comfortable.
Salt water does not harm these fabrics or affect the performance in any way as salt water crystals are much too large to clog the pores in the membrane.
Salt accumulation does attract moisture so rinsing your garments in fresh water is important. If fresh water isn't available, rinse in salt water. Salt water is only 3% salt.
A breathable Dry Suit or Semi-Dry one piece suit is a comfortable option under any conditions as you can regulate the warmth of the system by adding or removing layers underneath.
| | | Re: Drysuits.
[Re: _flatlander_]
#124229 11/20/07 11:13 AM 11/20/07 11:13 AM |
Posts: 976 France | If it's breathable (priority #1), it's a "semi-dry" suit, right? Hu, no. Breathable let water out but does not let water in. So if you sweat inside the suit the sweat can escape so you stay dry, but the water cannot come it. From what I heard it's fantastic. All the suits I have listed are both waterproof and breathable... Drysuits of old were not breathable. So the water was not coming in, but the sweat was not getting out either. So you ended up wet inside your drysuit. New materials are awesome, do not ask me how they work, but they do, I have a motorcycle suit and a ski jacket in breathable fabrics and those are windproof, waterproof *and* breathable. | | | Re: Drysuits.
[Re: macca]
#124232 11/20/07 02:48 PM 11/20/07 02:48 PM |
Posts: 12,310 South Carolina | Musto, the only suit to bu if you are serious about keeping warm and dry on a Cat.
I think 90% of all teams in the Archipelago Raid used Musto, the ones that didn't were the ones that got wet.... I would agree with that - but also put Kokatat just above Musto on the list. They're also premium drysuits with the customer support that will blow your mind. I recently sent them a three year old (well used) drysuit that had begun to seep a little in the legs and belly. I got a brand new one back within two weeks and no bill.
Jake Kohl | | | Re: Drysuits.
[Re: George_Malloch]
#124233 11/20/07 06:56 PM 11/20/07 06:56 PM |
Posts: 976 France | I have the Lomo suit. If I was buying another drysuit then I wouldn't consider any other make. It's good quality and has features which generally only feature in much more expensive suits. Customer service is excellent - they sent me the wrong size, when I told them, the correct size arrived the next day. Highly recommended. The lomo sounds great, especially since it is the cheapest. *But* they are out of stock and according to their web site do not expect new shipments until early January. I'm not going to freeze my **s for two months, I need something available now... | | | Re: Drysuits.
#124234 11/20/07 06:59 PM 11/20/07 06:59 PM |
Posts: 976 France | Musto, the only suit to bu if you are serious about keeping warm and dry on a Cat.
I think 90% of all teams in the Archipelago Raid used Musto, the ones that didn't were the ones that got wet.... I would agree with that - but also put Kokatat just above Musto on the list. They're also premium drysuits with the customer support that will blow your mind. I recently sent them a three year old (well used) drysuit that had begun to seep a little in the legs and belly. I got a brand new one back within two weeks and no bill. Here we go, two recommendations for the two most expensive models on the list. I guess you get what you pay for <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> | | | Re: Drysuits.
[Re: pepin]
#124235 11/20/07 09:21 PM 11/20/07 09:21 PM |
Posts: 22 Montreal | I got the Gul infra last year in London and I paid 200 pounds at http://www.welshharp.co.uk/Really happy with it and would do the same again.
| | | Re: Drysuits.
[Re: pepin]
#124236 11/20/07 09:26 PM 11/20/07 09:26 PM |
I think 90% of all teams in the Archipelago Raid used Musto, the ones that didn't were the ones that got wet.... I would agree with that - but also put Kokatat just above Musto on the list. They're also premium drysuits with the customer support that will blow your mind. I recently sent them a three year old (well used) drysuit that had begun to seep a little in the legs and belly. I got a brand new one back within two weeks and no bill. Here we go, two recommendations for the two most expensive models on the list. I guess you get what you pay for <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> Having had two that were inexpensive models and didn't hold up for two years, I would say that I wholeheartedly agree with that statement.
[Re: pepin]
#124238 11/21/07 06:16 AM 11/21/07 06:16 AM |
Posts: 34 Long Island | I have an OS Systems drysuit ... Don't know the price (I got it at a pro discount) ... but figure it must have been around 600 to 800 USD about five years ago ... anyway ... great suit, lots of doubled material (butt and knees) ...breathable, diagonal front zipper, etc ... I've used DUI (US) and Northern Diver (UK) for dive suits in subArtic/Antarctic waters ...like both manufacturers ... don't know if they make surface suits ... This is the only non-dive drysuit I've had and it does great duty ...latex socks (I wear wetsuit boots over), neck, wrist ... brass zip ... Spent an hour floating as a practice dummy MOB in February waters off NJ (similar to off the UK, I'd say) ... and was relatively fine (all things considered!) ... this also entailed being pulled, yanked and rolled into RIBs several times ... no leaks, no rips, etc. gary http://www.ossystems.com/ | | | Re: Drysuits.
[Re: gjoyce56]
#124240 11/21/07 10:16 AM 11/21/07 10:16 AM |
Posts: 3,969 | Spent an hour floating as a practice dummy MOB in February waters off NJ... Wow. Unless you're a complete masochist, you'd be better off making friends with a fireman. They have life-sized (and weighted) dummies for this purpose... <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" /> Since I'm on a tangent, Happy Thanksgiving everyone!!! <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> Mike | | | Re: Drysuits.
[Re: Vladimir]
#124242 12/07/07 02:40 PM 12/07/07 02:40 PM |
Posts: 1,200 Vancouver, BC | The Kokatat Supernova "semi" drysuit has just been reduced in price at REI (<$340): http://www.rei.com/product/722283 Supernova I've used one for the past season and it is really very good for cat sailing. Full beathing, neoprene neck, Tropos (goretex-light) booties instead of latex, front zip, relief zip (mens & womens styles). I will never go back to latex booties!
1 registered members (basket.case),
483
guests, and 25
