Page 3 of 3 1 2 3
Re: What do YOU do in the winter? [Re: flounder] #12501
01/24/03 06:21 AM
01/24/03 06:21 AM
I'm with you. The most enthusiastic cat sailors seem to live in the areas that have the shortest sailing seasons. When we were sailing up in the Ohio, Michigan area and the season was only about 12 weeks long, everybody tried to get to every regatta, regardless of weather, because we had a time limit. But in Florida, because we are able to sail year round, it's too easy to say, "Hey, it's too much wind, it's too little wind, it's too cold, it's too hot -- catch ya next time."
Re: What do YOU do in the winter? [Re: MaryAWells] #12502
02/05/03 01:41 AM
02/05/03 01:41 AM
It IS still winter up North, isn't it? Mike Fahle just sent this to me to put a nautical spin on the cold weather theme. I had also used this in the magazine sometime in the last year.
In the heyday of sailing ships, all war ships and many freighters carried iron cannons. Those cannon fired round iron cannon balls. It was necessary to keep a good supply near the cannon. But how to prevent them from rolling about the deck?
The best storage method devised was a square-based pyramid with one ball on top, resting on four resting on nine which rested on sixteen. Thus, a supply of thirty cannon balls could be stacked in a small area right next to the cannon.
There was only one problem -- how to prevent the bottom layer from sliding or rolling out from under the others.
The solution was a metal plate called a "Monkey" with sixteen round indentations. But, if this plate was made of iron, the iron balls would quickly rust to it. The solution to the rusting problem was to make "Brass Monkeys."
Few landlubbers realize that brass contracts much more and much faster than iron when chilled. Consequently, when the temperature dropped too far, the brass indentations would shrink so much that the iron cannon balls would come right off the monkey.
Thus, it was quite literally, "Cold enough to freeze the balls off a brass monkey!"
Re: What do YOU do in the winter? [Re: Mary] #12503
02/05/03 08:11 AM
02/05/03 08:11 AM
42.904444 N; 88.008586 W
Todd_Sails Offline
Todd_Sails  Offline
Sail most of the winter, in 70's degree weather here around Galveston Is. and Galveston Bay. (Houston area)
F-18 Infusion
#626- SOLD it!
Re: What do YOU do in the winter? [Re: Mary] #12504
02/05/03 08:55 AM
02/05/03 08:55 AM
Burlington, Vermont USA
K
Kevin Rose Offline
Kevin Rose  Offline
K
Mary,
Great bit of trivia. Made me start wondering what happens when it gets "colder than a witches ### in a brass bra"?
Kevin Rose N6.0na #215 Lake Champlain (New England's "west coast") Burlington, Vermont
Page 3 of 3 1 2 3
0 registered members (), 5,967 guests, and 343 spiders.
