| what are daggers and rudders generally made of? #125832 12/07/07 06:37 PM 12/07/07 06:37 PM |
Posts: 757 japan | hi all, am idly thinking of sometime in the future reshaping the daggers and rudders on my old nacra 5.2 to a more modern profile, (round out the forward lower corner of the daggers and removing some of the width of the rudder blades)
but to do so i need to know what they cored with heavy enough to either be ply or solid glass!
or maybe safer to copy them in shaped ply and then wrap with glass, anyone guess what weight of cloth and how many layers would be needed to provide enough strength?
| | | Re: what are daggers and rudders generally made of
[Re: erice]
#125837 12/08/07 10:18 AM 12/08/07 10:18 AM |
Posts: 12,310 South Carolina | Those boards are fiberglass with a sort of solid resin core. I'm not certain exactly what they use in the core on those but you can sand to it, shape it, and cover it a little with some glass with no problem.
Jake Kohl | | | Re: what are daggers and rudders generally made of
[Re: Karl_Brogger]
#125838 12/08/07 10:36 AM 12/08/07 10:36 AM |
Joined: Jun 2006 Posts: 121 Hollister CA, Plano TX avalondarlyn
Posts: 121 Hollister CA, Plano TX | I built a set of rudders and daggers for a viva 27. The rudders were 1 3/4 in thick, by I think 38 long and were very heavy solid mahogany. I used the originals as cores planed them down about 3/8 3/16 from each side and then cut off the leading and trailing edge leaving a top w/ a tapered stringer. I then glued on 1 lb styren foam. A few templates and and using my old surfboard shaping skills. 1 layer of of uni-knitted "rutan" glass "highly recommened" about 2/3 lenth and then 1 layer of 4oz glass. a little micro light. the new rudders were approx 48 in long an extra 8 in. with the last 12 in or so just, an egg shell. skin. new rudders were about 1/3 the wieght. With an much improved foil. I used a naca 12 foil. If I did it again I use the resource "here" to get a better foil. As for daggers, I used www.flyingfoam.com had Bob cut the cores with a cnc machine. again glassed w/ approx 10 layers of the Rutan uni-knitted glass. 1 layer of 4 oz glass. a little micro light. new boards were great I got close to a naca 12 foil but was restricted by the slot. new daggers were 8 ft 4 in long. and wieghed about 30 lbs each about 50 lbs lighter than the originals. In my opinion, the wieght savings vs strenth vs cost I would look at the new cloths being developed by the airplane composite company's. The foils I built were with in 10-15% of the wieght of a full carbon foil. But approx 1/3 the price. These are my opinons based upon 20+ years "part time" of fiberglass and water craft production and airplane restoration. PM if you want or need an opinion. Question has anybody out there built a set of aluminum boards I'm considering it for my new project "C-class" if so I would like to see how they were built. | | | Re: what are daggers and rudders generally made of
[Re: avalondarlyn]
#125839 12/08/07 12:06 PM 12/08/07 12:06 PM | Anonymous
| Anonymous
Unregistered | Guy at the Texas city dike where I use to sail had a SWEET set of wooden rudders on his Hobie 21. Even LONG spin run of hours her had no problem. Light tan and dark mahogany color. They looked REALLY good.
Doug | | | Re: what are daggers and rudders generally made of
[Re: ]
#125840 12/08/07 02:11 PM 12/08/07 02:11 PM |
Joined: Nov 2003 Posts: 749 Santa Cruz, CA SurfCityRacing
Posts: 749 Santa Cruz, CA | They don't have to be high tech. I've heard that there was a company that made wooden rudders for the H14 and 16 back in the day. Anyone know about that? I don't know anything about this really, but my friends at Elkhorn Composites were building hollow surfboards out of aluminum honeycomb core and carbon. They were super stiff and very light. I thought it would be a cool way to make rudders. It would be expensive though! Billet aluminum on a CNC would be cool Karl. Titanium??? Ouch, my wallet.<img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" /> You can make daggers out of a lot of materials and each method has pluses and minuses. | | | Re: what are daggers and rudders generally made of
[Re: Karl_Brogger]
#125842 12/09/07 05:46 AM 12/09/07 05:46 AM |
Posts: 757 japan | weighed my daggers today and they came in at 5kg or 11lb each, which must be much heavier than newer foam cored daggers
i think solid alloy would weigh about the same, however an aerospace alloy honeycomb core, like the old usa ski maker hexcel used, wrapped and sealed in riveted duralinium skins would be pretty cool
pity i'm no longer working as an aircraft mechanic with access to all that cool stuff
well shaped ply would look pretty good too as the different colored laminates would show up like contour lines in the leading and trailing edge tapers
maybe if they are well soaked in resin they wouldn't even need a cloth sheath. doing without the cloth would make them easier to build and lighter
might cut out some bits and start flex comparisons, i know the glass ones can support my weight after my last 2 capsizes and that old nacra daggers can break when being used all the way down in heavy air. perhaps they aren't flexible enough
[Re: erice]
#125843 12/09/07 03:12 PM 12/09/07 03:12 PM |
Posts: 902 Norman,OK | Flexible is bad when you are trying to go fast.
[Re: gree2056]
#125844 12/09/07 04:22 PM 12/09/07 04:22 PM |
Posts: 757 japan | lateral twists in the dagger cases would be bad but if others are snapping 5.2 boards in heavy air it seems to me they don't give enough
those long high aspect daggers on boats like the inter17 and A cats at half the width and twice the length must bend more than 5.2 boards
if 2 daggers weigh 10kg, 22lbs, together, then the 2 rudder blades probably weigh another 5kg, 11lbs. that's 10% of the boats 150kg, 325lbs
[Re: Karl_Brogger]
#125850 12/12/07 10:42 AM 12/12/07 10:42 AM |
Joined: Jul 2001 Posts: 953 Western Australia Stewart
Posts: 953 Western Australia | I would probably not go down the path of cnc'ing a block of "ally".. While it sounds great "ally" does not float!! So if for some reason it comes out of the case the whole thing sinks!! At least with wood you have a chance the plate/rudder can be retrieved. Even though its old read the chapter in Frank Bethwaite's book.
For those classes which have a no carbon rule.. Very thin veneer or ultrathin ply is the natural carbon substitute.. One can steam veneer and epoxy together to make a side of plate.. then put in the backbone stringer epoxy the side together and glass.. should be very strong and light
[Re: erice]
#125851 12/12/07 11:15 AM 12/12/07 11:15 AM |
Joined: Jan 2006 Posts: 39 Richmond Virginia NACRADUDE
Posts: 39 Richmond Virginia | might cut out some bits and start flex comparisons, i know the glass ones can support my weight after my last 2 capsizes and that old nacra daggers can break when being used all the way down in heavy air. perhaps they aren't flexible enough Had a friend of mine snap two 5.2 boards in heavy air quite recently with two big guys on the wire in 30+. When you experience that type of wind it is better to raise the boards about 1/3 of the way to help depower the boat along with droping the traveler. Without a reef point that's a good way to reduce the chance of inadvertant swimming.
Money can't buy you love, but it can rent it for a while
2,499
guests, and 502
