| Re: Picked up a Nacra 5.8na this past summer..
[Re: bradb555]
#126080 12/11/07 05:30 PM 12/11/07 05:30 PM |
Posts: 757 japan | i can only comment on my experience with a nacra 5.2 where hull alignment is very easy and the top tuning advice is to actually slightly misalign hulls slightly toed out...
if you want to clean up the hulls and do a bottom job properly it is hard to see how doing so with the beams on is possible without lots of extra work
if you are worried about breaking the captive nuts free use a torque wrench to loosen the 1st bolt and see what torque is starts to move at, and or, even a mirror and spray on the threads in the hull to make sure they come out smoothly
[Re: erice]
#126082 12/12/07 10:50 AM 12/12/07 10:50 AM |
Joined: Jan 2006 Posts: 39 Richmond Virginia NACRADUDE
Posts: 39 Richmond Virginia | i can only comment on my experience with a nacra 5.2 where hull alignment is very easy and the top tuning advice is to actually slightly misalign hulls slightly toed out...
Ah no. Good way to make it a pig in light air.
Money can't buy you love, but it can rent it for a while
[Re: NACRADUDE]
#126083 12/12/07 11:40 AM 12/12/07 11:40 AM |
Posts: 308 Reno NV | i can only comment on my experience with a nacra 5.2 where hull alignment is very easy and the top tuning advice is to actually slightly misalign hulls slightly toed out...
Ah no. Good way to make it a pig in light air. True for a bridle foil boat like a 5.8NA, maybe not true if you have bridle wires. | | | Re: Picked up a Nacra 5.8na this past summer..
[Re: Rhino1302]
#126085 12/13/07 08:51 AM 12/13/07 08:51 AM |
Ah no. Good way to make it a pig in light air. True for a bridle foil boat like a 5.8NA, maybe not true if you have bridle wires. Why would you say that? Would it not act like a funnel for the water to pass between the hulls upwind and downwind? I don't even want to think of the stresses of the hulls fighting each other. Would it not try and make the hulls roll towards each other from the top of the deck? I'm not seeing the benefit.
[Re: NACRADUDE]
#126086 12/13/07 09:37 AM 12/13/07 09:37 AM |
Posts: 757 japan | i don't toe-out and only mentioned it because someone seemed worried that cracking the beam bolts could lead to alignment problems. the 5.2 at least seems very easy to align with it's limiter straps riveted to the hulls and if you are worried about not getting perfect alignment then err on the side of toe-out rather than toe-in http://www.goosemarine.com.au/Articles%20%7C%20Photos
[Re: Rhino1302]
#126088 12/13/07 04:53 PM 12/13/07 04:53 PM |
Posts: 39 Richmond Virginia | OK that makes sense, kind of. But I still see the hulls rolling towards each other. Either way I see no real benefit to toeing out, but I may be full of [censored] also.
[Re: bradb555]
#126090 12/18/07 02:12 PM 12/18/07 02:12 PM |
Posts: 169 Santa Barbara CA | Hey there, I personally don't think you will have much to worry about on getting the bolts out, usually the problem is the last owner overtorquing them and stripping the threads on the aluminum insert glassed into the hull. Several of the Nacs' I've had actually had longer bolts and a lock nut inside reachable through an access port, so if you keep spinning a bolt and it's not coming out...of course reaching inside got harder and harder as my forearms got all Popeyed out after lots of catsailing.LOL On the tramp issue, none of the ones I had could get re-tramped without disassembly ( this is all from personal experience trying to do it all myself). They would come off, but not back on without several helpers trying to inch the edges into the track while somebody pulls from behind. You do have to drop the mast to get the boat apart, and it's suprisingly hard to mess with the mast with no tramp on, hard to reach up high enough for stepping it, so don't pull the tramp before dropping the stick (guess how I know)! I took off one front corner set of bolts, and the opposite back corner set of bolts so that the hulls would support each other as they slide in to get the slack in the tramp, if you do same side the one hull tries to flop over. If you have time, the new style tramps have webbing sewn down both edges that either lace to slides in the tracks or directly to the hull. I did my own 'cause I have a sewing machine, laced to slides in the existing tracks. Then you never need to demount the crossbars for tramp repairs. Some don't like it because of the sheets getting out through the gaps in the lacing though...
On the alignment, the toe in/out is pretty set, but you do have to get the bows the same height relative to each other.
[Re: Rhino1302]
#126093 12/21/07 04:33 PM 12/21/07 04:33 PM |
Joined: Aug 2007 Posts: 7 So Cal-Long Beach bradb555 OP
Posts: 7 So Cal-Long Beach | Is it bent above or below the main beam? If above, you can probably straighten the rod in place, just be careful not to gall the threads. I don't think you need to remove the hulls in order to replace the rod, but I'm not sure. The Rod is bent above the beam. My experience with yielded metal is to replace the part. Besides I already have the rod and assoc h/w. This doesn't look too hard. I plan on measuring the existing cross beams prebend and duplicating it during re-assembly. The fun part will be cutting the rod <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> | | |
280
guests, and 35
