Bend in Nacra 20 mast #126346
12/14/07 01:11 PM
12/14/07 01:11 PM
Newport, RI
wildtsail Offline OP
Newport, RI
Hey guys...
When I was leaving the Steeplechase I noticed there is a slight bend in my Nacra 20 mast.
My question... carbon has no memory right? So it can't be a permanent bend it's got to be an adjustment I have to make in the diamond wires right?
A side bend would have to mean one diamond is tigher than the other right?
Considering the mast is 1,500+ miles away right now I can't toy with it now but am going to have to get it figured out once I get down there.
Thanks,
Todd
P.S.
No one better put up a piece of toast in response to this! I sure don't feel like forking up $5,400!!!
Re: Bend in Nacra 20 mast [Re: wildtsail] #126347
12/14/07 01:35 PM
12/14/07 01:35 PM
Undoubtedly the diamonds - use a Loos guage, check both sides, use the adjustable side to straighten.
Re: Bend in Nacra 20 mast [Re: wildtsail] #126348
12/14/07 01:35 PM
12/14/07 01:35 PM
one spreader bent up(or down) - thus less tension/compression on one side ?
do you have independant adjustment on each side?
Re: Bend in Nacra 20 mast [Re: scooby_simon] #126349
12/14/07 01:47 PM
12/14/07 01:47 PM
TeamChums Offline
TeamChums  Offline
Definately check the spreaders to see if they are adjusted the same amount on each side as well as being square with the mast. Look closely at the wires for any broken strands. If one of those lets loose, you will be paying the $$.
Lee
Lee
Re: Bend in Nacra 20 mast [Re: TeamChums] #126350
12/14/07 02:21 PM
12/14/07 02:21 PM
SC
zander Offline
zander  Offline
SC
I know they say carbon can't hold a bend but my Nacra 20 mast bends a little to port(I think) above the diamond wires. It does not really effect sailing, at least not my sailing. I think my mast spent a lot of time stored on its side in atlanta before I purchased it. I have often wondered if heat from the sun along with the way it might have been supported on its side could have altered the mast itself. But I can attest that there is a slight permanent bend. I'll see if I can get a picture to show you guys what I mean.
Always borrow money from a pessimist. He won't expect it back.
Re: Bend in Nacra 20 mast [Re: wildtsail] #126351
12/14/07 02:26 PM
12/14/07 02:26 PM
I think the old diamond wires don't have the single side diamond wire adjustment...think they added that in 2005. It could be different spreader rake too.
Re: Bend in Nacra 20 mast [Re: Jake] #126352
12/14/07 03:51 PM
12/14/07 03:51 PM
About every Nacra 20 mast I've seen has that bend. I suggest getting a new set of adjustable diamond wires and tweak it out, like Champ Williams says.
Re: Bend in Nacra 20 mast [Re: ] #126353
12/14/07 08:20 PM
12/14/07 08:20 PM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
If you don't have the adjustable diamonds you can take off one end of the wire that needs tension and twist it to shorten it. Then put it back on and re-tension to check. Takes a little experimentation but works like a champ. I find I've had to re-set it every now and then. When you twist the wires make sure you make them tighter and don't un-wind/ un-lay them.
Todd
Isak Dinesen
E. B. White
Re: Bend in Nacra 20 mast [Re: Team_Cat_Fever] #126354
12/16/07 06:53 PM
12/16/07 06:53 PM
Newport, RI
Newport, RI
I'm gonna try the loos gauge when I get back to FL for sure.
The boat I use doesn't have the single adjustment, too bad that would make life easy.
While resetting it I am going to have to check the prebend... Matt Struble's (which is kinda old) tuning guide says minimum 1"... seems a little stiff to me?
What the general consesus on prebend these days? I was thinking more like an inch and a half?
Re: Bend in Nacra 20 mast [Re: wildtsail] #126355
12/16/07 11:33 PM
12/16/07 11:33 PM
SC
zander Offline
zander  Offline
SC
If I remember correctly, we set my mast at 1.5 inches. Measured from a straight edge off the spreaders to the mast. That is the measurement I had been given from several people.
Re: Bend in Nacra 20 mast [Re: zander] #126356
04/04/08 09:44 AM
04/04/08 09:44 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
How much spreader rake do you have? How much diamond wire tension?
Other recommendations?
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: Bend in Nacra 20 mast [Re: wildtsail] #126357
04/04/08 10:07 AM
04/04/08 10:07 AM
srm Offline
srm  Offline
I think you are correct, carbon doesn't have a memory (unlike metals) but it will take a set. I don't have experience with carbon catamarn masts, but in windsurfing, if you leave a sail rigged too long, the mast will take a fore/aft set. The solution is to rotate the mast 180deg and then re-rig to bend the mast back the other way. So, using that logic, you could probably disconnect/loosen the diamond wire on the concave side of the mast, tighten the convex side, and let it sit there for a few days to bend it back the other way.
sm
Re: Bend in Nacra 20 mast [Re: Chris9] #126358
04/04/08 10:59 AM
04/04/08 10:59 AM
Crofton, MD
Todd Berget Offline
Todd Berget  Offline
Crofton, MD
Here's another question: Are you guys going with the minimum rake (I think it's 1.5" measured from the spreader tips to the mast) or are you staking your sail and trying to match the mast to the luff curve of the sail?
Curious what the top guys are doing.
Todd Nacra 20 www.wrcra.org
Re: Bend in Nacra 20 mast [Re: Todd Berget] #126359
04/04/08 11:09 AM
04/04/08 11:09 AM
brucat Offline
brucat  Offline
Todd, don't you live within 15 minutes of Hall spars? I would ask them for their advice. You probably know people that work there too.
Re: Bend in Nacra 20 mast [Re: brucat] #126360
04/04/08 12:58 PM
04/04/08 12:58 PM
Crofton, MD
Todd Berget Offline
Todd Berget  Offline
Crofton, MD
naw, different Todd. I live in MD. the other one lives up north near Hall.
TB
Re: Bend in Nacra 20 mast [Re: Todd Berget] #126361
04/04/08 01:51 PM
04/04/08 01:51 PM
brucat Offline
brucat  Offline
Whoops, that was meant to be directed at Riccardi, who actually started this post. Sorry about that.
Re: Bend in Nacra 20 mast [Re: Chris9] #126362
04/04/08 08:47 PM
04/04/08 08:47 PM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
Well I ended up with about 2.5" of spreader rake, applied tension to #39 on Loos guage and that yielded about a tad more than 1.5" of prebend. Where are you with these settings?
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: Bend in Nacra 20 mast [Re: Chris9] #126363
04/07/08 07:54 AM
04/07/08 07:54 AM
Northern Virginia
SoggyCheetoh Offline
Northern Virginia
Chris,
Is that what you were using last year, or are you trying something new?
Alec
Alec D.
Pirates of the Chesapeake www.teampiratesofthechesapeake.com
Nacra20 1057 - Crew
F16 Viper 152 - Uni
Re: Bend in Nacra 20 mast [Re: Chris9] #126364
04/07/08 08:42 AM
04/07/08 08:42 AM
Crofton, MD
Todd Berget Offline
Todd Berget  Offline
Crofton, MD
I was running around 2 1/2"- 2 3/4" of spreader rake. not sure how much mast bend I had. I was at 37-38 on the loos which I think was around 700#'s. The factory recommends a minimum of 1.5" of spreader rake which looking at your #'s suggest very little prebend
Re: Bend in Nacra 20 mast [Re: SoggyCheetoh] #126365
04/07/08 01:15 PM
04/07/08 01:15 PM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
Essentially the same as last year.
Anybody else wanna share?
Chris Allen
Nacra 20 Gertie
www.wrcra.org
1 registered members (bogus), 447 guests, and 48 spiders.
