| Re: Hobie Cat vs Paper Tiger
[Re: warbird]
#127756 01/04/08 04:15 PM 01/04/08 04:15 PM |
Joined: Jan 2008 Posts: 9 Auckland, New Zealand ZaneO OP
Posts: 9 Auckland, New Zealand | Hmmmm...
So, it's blowing outside, and I'm just waiting to see a kitesurfer cruise past my window... if only I had a cat <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
I wandered out to the neighbours, and sure enough, that cat on his lawn is a Windrush 14! When he gets back from holiday, I'm going sailing!
That white PT down in Taranaki is quite sexy, and very tempting, but based on all the advice I'm getting, Im leaning towards the windrush.
Warbird, you certainly are a college of knowledge - I'm not sure if your description of introducing a partner to cat sailing was a glimpse into my future, or your past - either way - sounds like a familiar story.
A couple of questions remain for me... - How will a Windrush 14 handle in lighter winds - 7-10kts - Does the Windrush have a trapeze?
I will get notified when any Windrush / PT come up for sale.
I'm looking forward to joining the club... | | | Re: Hobie Cat vs Paper Tiger
[Re: ZaneO]
#127757 01/04/08 05:16 PM 01/04/08 05:16 PM |
Posts: 902 Norman,OK | I know a local guy here has a cat that is the old version of the windrush 14, called a trac 14, same exact boat different name. It has a trapeze and he sails it pretty well when he actually comes out, which is only about 2 times a summer.
[Re: Qb2]
#127762 01/07/08 03:20 PM 01/07/08 03:20 PM |
Posts: 29 syracuae | I learned on a Hobie 16, and in 20 knots you can almost right one with out a righting line. simple boat hard to race easy to sail, in my opinion its a great starter boat, go out with a buddy and flip it a few times so you get the hang of it. flip, stand forward on hull in water until boat weathervanes and bows are pointed into wind and lean back on righting line..up she goes (make sure all lines are uncleated first.) as a bonus they're tuff as nails so being a noob won't trash your boat.
Cheech U-204
[Re: cheech]
#127763 01/08/08 01:22 AM 01/08/08 01:22 AM |
Posts: 271 Atlanta, Ga | If you are having trouble righting a 16 you need to either use the wind against your tramp more to your advantage, or you need a longer line..hook it to your harness and lean. I used to right my 16 solo when I was a teenager. No offense, but the 16 has much more to offer than the Paper Tiger. Don't be shy, jump in.
[Re: BLR_0719]
#127765 01/09/08 06:56 AM 01/09/08 06:56 AM |
Posts: 1,449 | BLR, I don't know if you or anyone else remembers but I remember a guy that visted the catsailor forum a few years back asking for advice on solo righting a H16. I heard he was trained in survival. Does anyone remember this person and what happenned?
Regards, Phill
[Re: phill]
#127766 01/09/08 05:35 PM 01/09/08 05:35 PM |
Posts: 271 Atlanta, Ga | Maybe he flipped his 16 and survival training didn't pay off?
I used to keep a big trash bag on the boat..If I flipped I worked fast to keep from going turtle. I had a long line that I hooked to my harness. I would get the tramp against the wind as much as possible and begin filling the bag..just the motion of trying to lift the bag out the water would usually provide enough pull to get the boat back over. Don't get me wrong by teenager I meant 17-19, not 13 or 14. And there have been times I did need help (real choppy water, water in mast etc.) but generally I was able to do it on my own.
I have nothing against a 14 (used to have one) and in this specific case it may truly be the better of the two choices.. but for my taste I personally have a soft spot for the H16 and it will always be my first suggestion to someone interested in getting into sailing ..and no I'm not one of those "Hobie way of life" people | | |
20,658
guests, and 849
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online21,917 11 minutes ago | | |
