Page 1 of 4 1 2 3 4
Texel, SCHRS and PY #128878
01/16/08 06:28 AM
01/16/08 06:28 AM
wirebound Offline OP
So what can we expect this year with Texel and SCHRS and the PY systems. Hold the same as 2007 or getting sharpened?
Re: Texel, SCHRS and PY [Re: wirebound] #128879
01/16/08 06:40 AM
01/16/08 06:40 AM
The RYA publish new PY numbers every year.
The SCHRS management group are working on some minor polishing on the rule, nothing spectacular and will not effect most boats.
Feedback we have had this year has been positive and that what was done last year was valid and produced better results.
Re: Texel, SCHRS and PY [Re: scooby_simon] #128880
01/16/08 06:54 AM
01/16/08 06:54 AM
Thanks Simon, that was quick.
Re: Texel, SCHRS and PY [Re: wirebound] #128881
01/16/08 07:40 AM
01/16/08 07:40 AM
Just happened to be in the area when you asked the question. Actually at home recovering from a nasty virus.
Re: Texel, SCHRS and PY [Re: wirebound] #128882
01/16/08 12:16 PM
01/16/08 12:16 PM
Mark P Offline
Mark P  Offline
Here is something that may be of interest. http://www.sailwave.com/?page=devplan take a look at; "In the pipeline" Is this truly going to be a Global Rating System which is in real time, as in amends itself every time results are downloaded so you have the most up to date and accurate ratings possible!!!! We shall have to wait and see.
MP*MULTIHULLS
Re: Texel, SCHRS and PY [Re: Mark P] #128883
01/16/08 01:55 PM
01/16/08 01:55 PM
Cheshire, UK
Simon Offline
Simon  Offline
Cheshire, UK
OK Simon, at the risk of going off at a tangent, what do you mean by "what was done last year was valid and produced better results"? Have you seen boats that used to win now get beaten, and vice versa? And given that we all basically agree it's the nut on the tiller that makes the difference, how can you judge the effect of the changes?
Go on, it is winter... <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Simon
Simon
Shadow 067
Re: Texel, SCHRS and PY [Re: Simon] #128884
01/16/08 02:48 PM
01/16/08 02:48 PM
Simon
I've had a good number of people comment that the revised numbers look better and reflect the performance more accuratly than the previous 2 decimal place system.
Re: Texel, SCHRS and PY [Re: scooby_simon] #128885
01/16/08 05:39 PM
01/16/08 05:39 PM
claus Offline
claus  Offline
So here goes a contrary comment, concerning the H16 rating which I know. Even with the 1,16 rating it was very difficult to get an acceptable position in a race (with less than 15 knots), now it is even worse (1,146). I dont know why this is so (daggerboards, spi?) but in Spain the rating kills the H16, as no classes come together at a local level and we have to sail in a mixed fleet.
Re: Texel, SCHRS and PY [Re: claus] #128886
01/16/08 06:37 PM
01/16/08 06:37 PM
Claus,
Please can you send me (email address is on www.schrs.com) these results(in sailwave format please) of these races where you feel the H16 was not getting appropiate rewards. Please also include the wind conditions, sailing area, and "skill" level of those competing. We can then add it to the "race database" for the next time we run "evaluation races".
The reason the rating went down is partly because the all up weight we had for the boat was wrong (it's now dropped to 145.15kg).
Re: Texel, SCHRS and PY [Re: scooby_simon] #128887
01/17/08 01:42 AM
01/17/08 01:42 AM
claus Offline
claus  Offline
Simon, I dont have the numbers, it is just personal experience sailing with the Hobie 16 against F18 and A class and Tornadoes the last two years in varying conditions. The only times we were able to get into the first three places was 15 kn++. I changed class because of the H16 rating and with the F18 I am much more competitive. My personal impression is backed up by a race last summer where the H16 European Champion and the third in the SA H16 Worlds placed 6 and 7 behind A classes and Tigers that are not even top sailors at our national level (lightish conditions).
Re: Texel, SCHRS and PY [Re: claus] #128888
01/17/08 04:44 AM
01/17/08 04:44 AM
Mark P Offline
Mark P  Offline
Without trying to sound too bias this is where the Sailwave International Rating System (SIRS) will be beneficial. Not only will the ratings be update every time race data is inputted from anywhere around the World but I believe it will discount the best and worst performance percentages from the results. As I've mentioned before this will produce the most accurate ratings available at any one time. It's a great concept and I'm sure it will prove to be very successful.
MP*MULTIHULLS
Re: Texel, SCHRS and PY [Re: claus] #128889
01/17/08 06:05 AM
01/17/08 06:05 AM
The 16 will struggle in the lighter stuff agaist such boats. It's a nature of the boat.
I'd expect the 16 to do much better in the big stuff.
Re: Texel, SCHRS and PY [Re: claus] #128890
01/17/08 07:59 AM
01/17/08 07:59 AM
I think we must understand one key aspect of any measurement based rating system.
It rated the performance that CAN BE HAD with a design using the given specifications, not what a real design has as performance.
Basically, say we have two F18's designs one is a plain optimized one and the other has rectangular boxes for hulls. Both will be rated the same under any measurement based rating system.
The Hobie 16 is suffering from that problem. It has a relatively large sail area combined with a rather ineffective sail shape and hull shape. The latter going beyond the point of being boardless. Both the Nacra 5.0/Nacra 500 as the Prindle 16 point higher then the Hobie 16 and achieve the same VMG or better VMG with a smaller suit of sails. This is the rest of their boardless hull design being significantly more efficient at resisting sideways slipping the the hulls of the Hobie 16.
Note how these three boats have hulls of the same length and weight overall about the same as the Hobie 16, so they are good comparisons.
Re: Texel, SCHRS and PY [Re: scooby_simon] #128891
01/17/08 09:45 AM
01/17/08 09:45 AM
claus Offline
claus  Offline
And in a perfect rating system this nature would be well represented by the formulas. Of course, a perfect system does not exist, but in the case of the 16 the schrs does not work well, whereas with more similar boats (F18-T-A) it usually works out fine.
This could indicate for example that the factor applied to centerboard area and aspect is too small. Or maybe it would be nice to have a factor that controls if we have a more efficient rig (with diamonds, controlable mast rotation etc.) which permits more control and therefore permits a sailcut that powers up with less wind.
I guess the influence of these systems on the survival of classes is probably underestimated. A good 16 sailor here gets bored going to local races if he has no chance to obtain a good position. So he only has the national races where we have a 16-only fleet. Given that there are much more local races during the year, he will have more fun if he gets another boat for racing (F18, A etc.). He finally sells the 16 and both the local and national H16 fleets get smaller. That is what seems to be happening in Spain right now.
Wouter, I think a good rating system should try to adapt itself to the existing boats and not vice versa. Texel, although simpler, achieves this probably better than schrs.
Re: Texel, SCHRS and PY [Re: claus] #128892
01/17/08 10:06 AM
01/17/08 10:06 AM
But the F18, A and T are not that similar
One is a very hi-tech light single hander development boat without a kite, One is a heavy 2 up box rule boat with a kite, and one is a wide, ligher, powefull 2 up boat with kite. Not that much alike.
What ever rating an boat gets, it will have sweet spots.
If we were to a\dd amny seperate items into the rule, would it die as no-one would remember what they all needed to be and how they were controlled.
By the nature of such rules ans SCHRS and Texel, they need to have enough datas to provide the corrct results without too many datas to make the rule unusable.
Wouter is right that the H16 is a very old boat, with a sail shape that is not fast under current thinking and with an old hull shape. However it does have large sails as so should be able to perform.
Without real data it's difficult to analyse this. I've seen Hobie 16's sailed very well at my local club (by the RYA Youth squad) and see them make their handicap against similar skill crews in Hurricanes, Spitfires, Darts and various other classes.
Re: Texel, SCHRS and PY [Re: claus] #128893
01/17/08 02:11 PM
01/17/08 02:11 PM
That blame can not be assigned to the rating committees or rating systems. It is not so hard to make a measurement based rating system that covers all and even rates cardboard boxes very accurately.
The party that is making the problems are the race committees. For a while (I think in 2004) Texel had two rating numbers for each boat (setup); one for light winds and one for strong winds (trapezing), this is rather effect at taking the larger share of the inequalities, especially between say the H16 and A-cats. So we engineers and raters though we had cracked it. And what do you know ? all the racing committee simply refused to use the new system. It was too complicated they said; which is total BS of course as it was the very same system but now with two rating numbers. I think they even went as far as to agree among themselved to never use it. Loosely translated they simply don't care about any inequalities. They do care about the "perceived" hassle. Another thing was of course that they don't want to get into arguments with sailors why a certain race was marked as a "light winds" or "strong winds" race.
Of course as always the cat sailors themselved were to lazy and disorganised to mount an effective counter campaign and a year later Texel was restored to single number rating that must somehow strike an even balance between light and strong wind race. This means of course that it loose accuracy in both circumstances.
End of story.
Re: Texel, SCHRS and PY [Re: Wouter] #128894
01/17/08 02:26 PM
01/17/08 02:26 PM
End of story.
The problem with declaring "non trapezing" and "trapezing" ratings are that they occur at totally different points.
A class is (probably) flat wiring in 5 kts, My F16 is probably flat in 7, a Hurricane in 9 and a Dart 18 in 12 and a Sprint (Dart) 15 in 15
Where do you set the point?
US has 4 points, but all that does it make it more complex.
Who decides how windy it is? Do we have a procedure set out for it (to be fair we would need one, and thus it would be protestable).
Re: Texel, SCHRS and PY [Re: wirebound] #128895
01/18/08 07:01 AM
01/18/08 07:01 AM
Mark P Offline
Mark P  Offline
Check this out; http://www.yachtsandyachting.com/news/?article=139810
Maybe in the not to distant future we wont be seeing threads like this one <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
MP*MULTIHULLS
Re: Texel, SCHRS and PY [Re: Mark P] #128896
01/18/08 10:39 AM
01/18/08 10:39 AM
It has all the same drawbacks of any yardstick system and none of the advantages of a measurement system.
Will it be a more accurate yardstick system ? Possibly.
Will it be a more accurate rating system ? No.
One of the more endearing qualities of it will be : rating numbers that swing about depending on how enters or exists the class. The famous "Randy Smyth vs Supercat" syndrome.
I fear we will actually have more threads discussing the rating systems as a result.
Re: Texel, SCHRS and PY [Re: Wouter] #128897
01/18/08 11:21 AM
01/18/08 11:21 AM
Mark P Offline
Mark P  Offline
Are any sailing handicap ratings correct = NO. Will SIRS be the most accurate. That depends on the people who use it. The more people who use it bearing in mind that Sailwave is used all over the World then the more accurate it will be. As for swinging back and forth you are correct this can happen which is GOOD. If you were using it for a Summer series for instance then the ratings could be set from the 1st race and wouldn't necessarily be altered till the last race. During which period the ratings would have probably altered. You could then if happy with the Summer results stick with the same ratings or start the Autumn series with the latest ratings from SIRS. You wouldn't have to wait a year for an updated rating which is currently the case. Wouter I don't want to get embroiled in a discussion over something neither of us are likely to change. I respect your views in regard to formula based Ratings but please don't tell me that my personal feelings are wrong because I believe that SIRS has the capability to be one of the best rating systems known to Sailing.
MP*MULTIHULLS
Page 1 of 4 1 2 3 4
0 registered members (), 2,458 guests, and 328 spiders.
