N20 Diamond Wire? #129460
01/22/08 10:56 AM
01/22/08 10:56 AM
Crofton, MD
Chris9 Offline OP
Chris9  Offline OP
Crofton, MD
What is the new adjustable diamond wire setup for the N20? I know it was discussed here within the last month, but I couldn't find it.
I think I have the originals as two wires with one adjustment. I thought I read here that each wire now gets it own adjuster. I heard in the bar the other night that only one wire gets an adjustment.
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: N20 Diamond Wire? [Re: Chris9] #129461
01/22/08 12:20 PM
01/22/08 12:20 PM
Northern Virginia
SoggyCheetoh Offline
Northern Virginia
Chris,
The new wires are set up just like your original ones, except that one wire now has a turn buckle adjustment on it. You still set the diamond tension using the main adjustment in the center, but you can even things up with the turn buckle on the single wire. I believe this solves a quality control issue if one diamond wire ended up being slightly longer than the other.
Alec
Alec D.
Pirates of the Chesapeake www.teampiratesofthechesapeake.com
Nacra20 1057 - Crew
F16 Viper 152 - Uni
Re: N20 Diamond Wire? [Re: SoggyCheetoh] #129462
01/22/08 12:30 PM
01/22/08 12:30 PM
Crofton, MD
Chris9 Offline OP
Chris9  Offline OP
Crofton, MD
ahhhhh. got it.
Tanks!
Chris Allen
Nacra 20 Gertie
www.wrcra.org
0 registered members (), 384 guests, and 437 spiders.
