| Re: Rigging replacement
[Re: Qb2]
#131147 02/08/08 04:43 AM 02/08/08 04:43 AM |
Joined: Oct 2007 Posts: 199 Constanta, Romania isvflorin
Posts: 199 Constanta, Romania | Hi, Just a thought, not necessarily an advice. Clamping the ss fittings on the cable is delicate stuff, but you don't want that to brake or get loose. The mast is much too important and expensive to have it damaged by using home made rigging.
You should check out these companies and find resellers of their stuff.
"Jakob Inox" "Carl Stahl"
These companies offer architectural hardware and rigging, and you can order ready made , cut to lenght rigging that is guaranteed to withstand a certain tension. The SS cable is welded to the end fittings so breaking or getting loose is out of the question. You can download their catalogues from their websites in pdf form, and then choose the exact type of fittings you want.
Just a thought. Not sure if it would be cheaper than marine rigging.
Florin
[Re: Qb2]
#131148 02/08/08 08:50 AM 02/08/08 08:50 AM |
Joined: Apr 2005 Posts: 473 Panama City, Florida Redtwin
Posts: 473 Panama City, Florida | For the past couple of years, I have built and replaced my own rigging. I build them right in the hardware store where I buy the parts. They have a huge table and all the tools necessary to build the rigging. I use 1x19 and have not had any problems getting them around the spindles. It is pretty exausting on the fingers but it can be done. I hold the wire and fitting tight with both my hands while the store employee works the swage tool. It is best to make it a two-man job, just be sure to communicate well so the other person does crimp your fingers. <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" /> Since I personally build the rigging I trust it; however, I do end up changing it out more often than I would if I had bought the rigging ready made. Even though I change it so often, building the rigging is still much cheaper than buying the ready-made stuff. On the other hand, if you are having trouble getting a perfect fit and a perfect crimp, I would not trust the rigging. The mast is a very big stick to have come down on you. I should add that I sail in a bay with very flat water and my "stay on shore" wind speed is anything over 15 knots. If you sail in any kind of surf or sail in heavy winds from time to time, I would highly recommend forking out the extra cash for some professionally-made rigging. They are really not that expensive when you factor in the security and peace of mind. Rob V.
Nacra 5.2
Panama City | | | Re: Rigging replacement
[Re: pepin]
#131152 02/08/08 10:44 AM 02/08/08 10:44 AM | Anonymous
| Anonymous
Unregistered | Spectra instead of forestay and shrouds??? NO way? for real? | | | Re: Rigging replacement
[Re: ]
#131153 02/08/08 11:42 AM 02/08/08 11:42 AM |
Posts: 321 Albuquerque NM | Not sure about rigging, have heard a few people use it for Trap wire.
[b] Sail Like you have a Pair
[Re: ]
#131154 02/08/08 12:21 PM 02/08/08 12:21 PM |
Posts: 1,203 uk | I'm going to use it on the F32 so it should be do-able on a beach cat have a look on http://www.precourt.ca/ they know their stuff P
[Re: ]
#131156 02/08/08 04:36 PM 02/08/08 04:36 PM |
Posts: 1,200 Vancouver, BC | A-cats allow use of spectra rigging. T-class does not permit it for standing rigging or mast diamonds, but does for traps & spin pole stays. If permitted, most T boat teams would use it all around since it's lighter. Cost wise is would be cheaper than the currently popular Dyform cable (~$1.30/foot for 3-3.35 mm). Spectra instead of forestay and shrouds??? NO way? for real?
[Re: Qb2]
#131158 02/10/08 09:17 AM 02/10/08 09:17 AM |
Posts: 199 Constanta, Romania | You should make some pics while working on the rigging and post it on the homebuilding section. Might be usefull, or maybe you should post the pics after a test sail with strong wind. Good luck and keep us informed. <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
Florin
[Re: mikekrantz]
#131161 02/10/08 06:55 PM 02/10/08 06:55 PM |
Posts: 1,253 Columbia South Carolina, USA | Ive done 3 boats at West Marine for around $50-$75 for 2 shrouds and a forestay. All 3 boats were smaller beach cats, GCat 5.0, NACRA 5.0 and 5.2. I used 1x19 wire, double thimbles, and thier bench swager. All 3 boats are still sailing with this rigging, the oldest being 6 years old(I wouldnt recommend waiting that long but these guys dont sail as much as some of us. I found it quite easy to put the thimble in the swage and cinch it up tighly by myself. The most difficult part was getting the "pull to pull" length right, especially by yourself. The West Marine guys said they couldnt help for liability purposes. The most important thing is to double thimble, IMHO.
If I were sailing with a carbon mast, or a new boat, I would probably go with a professional rigger.
[Re: avalondarlyn]
#131163 02/10/08 11:12 PM 02/10/08 11:12 PM |
Posts: 169 Santa Barbara CA | For Dave M., do you mean double nico (nickel-copper) sleeves? If not, I don't understand what you mean by double thimbles. As for the double nicos, that used to be the standard espec. on hang gliders (I'm a sailing and hang gliding rigger btw) but when testing got better it showed the double nicos made the terminal too stiff, and increased wire fatigue in the area next to the thimble. On the length thing if you take very careful measurements you can figure out how much length you lose going around the thimble, I have a whole chart I made for how much wire to cut to get the right finished length. Especially with loaner tools make sure to use the go gauge, which is a piece of metal with slots for the different size nicos, and if it won't fit in the slot it isn't compressed enough. For QB2, don't use 7x7 or 7x19, both are too stretchy. As for the synthetic rigging, it can be a real pain to get symmetrical, and on the big boats they usually have a hydraulic come-along that hooks into the rig for adjusting the lashings. All in all, it's hard to beat rotary hammered swage terminals, but if you do Kearny swage (has two rotating dies that draw the fitting through) most places do a second pass after rotating the fitting 90 deg. to flatten off the "wings" that form after the first pass, but that's shown to over work harden the fitting. If you got bucks you could also do a Norseman/Staylok type screw together terminal, very simple to do and very low wire fatigue during assembly (these are the ones you should fill with 5200, but on a regular fitting I use Lanocote). Just for reference, my old shop had a rotary hammer that could do up to 1.5 inch wire, and you have never had fun like having the terminal stick in the die, the flywheel keeps the machine turning long after the power is shut off, turning the wire into flying jumprope of death, literally beating holes in the walls and smashing out the overhead lights until it slows down....
[Re: PTP]
#131165 02/11/08 12:09 PM 02/11/08 12:09 PM |
Posts: 1,253 Columbia South Carolina, USA | sbflyer, yea I meant nico's, and Im not a rigger by anymeans, just had good luck with my 3 attemts I guess.
4,145
guests, and 742
