| Building a mast #132980 02/24/08 11:23 AM 02/24/08 11:23 AM |
Posts: 435 Finland | I have just started to build a new mast for my Mini 650, and after that I will attack the one for the Blade. So for those interested: http://www.gust.ax/gallery/mast/ | | | Re: Building a mast
[Re: Gato]
#132987 02/28/08 04:25 AM 02/28/08 04:25 AM |
Posts: 435 Finland | | | | Re: Building a mast
[Re: Gato]
#132988 02/28/08 05:32 AM 02/28/08 05:32 AM |
[Re: Gato]
#132989 03/01/08 02:36 PM 03/01/08 02:36 PM |
Posts: 9,582 North-West Europe | Gato,
When you start on the Blade mast you should really post that on the F16 forum; I'm sure you 'll get alot of response there and it is of course an excellent read for all of us !
| | | Re: Building a mast
[Re: Gato]
#132998 03/04/08 03:44 PM 03/04/08 03:44 PM |
Joined: Oct 2007 Posts: 199 Constanta, Romania isvflorin
Posts: 199 Constanta, Romania | Gato, The mast homebuilding project is very interesting considering the price of a new mast, and shipping options for it. I am curious about how are you going to make the mainsail track. I assume you already have that sorted, but how ?
Florin
| | | Re: Building a mast
[Re: isvflorin]
#132999 03/04/08 03:55 PM 03/04/08 03:55 PM |
Posts: 4,451 West coast of Norway | Gato and Florian, J.R. Watson at Gougeon have been building boats with epoxy for a generation soon. I asked him about beams (sorry for going off topic, but it is kind of related and very interesting for homebuilders). Here is his reply: The rule generally regarding carbon vs aluminum is that the wall thickness that works for aluminum (say 3mm) will work for carbon – all geometry the same. The Marstrom and Lindahl A-class have carbon beams that are just under 3mm thick. If strip planked you could subtract from that a little. I would especially like to see the beam striped in halves with carbon put on inside, halves then joined then outside carbon applied. I think you could get away with 1mm inside and 1 mm outside with 6mm thick spruce strips. 75% unidirection 25% braid or biaxial or woven for hoop strength. Striped up you could increase geometry toward the center, tapering as you get to the hull (can’t do that with extrusions or pultrusion) but you could with a strip version – especially applicable to the forward beam. In addition to function, it would look cool too. (This was actually done in some of the early C-class by Hubbard and A-class boats like the Loca. The aft beam should be lighter than the forward beam. You could also add to the outside if under built – the way to do it if you’re pushing the envelope. We are considering it for our boats.. List of to-do's are constantly growing.. Having access to guys like J.R. Phill, Marcus and others and sharing information between us is what forums should be about. Not squabbling and personal agendas. | | |
410
guests, and 746
