| Re: Building a mast
[Re: Rolf_Nilsen]
#133000 03/04/08 09:14 PM 03/04/08 09:14 PM | Anonymous
| Anonymous
Unregistered | This is a very good rule of thumb that I was first introduced to as a student by some very experianced Aeronautical Engineers. Typically it leads to an approx 25% weight saving over ali and a significantly stiffer part. I would usually specify a double bias instead of the biax in order to provide some off access strength. | | | Re: Building a mast
[Re: Gato]
#133003 03/05/08 02:28 AM 03/05/08 02:28 AM | Anonymous
| Anonymous
Unregistered | Because the BX (Double bias) carbon is hard to get, the other alternative is to wrap unis around on a 45 degree angle.
Laminate schedule would be some thing like: Outside Carbon unis at 45 degrees (clockwise) Carbon unis along mast Carbon unis along mast Carbon unis at 45 degrees (anti clockwise) Core Carbon unis along mast Carbon unis along mast Carbon cloth (0/90) Inside.
Disclaimer: This is not an engineered solution just a starting point. | | | Re: Building a mast
[Re: Gato]
#133005 03/05/08 04:12 AM 03/05/08 04:12 AM | Anonymous
| Anonymous
Unregistered | yeah thats fine, you'll just need a little more. | | | Re: Building a mast
[Re: Rolf_Nilsen]
#133006 03/05/08 04:28 AM 03/05/08 04:28 AM |
Posts: 9,582 North-West Europe | The rule generally regarding carbon vs aluminum is that the wall thickness that works for aluminum (say 3mm) will work for carbon
I understand nobody give much about what I say or about my maths but here goes anyway : The aluminium masts and beams used on the F16 (Halve of which I designed) use 1.6 mm to 2 mm thick walls. Only Bimare has used 3 mm thick walls on the beams at one time; John Pierce used 4 mm on his Dolphinstrikerless Stealth which was a predecessor to the F16 (but not full F16 compliant) at the time. My point, 3 mm thick (aluminium walls) is NOT a good rule of thumb for F16's; it overestimates the parts used in real life by 50 to 85 %; overestimating the associated weights accordingly. I have yet to see a 1.6 mm thick wall on a carbon mainbeam. In my experience with stunt kites I found that carbon beams are relative easy to break when point loaded, especially when the loading is perpendicular to the carbon fibres. This happens at several points along the mainbeam (bolts, transition from hull to overspan, mast step). Basically the glue matrix cracks up allowing movement of the fibres which then break one by one to finally break to whole element there locally. The thinner the walls the easier it was to break carbon tubes that way. We used to reinforce the tips of the carbon tubes for this reason. I strongly suspect that the underlaying layer of timber layer will go some way of improving this. Density of extruded aluminium is 2710 kg/m^3 (for 6061-T6) Density of carbon laminate is what ? 1850 kg/m^3 (from top of my head) Density of Gaboon ply is what ? 650 kg/m^3 (from top of my head) This means you may not have a carbon wall thicker then 145% of the alu wallthickness if the criterium is to arrive at equal weight of less. Going from 2 mm alu wall to 3 mm carbon wall is an increase of 150% for example. With respect to ply : 417% increase in wallthickness will do the trick. Therefor a 6mm thick middle layer of this ply (as adviced by J.R. Watson) will weight the same a 1.45 mm thick aluminium wall already (= 90% of 1.6 mm thick walled alu mast section). So here to you need to cut down if any significant weight savings are to be achieved. The aft beam should be lighter than the forward beam
Only if the mainbeam is dolphinstriker less; otherwise it would seriously consider making both beams the same. 450 kg of mainsheet pull in the middle of the rearbeam is alot of loading as well. It seems from the experience I have that the rule of thumbs supplied here by J.R. Watson are too crude to be of much use to an F16. Although they may well be accurate for larger vessels like yachts and Tornado's (don't they use 3 mm thick alu beams Rolf ?). Mind you F18 masts use 1.6 mm wallthickness on the masts as well. Tornado alu masts use 2 mm wallthickness and the A-cat carbon mast I have a cut-off from, uses 1.2 to 2.0 mm thick walls (pure carbon) depending on where you measure it. This is an Australian composites mast and was used by Gary on Altered when that boat was still a mk5 Boyer A-cat. I hope this info helps. Wouter
| | | Re: Building a mast
[Re: Wouter]
#133007 03/05/08 04:58 AM 03/05/08 04:58 AM | Anonymous
| Anonymous
Unregistered | Wouter do you read what you write?
"F18 masts use 1.6mm wall thickness" "Tornado use 2mm..." "A class... 1.2-2mm"
Sounds like carbon thickness is similar to aluminium to me. I'm pretty sure the 3mm was pulled out of the air for the sake of an example and that Gato was always intending on confirming numbers etc. | | | Re: Building a mast
[Re: ]
#133008 03/05/08 06:30 AM 03/05/08 06:30 AM |
Posts: 435 Finland | One thing is sure. nobody is going to get me to put 3mm of carbon... Even the alu mast for the mini has a wall thickness of 1,6mm It's just the profile that is larger and makes it 2.5ks/lm Btw. the same profile in carbon is about 1,6kg/lm
| | | Re: Building a mast
[Re: ]
#133012 03/05/08 02:17 PM 03/05/08 02:17 PM |
Posts: 9,582 North-West Europe | Wouter do you read what you write?
Humm, lets see if anyone can spot the differences ? "F18 masts use 1.6mm wall" F18, total crew weight 140-170 kg, double trapeze, total righting moment 774 kgm, spinnaker, forestay with jib, total 21.15 sq. mtr upwind sailarea and typically 9:1 or 10:1 mainsheet with crew using both arms to work it. 12:1 and 16:1 cascaded downhaul. Mast survives severe impacts with watersurface "Tornado use 2mm..." (I repeat that this is the ALUMINIUM Tornado mast) Tornado, total crew weight 140-170 kg, double trapeze, total righting moment 900 kgm, forestay with jib, spinnaker, total 22.82 sq. mtr. upwind sailarea, typically 9:1 or 10:1 mainsheet with crew using both arms to work it. 12:1 and 16:1 cascaded downhaul. Mast survives severe impacts with watersurface "A class... 1.2-2mm" (I repeat that is dependent on where you measure; sides are 2 mm, front/web are 1.2 mm) A-class, total crew weight 60-90 kg, total righting moment 334 kgm, single trapeze, double forestay and no need to have a tight forestay, total sail area 13.94 sq. mtr. , typically 6:1 mainsheet with skipper using only 1 arm to work it. 8:1 downhaul. Mast breaks during severe impacts with the watersurface. So yes, the wallthickness are similar where the masts in the way of strength, loading and durability are not. Wouter
| | | Re: Building a mast
[Re: Gato]
#133014 03/05/08 05:14 PM 03/05/08 05:14 PM | Anonymous
| Anonymous
Unregistered | Gato, you've probably seen thats I've just asked for some data on the existing ali masts assuming someone comes fwd with it I'll try and put a laminate spec together for you. When are you hoping to start? | | | Re: Building a mast
[Re: Rolf_Nilsen]
#133016 03/05/08 05:50 PM 03/05/08 05:50 PM | Anonymous
| Anonymous
Unregistered | No worries, I don't have time at present to do it from scratch but if someone gives me a leg up with the ali data then I'm happy to put something together (all care no responsibilty) | | | Re: Building a mast
[Re: Gato]
#133017 03/05/08 06:06 PM 03/05/08 06:06 PM |
Posts: 9,582 North-West Europe | Gato,
Actually the cross section of the carbon mast I quoted in my post is as good as identical to the superwing F16 mast crossection. Of course all comments about higher loadings, smaller wall thickness and such also hold for the F16 superwing.
I'm amazed at the shear stupidity of some people here. Did you guys honestly think that I hadn't checked for that ?
And Gato your comments on putting carbon on inside or outside of the mast is just misplaced. Failure of the mast is not because of the crossection failing but because the wall is buckling locally under compression loads and thus initiating a larger failure mode. Increasing local buckling resistance (double sandwhich construction) is therefor more important then the downsides of placing some carbon on the inside of the mast. If you are using 4 mm thick ply then you can just as well forget about the whole project altogether as the ply will already weight 8.5 kg on its own and won't do much in the way of strength and stiffness.
But I get the hint. I will scram off now and leave you guys to discovering these things yourself.
Who needs a qualified engineer anyway right ? I only went to "school" and learned nothing !
Bloody ignorants !
| | | Re: Building a mast
[Re: Gato]
#133019 03/06/08 01:26 AM 03/06/08 01:26 AM |
Posts: 435 Finland | If somebody is interested in “guessing” the final weight the wood weight glue included will be something around 6,5 kg. The mast I already made had a wood weight of just under 5 kg, and I used spruce instead of WRC on that one.The calculations are adjusted by a sharp plane. There is another thing that is troubling me a little. If we shift to all carbon my method of joining the strips by glassing them together will result in some completely useless extra weight in glass, but I don’t see myself doing it with carbon. In that case I would portably have to put all the carbon going on the inside and bag it.
2,518
guests, and 342
