box rule drawing #133317
02/25/08 04:16 PM
02/25/08 04:16 PM
Knokke-Heist - Belgium
Gilo Offline OP
Gilo  Offline OP
For the F16 flyer I still need the boxrule in high resolution. I contacted the original person that did the drawing and he wanted to draw it again but is rather busy at the time. I really want the flyer to be ready before Carnac so I wondered if anyone else could make this drawing? Does anyone know how to draw things in CAD or another program?
You will be rewarded with lots and lots of fame ;-)
Gill
Falcon F16 - BEL666
Boats: TheBoatShop.be
Re: box rule drawing [Re: Gilo] #133318
02/25/08 06:03 PM
02/25/08 06:03 PM
Constanta, Romania
isvflorin Offline
isvflorin  Offline
Constanta, Romania
Can you be more specific ? What actually has to be drawn ?
Florin
Re: box rule drawing [Re: isvflorin] #133319
02/25/08 08:13 PM
02/25/08 08:13 PM
Re: box rule drawing [Re: Gilo] #133320
02/26/08 03:09 AM
02/26/08 03:09 AM
Constanta, Romania
isvflorin Offline
isvflorin  Offline
Constanta, Romania
Ok, thanks for clearing things out. When does it need to be ready, is it ok if it is vectorized over the raster version ?
Florin
Re: box rule drawing [Re: ] #133321
02/26/08 03:56 AM
02/26/08 03:56 AM
Constanta, Romania
isvflorin Offline
isvflorin  Offline
Constanta, Romania
First sketch. If anybody else started working on this they should mention it, also it might be a good time to update the drawing with other things (logo). Remarks ?
135057-boxrulef16.pdf (230 downloads)
Florin
Re: box rule drawing [Re: isvflorin] #133322
02/26/08 05:55 AM
02/26/08 05:55 AM
I know it will be alot more work, but here is an idea that would really well in a brochure.
Is it possible that we have a 3D rendering of an F16 boats enclosed with a wireframe box with dimension arrows/numbers along side in 3D ?
We had such a figure in the past and it looked so bloody good.
It visually explained the name "Box-rule" which suprisingly enough is still not a widely understood concept. And it cuts down on required space by allowing all measurements to be drawn in one single pictures instead of needed three (front view, sideview and top view)
Re: box rule drawing [Re: Wouter] #133323
02/26/08 06:14 AM
02/26/08 06:14 AM
Like this? <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: box rule drawing [Re: Wouter] #133324
02/26/08 07:03 AM
02/26/08 07:03 AM
Constanta, Romania
isvflorin Offline
isvflorin  Offline
Constanta, Romania
Wouter , everything is possible. And that would be really cool. There are some design copyright issues regarding the boat I assume.
Back to the basic box rule drawing. When do the guys need it ?
It's just a matter of adding the dim lines.
Tony - that should explain it better. <img src="http://www.catsailor.com/forums/images/graemlins/laugh.gif" alt="" />
Florin
Re: box rule drawing [Re: isvflorin] #133325
02/26/08 02:45 PM
02/26/08 02:45 PM
Gilo Offline OP
Gilo  Offline OP
Hi Florin,
Thank you very much for your initiative!
If you could have it ready by next Tuesday, I could take it with me to Gulfport.
Otherwise, end of March is ok.
I would propose to start of with the same drawing as we have at the moment to get the flyer finished, from that design onwards (and if everyone involved wants to put the effort into it) we could go for an updated version.
Regars and thanks again!
Gill
Falcon F16 - BEL666
Re: box rule drawing [Re: Gilo] #133326
02/26/08 05:59 PM
02/26/08 05:59 PM
Constanta, Romania
isvflorin Offline
isvflorin  Offline
Constanta, Romania
Gill,
It might be ready by Tuesday.
Florin
Re: box rule drawing [Re: Gilo] #133327
02/27/08 02:41 PM
02/27/08 02:41 PM
Constanta, Romania
isvflorin Offline
isvflorin  Offline
Constanta, Romania
Gill, this is what I managed to do so far. I don't know If I got the lines right, the raster version is low res and difficult to read. PM me your email so I can send dwg, 3dm, ai or other. Lineweights can be adjusted in autocad depending on print size. I'll be away for a few days and take the file with me. Hope I find wifi spot.
Good luck
135215-boxrulef16.pdf (195 downloads)
Re: box rule drawing [Re: isvflorin] #133328
02/27/08 02:57 PM
02/27/08 02:57 PM
There are a couple of errors in the drawing :
-1- We don't use rated sail area's anymore; max mainsail area (real) = 15.0 sq. mtr. and max jib area (real) = 3.7 sq. mtr. We also don't use the combined area of mainsail+jib anywhere in the class rules anymore.
-2- 104 kg is the minimum weight for the 1-up setup and not for the 2-up setup
-3- The gennaker clew corner is much higher up and maybe you can make the mainsail look more modern with a larger squaretop and a more straight leech.
-4- All F16 jibs are selftacking these days; the draw jib setup is still the old overlapping Taipan 4.9 setup with the blocks halveway down the trampoline.
Re: box rule drawing [Re: Wouter] #133329
02/27/08 04:25 PM
02/27/08 04:25 PM
Constanta, Romania
isvflorin Offline
isvflorin  Offline
Constanta, Romania
Wouter, thanks for clearing things up. It was done on a hurry. I hope to find some time to adjust things.
Florin
Re: box rule drawing [Re: Wouter] #133330
02/28/08 12:48 AM
02/28/08 12:48 AM
Marcus F16 Offline
Marcus F16  Offline
Quote -
Both of which are not class rules.... <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />. The guy is doing the class a favor - dont pick too much.
Marcus Towell
Re: box rule drawing [Re: Marcus F16] #133331
02/28/08 01:50 AM
02/28/08 01:50 AM
taipanfc Offline
taipanfc  Offline
Still have the option of going to (or staying with) a non self-tacker jib. Could say there are still some advantages to this and depends on what type of racing you do. Reaching with a self-tacker is really crap when you can't get a kite up, and your local club may do a lot of this style of racing. So agree with Marcus' view, and bit of a sweeping statement.
Think the diagram looks great. As long as the measurements are fine, then it fills the purpose.
Re: box rule drawing [Re: taipanfc] #133332
02/28/08 01:57 AM
02/28/08 01:57 AM
Gilo Offline OP
Gilo  Offline OP
Hi Florin,
Thank you for the effort. It already looks nice!
Depending on how much work this will take, you could take all Wouters points into consideration, or just the first 2.
Thanks again!
Gill
Falcon F16 - BEL666
Re: box rule drawing [Re: Marcus F16] #133333
02/28/08 03:09 AM
02/28/08 03:09 AM
Yes, but this is going to be part of a promotional package right ?
Better have the depicted boat look modern and truthful to reality right ?
How many car brochures are showing last years model ?
Re: box rule drawing [Re: taipanfc] #133334
02/28/08 03:15 AM
02/28/08 03:15 AM
... have the option ... could say ... depends on ... may do ...
Contrasted with what ? 95 % of all registered 2-up F16's having a selftacker now ?
You are just grasping any opportunity to pick on Wouter here.
Come on guys still is just childish !
Re: box rule drawing [Re: Wouter] #133335
02/28/08 03:23 AM
02/28/08 03:23 AM
taipanfc Offline
taipanfc  Offline
You could edit/quote your posts the same way, but that doesn't really achieve anything in this discussion/thread.
I have my reasons of why I think the Taipan-style jib in some ways is a better option than a self-tacker, and noted those down briefly.
Re: box rule drawing [Re: taipanfc] #133336
02/28/08 03:28 AM
02/28/08 03:28 AM
I'm sure you have but what are your reasons to want our promo "rules summary" drawing look outdated by showing an overlapping jib sheeted of the trampoline ?
That is the more interesting question.
1 registered members (JesperS), 759 guests, and 38 spiders.
