| Re: LOOKING FOR SUGGESTIONS ON RESTORING OLD HULLS.
[Re: VIC]
#133361 02/26/08 05:31 AM 02/26/08 05:31 AM |
Posts: 1,383 Kingston SE South Australia | G'day Vic you'll get heaps of answers dont sand the gelcoat off. I dont know the layout of a Gcat but definately from the inside, I cut the decks of my stingray and put divinacell foam under them then used wessystem to put them back on and bulkheads in the hulls to make a rigid boat. Its a huge job very satisfying but not cheap any photo's of your boat? is it really bad? regards
[Re: VIC]
#133363 02/27/08 09:01 AM 02/27/08 09:01 AM |
Posts: 12,310 South Carolina | Vic,
For all the trouble that would require, you would be better off to invest your money in a new used boat. Plenty of great boats can be had for around $1000.
Jake Kohl | | | Re: LOOKING FOR SUGGESTIONS ON RESTORING OLD HULLS
#133364 02/27/08 09:14 AM 02/27/08 09:14 AM |
Posts: 185 Shanghai, China | agree with Jake. the potential result and costs are far not worth the trouble.
Dirk
A-Cat GER 5
F-16 CHN 1 (sold)
SC 6.5 CHN 808
[Re: VIC]
#133367 02/28/08 01:31 AM 02/28/08 01:31 AM |
Posts: 1,200 Vancouver, BC | Simply laying new glass over the soft areas does not address the issue...the core has gone soft, not the outer layers (which den\pend on the core for stiffness). Typical way to repair a soft core area is to drill small holes through the outer layer of glass into the core but not through the ineer layer. Make a pattern of holes all across the soft area. Take a small syringer filled with epoxy thickened with light to medium density filler (get it near peanut butter thickness), then inject into the holes as completely as possible. After setting, sand off any lumps on the surface, paint or gelcoat the ares for appearance sake and you;re done. This is only practical if the soft areas are limited in size. It does add weight, but not much on reasonable sized areas. GOOD MORNING,
I'M A POWER-BOATER ON A SABBATICAL. I WANT TO BRING MY OLD G-CAT 5.0 BACK TO LIFE. IT'S BEEN IN THE BACK YARD FOR SEVERAL YEARS, AND THE HULLS APPEAR TO HAVE SOFTENED ON THE SIDES, AND ON THE DECK. I WOULD LIKE TO SOMEHOW REINFORCE THE HULLS. I'M NOT SURE IF TO SAND THE GEL-COAT OFF AND REINFORCE FROM THE OUTSIDE, OR CUT THE HULLS OPEN AND DO IT FROM THE INSIDE. ANY SUGGESTIONS WOULD BE GREATLY APPRECIATED.
THANKS,
VIC.
[Re: Tornado]
#133368 02/28/08 06:01 AM 02/28/08 06:01 AM |
Joined: Oct 2006 Posts: 119 Bernhards Bay, N.Y. popeyez7
Posts: 119 Bernhards Bay, N.Y. | The guys are right. Another boat it is..... <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" /> It's not worth the labor, especialy for that much of the hull(s)......
~~Don't fear the ''SPEED''~~ Fear the''ADDICTION'' ~17,18 Hobies, ~Jet boat~Speedster 150 ~2 Kayaks~ ~~~~VIETNAM VET. 69-71~~~~
[Re: popeyez7]
#133369 02/28/08 08:39 PM 02/28/08 08:39 PM |
Posts: 4 MIAMI, FLORIDA | GENTLEMEN,
THANK YOU FOR YOUR RESPONSES. I THINK YOU'VE HELPED ME SEE THE INEVITABLE. I MAY JUST USE THE HULLS AS PRACTICE TO HONE MY GLASSING SKILLS, AND WE'LL SEE WHAT HAPPENS.
ON ANOTHER NOTE, WHAT WOULD BE A GOOD SITE FOR USED CATAMARAN LISTINGS? I'VE GONE TO CATSAILOR, AND BOATRADER, BUT DIDN'T FIND MUCH.
THANKS AGAIN,
VIC.
[Re: arbo06]
#133371 02/28/08 09:25 PM 02/28/08 09:25 PM |
Joined: Sep 2007 Posts: 531 Lake Murray SC FasterDamnit
Posts: 531 Lake Murray SC | Go here and search as many Craigslist cities as you like. http://crazedlist.org/Search for catamaran and then Hobie. You can find some great deals.
E-Scow 24' ULDB
[Re: stingray]
#133373 02/29/08 07:58 AM 02/29/08 07:58 AM |
Posts: 1,383 Kingston SE South Australia | Sorry I posted the Stingray one by accident I was going to use that name originally when I joined Catsailor. regards
[Re: VIC]
#133374 02/29/08 01:07 PM 02/29/08 01:07 PM |
Posts: 291 | The Beach Cats is another good place to look. www.thebeachcats.com
5,459
guests, and 832
