| Re: Home building a mast..
[Re: Wouter]
#134207 03/04/08 10:45 AM 03/04/08 10:45 AM |
Posts: 120 Finland |
I keep saying it. Aluminium is a pretty wonderful material.
Ah, but so heavy, Gato is planning to lose few kg's with his ply/epoxy mast when comparing to wing aluminium section <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />.
Valtteri
[Re: Gato]
#134209 03/04/08 11:13 AM 03/04/08 11:13 AM |
Posts: 9,582 North-West Europe | Not to spoil the "corrector weight" party here, but the measurements supplied to me are in direct conflict with eachother. As a result I'm not convinced that the weight measurement is correct itself.
Now I like wood/timber but their ratios of "strength to density" and "stiffness to density" are lower then those of aluminium ; as such I don't see how a pure wooden mast can be superior in weight when having the same specs regarding strength and stiffness as an aluminium version.
Glass fibres share the same stiffness and density values with aluminium, but have a much higher yield stress limit. So by using that you can make a lighter and more flexible mast that won't break but I'm not sure that that is advantagious. I personally found glass masts to quickly resort to pumping on my landyachts. A combination of glass and wood will not be much differ in this respect unless significant amount of wood is used making the mast heavier.
The only real attractive option is mating timber with carbon fibre and I do expect some good results from any projects in that direction. Especially when thinwalled ply is used here.
[Re: Gato]
#134213 03/04/08 11:27 AM 03/04/08 11:27 AM |
Posts: 9,582 North-West Europe | Gato,
I'm thrilled to learn you go down that route.
I'm very interested in the results that you obtain that way and I have very high regards for the spirit to just try it.
You there are no other objections then I suspect that putting carbon on both sides (inside and outside) is best when compared to putting the same amount of carbon on only the inside or outside. I say suspect as I haven't done a more thorough analysis in that aspect yet. My expectation is that you can then get away with a significantly thinner ply wall. You be stressing the carbon fibres maximally but it is said that you can do that with carbon without much ill effects.
Best of luck !
[Re: Wouter]
#134214 03/04/08 11:45 AM 03/04/08 11:45 AM |
Posts: 120 Finland | Not to spoil the "corrector weight" party here, but the measurements supplied to me are in direct conflict with eachother. As a result I'm not convinced that the weight measurement is correct itself.
It wasn't measured with professional scales but even if it would be few percent off it still weights a lot and it doesn't change by using professional scales. I trust my scales more than your math based on these two and another mast that had smaller wall thickness, so there is too much unknown in it to draw any exact conclusions. IMHO alu is only good to save some money (not even that much) when comparing to a carbon and building your own wooden one does that even better.
Valtteri
[Re: valtteri]
#134217 03/04/08 01:46 PM 03/04/08 01:46 PM |
Posts: 9,582 North-West Europe | I trust my scales more than your math based on these two and another mast that had smaller wall thickness, so there is too much unknown in it to draw any exact conclusions.
Come on ! I also gave you a series of actual aluminium tip weight measurements taken at the time our F16's overhere were all officially measured by a ISAF certified measurer. I also gave you several weights of bare sections we weighted. If our identically shaped and fully fitted alu masts, incl. halyards, have tipsweights in the range of 7.8 to 8.2 kg then how on earth can your bare alu mast section weight 19 kg and have a tipweight of at least 9.5 kg without any fittings or halyards included at all ? That is not math, that is common sense saying that something very weird happened somewhere. Now I for one don't believe that the aluminium alloy suddenly increased over 30% in density for your mast alone. We checked compliance in crossectional shape, so that isn't the cause either. Now I still want to find out what really caused this weight measurement that you are upset about. If anything we can make you happy again and address the situation techically (new mast die ? lay claim at producer ?) if that is required. The most logical culprit at this time are your scales or your method of weighting. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />Either that or some 8 people in 3 different continents measuring about 10 different masts over a time frame of several years did all make the exact same measuring mistakes to arrive at very similar values. Not to mention the guys in the official engineering literature all making similar typos with respect to aluminium density and the way to calculate the total weight of thinwalled extruded sections. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> Nahhh ! Wouter
[Re: Gato]
#134218 03/04/08 01:56 PM 03/04/08 01:56 PM |
No cosmetics, but increased resistance of the wall under buckling failure. Very important in masts.
[Re: Wouter]
#134220 03/04/08 02:34 PM 03/04/08 02:34 PM |
Posts: 120 Finland | Wouter,
You assume that the only difference is 15 % of wall thickness, I guess that with that difference you can have also lot more alloy in some parts of the section. As I said before I didn't do weighting with professional scales but I trust them more than your calculations where there is too many unknown variables. I'm planning to weight it better though when our season starts in few months, so let's continue with carbon alu differences then.
For now I'm disappointed about not getting a carbon mast because clearly there is big performance difference i.e. lot more in weight difference than 4 kg's when comparing carbon to masts that we have here. As a engineer you should understand that dragging those extra kilos high up in the air is not that wise and percentage in weight difference is more than in price <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />.
Valtteri
[Re: Wouter]
#134221 03/04/08 02:48 PM 03/04/08 02:48 PM |
Posts: 120 Finland | That is not math, that is common sense saying that something very weird happened somewhere. Now I for one don't believe that the aluminium alloy suddenly increased over 30% in density for your mast alone. We checked compliance in crossectional shape, so that isn't the cause either.
Come on Wouter, There is over 15 % difference in mast wall thickness and you assume that the masts are otherwise identical? It's easy to slip 1 kg more alloy for example to reinforcements and sail track if you already slipped 15 % more to the wall <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />. Let's continue this when I have properly measured the mast when I have access to better scales in few months.
Valtteri
[Re: valtteri]
#134222 03/04/08 02:52 PM 03/04/08 02:52 PM |
Posts: 435 Finland | What’s the min tip weight? Just to know if it's of any use to taper. Want to keep the center of gravity as low as possible. <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
2,748
guests, and 589
