| Re: How do you rate a one-off boat?
[Re: FasterDamnit]
#135747 03/10/08 06:09 PM 03/10/08 06:09 PM |
Posts: 3,293 Long Beach, California | looks slow... needs more sail area... or an evinrude. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
[Re: John Williams]
#135748 03/10/08 06:25 PM 03/10/08 06:25 PM |
Joined: Sep 2007 Posts: 531 Lake Murray SC FasterDamnit OP
Posts: 531 Lake Murray SC | I was thinkin a ketch/junk rig w/ lee boards...
E-Scow 24' ULDB
[Re: wildtsail]
#135750 03/10/08 07:23 PM 03/10/08 07:23 PM |
Posts: 531 Lake Murray SC | That trailer is a temp. The aluminum trailer will get a ply deck w/ carpet. Cheaper, easier and supports the hulls better than cradles.
E-Scow 24' ULDB
[Re: FasterDamnit]
#135751 03/10/08 07:32 PM 03/10/08 07:32 PM |
Posts: 2,921 Michigan | I thought those looked like HT hulls. Definately use cradles or a well padded flat deck. The hulls are very "tender."
Up the frankenboat factor with some risers for the rear beam.. absolutely necessary IMO with that boat in any sort of chop downwind.
[Re: FasterDamnit]
#135756 03/10/08 08:26 PM 03/10/08 08:26 PM |
Posts: 2,921 Michigan | I meant risers to get the rear beam further from the water. Have you noticed how much the rear beam slaps the water and slows you down when running downwind? anyway... take the dpn of the original boat and then use all the multipliers to get to a decent starting point. There are modifiers for oversized main, no jib, jib on a boat normally without, etc etc etc... http://www.ussailing.org/portsmouth/tables06/modifications06.asptell us what you did to change the thing and we can then calculate a starting point at least. | | | Re: How do you rate a one-off boat?
[Re: FasterDamnit]
#135760 03/10/08 08:58 PM 03/10/08 08:58 PM |
Posts: 1,253 Columbia South Carolina, USA | leave the jib off and put on a spin. Ive got one for you, came off my F18. Its in fair shape, but its cheap! Get that boat to Tommy Whitside, we will rate it for you. And Bill Hendrix will be there with his one off TheMightyHobie18/20(were not sure how long it is) but its got a nice Tiger main on it, and he is one of the best sailors around. His Frankenboat rules! he is the aster at making a sq top out of an old sail.
[Re: mike220]
#135763 03/10/08 11:58 PM 03/10/08 11:58 PM |
Posts: 531 Lake Murray SC | PTP,
I'm currious, how do you put in the risers for the rear cross beam?
Construction, mounting, etc. Ditto. | | | Re: How do you rate a one-off boat?
[Re: FasterDamnit]
#135764 03/11/08 05:19 AM 03/11/08 05:19 AM |
Posts: 1,226 Atlanta | Glad to see you got that thing bolted together.
I cant help on the rating.
Yes, to the cradles not rollers.
Rear beam risers were traditionally made for the HT out of carbon, only a handful of boats added them, the boat will slap the chop downwind, but you'll need a very short steep chop and frankly the condition that causes the slap doesnt happen that often in my opinion. If its honking out, it will happen, but under 15knots probably not very often. I wouldnt worry about it for now. Chicken lines are an easy way to deal with the slap. The Risers I've seen were made by a guy in P'cola area, Bauwman I think was his name, I probably butchered that. Anyway, carbon bolted to aluminum isnt a good idea, its a nice way to get all kinds of electron swapping. I wouldnt do it.
If you are really set on risers, call Forte RTS, order a new carbon rear beam for $400, he's got the spec's, ask him nicely for a couple of cut-offs of the same diameter and glue them on, layer on carbon cloth to taste. I can post pictures of my beam at some later point.
Bill | | |
626
guests, and 34
