Re: Nacra Hull repair [Re: Mpls_Nacra] #137655
03/27/08 10:11 AM
03/27/08 10:11 AM
After you “lace” up the line, you use the main tool with a twist on the line to tighten it past the first grommet, then you insert one of the small pieces into the grommet so the line cant slip.
Then you twist the line again (lower down the tramp) and put a peice into the next grommet. You can then remove the first peice and tighten the line again. You work your way down the tramp.
I am not sure if this makes sence, but I am sure you get the idea.
Re: Nacra Hull repair [Re: Mpls_Nacra] #137656
03/27/08 01:30 PM
03/27/08 01:30 PM
Put the tool in the lacing and twist. Plugs go from grommet to grommet. REAL simple.
Doug
Re: Nacra Hull repair [Re: ] #137657
03/27/08 01:42 PM
03/27/08 01:42 PM
Yea, what he said~!
0 registered members (), 2,236 guests, and 645 spiders.
