| How to measure VMG for your own cat #137769 03/26/08 03:16 PM 03/26/08 03:16 PM |
Joined: Jul 2006 Posts: 549 Knokke-Heist - Belgium Gilo OP
Posts: 549 Knokke-Heist - Belgium | Hi,
This year is the second year I will be sailing my Blade. Last year I had to get used to the boat (coming from a Nacra 5.0), adjusting mastrotation, downhaul, getting to know the feeling with daggerboards, etc.
After this year I kind of know what is a very bad setting and whats not, concerning rotation, daggerboards, mainsheet tension, .... but now I want to start fine-tuning that. Next to that I also want to start working on tilting the mast and working with prebend.
All of these settings should affect VMG of the boat. (for example measuring what the change in upwind angle is while tilting the mast and what the change in speed is).
My main question is now, how to measure it (I don't want this thread to be about the settings themselves). I have a Garmin GPSIII which is old but can record where and how fast we're going and I downloaded GPSAR. Is anyone familiar with that or does anyone measure this in a different way?
Regards, Gill | | | Re: How to measure VMG for your own cat
[Re: Gilo]
#137770 03/26/08 03:55 PM 03/26/08 03:55 PM |
Posts: 2,921 Michigan | not sure what GPSAR is... but I have wondered how to do what youa re talking about also. I think any GPS will show you VMG if you pick a point and "go to" it. Even the one I had in 1996 did this. My only idea is either to sail to weather and pick a point which can be seen or identified as the point when you are downwind. Mark that on your gps. go ddw and mark a spot there. Then you can have your GPS show your speed and VMG to either of those points. I have seen some GPS that will actually pick a point in a direction 2 miles away or something if you give it a bearing from where you are now. I am, in the end, too lazy to do this.
[Re: Gilo]
#137773 03/27/08 02:38 AM 03/27/08 02:38 AM |
Joined: Oct 2005 Posts: 951 Brisbane, Queensland, Australi... ncik
Posts: 951 Brisbane, Queensland, Australi... | It is a little tricky to measure VMG even with a GPS and GPS Action Replay, without some nice tools that record and correlate wind speed and angle, GPS, and boat speed data. Leeway angle, current/tide and wind shifts will make GPS data a bit inaccurate.
However if you are aware of its limitation, you can still get useful information out of it.
A very basic polar plot (atleast with the upwind and downwind VMG data) can be generated with GPSAR, but you need to clean the data (track) up a lot first. Take out all the tacks and gybes, the pre-start, and any other stuff ups. Then you need to pick a "median" wind direction that "balances" both sides of the produced polar plot.
The problem you then have is correlating the data between races, and even during a race, because we all know that the wind speed changes during a race, hence the boat speed will change and make the polar plot even less useful.
With all this in mind, take the GPSAR polar plot with a pinch of salt.
An alternative use of a GPS track is to put it into Google Earth and see how your track changes at various locations around the course. For example, seeing how land masses affect your track (variations can be caused by either wind and/or current and/or wave affects).
The "VMG" features on some non-sailing GPS units are of little use to sailing. They only give you "VMG" to a point (the one that is marked), which will change between tacks/gybes if you are far from an imaginary line that is drawn through the mark and is inline with the wind. Boat (real) VMG is measured against an imaginary line that is only drawn inline with the wind, so it doesn't matter where on the course you are, it will be the same before and after you tack/gybe (if your keep the same angle to the wind and same boat speed before and after).
Imagine you are approaching the layline with the "VMG to a point" selected on your unit and the point is the top mark. The closer you get to the layline, the slower your VMG to that point will get (the mark is getting closer to abeam (90 degrees) of your direction of travel). The instant you tack onto the layline, your VMG will equal your boatspeed exactly, which is of little use to us. | | | Re: How to measure VMG for your own cat
[Re: Rolf_Nilsen]
#137777 03/27/08 05:40 AM 03/27/08 05:40 AM |
Joined: May 2006 Posts: 954 Mumbles Y.C Wales U.K Mark P
Posts: 954 Mumbles Y.C Wales U.K | I did have a good look at Gills tracking at Zandvoort and was suprised how often Matts course changed whilst running back up the course towards Zandvoort compared to Gills. Then I remembered Gill was flying a kite and I beleive Matt had a problem and thus sailed the long run under main and jib alone. I would also agree that GPS isn't that useful a tool when it comes down to a training aid...meaning it's best used for navigational purposes but the fact that it can re-call certain data as described above can help understand where gains and losses have been made but only by comparison. MP*MULTIHULLS | | | Re: How to measure VMG for your own cat
[Re: Codblow]
#137779 03/28/08 12:13 PM 03/28/08 12:13 PM |
Posts: 396 Annapolis Md. | I have to agree with using the Velocitek units. They've been great through the years. See their ad on Sailing Anarchy. Ed
Still hazey after all these beers. F-16 Falcon #212
[Re: LuckyDuck]
#137780 03/28/08 08:48 PM 03/28/08 08:48 PM |
Posts: 1,246 Orlando, FL | okay, so where (and how) do you mount your Velocitek (pics please) so that you can see it on both tacks without manipulating the unit?
USA 777
[Re: tback]
#137781 03/30/08 10:03 AM 03/30/08 10:03 AM |
Posts: 396 Annapolis Md. | I have the older (S-10) unit that mounts on the boom with bar clamps. I don't think that unit is available anymore. The best way to mount the new unit would be the same as mounting a Tac Tic, on the spin pole about a foot or so in front of the mast. I don't know if they have the mount or if you would find that elsewhere. I would look into it more but if I go to their web site one more time I know I'll break down and buy the new model. Ed
[Re: Gilo]
#137784 03/30/08 01:40 PM 03/30/08 01:40 PM |
Posts: 3,528 Looking for a Job, I got credi... | Rolf,
I agree we should get some GPS available on the next GC. Does anyone subscribed at the moment has a GPS that can be used for tracking?
1 Mark Pressdee 2 Hans Klok 3 Simon Longstaff => YES and I'll have my laptop with Garmin mapsource and cables with me! 4 Gill De Bruyne & Kathleen Vandenbulcke -> YES 5 John & Rob Alani 6 Paul Warren & Ann Powter 7 Geert Ruesink & Joanna Lienti -> YES 8 Nick Moore 9 Gary Maskiell 10 John Terry
I guess if you make a polar diagram everytime you sail, you will get a chart that is more or less reliable after some time? And using that chart I guess you can calculate the best angle to sail upwind or downwind?
But the most interesting about a GPS is comparing the same race.
Regards, Gill
F16 - GBR 553 - SOLD I also talk sport here | | | Re: How to measure VMG for your own cat
[Re: scooby_simon]
#137785 03/30/08 04:44 PM 03/30/08 04:44 PM |
Posts: 465 Oxford, UK |
1 Mark Pressdee 2 Hans Klok 3 Simon Longstaff => YES and I'll have my laptop with Garmin mapsource and cables with me! 4 Gill De Bruyne & Kathleen Vandenbulcke -> YES 5 John & Rob Alani 6 Paul Warren & Ann Powter -> YES 7 Geert Ruesink & Joanna Lienti -> YES 8 Nick Moore 9 Gary Maskiell 10 John Terry
I also have a spare GPS data logger that I'd be happy to lend out. Paul | | | Re: How to measure VMG for your own cat
[Re: Gilo]
#137788 03/31/08 04:29 AM 03/31/08 04:29 AM |
Posts: 9,582 North-West Europe | I personally believe that that little jave applet we saw earlier is the main attraction. It is sort of a poor mans virtual spectator. Afterall halve the benefit of a global Challenge is the promo value that comes with it. Being able to follow the races second by second using GPS tracks is a huge boost to promo.
I can lend mij Garmin Geko GPS logger to Hans Klok if he doesn't have one.
Also you guys much remember to bring plenty of battery chargers and a splitter so you can devide the power output of a single walloutlet into bank of battery chargers !
678
guests, and 331
