10:1 main blocks #137827
03/26/08 05:13 PM
03/26/08 05:13 PM
california
F-18 5150 Offline OP
california
what is the easiest system for a 10:1 main sheet? im going to 10:1 from 8:1 on my tiger.
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: 10:1 main blocks [Re: F-18 5150] #137828
03/26/08 05:40 PM
03/26/08 05:40 PM
League City, TX
flumpmaster Offline
flumpmaster  Offline
League City, TX
If you have a triple with becket up top then you could use a double 40mm harken block below this and a couple of blocks on springs on the lower unit. If you have a quad up top then you can tie a 40mm block from this. If you want real easy then throw down for the 57mm 5 block and then do a search on here for various roving options.
Chris.
Re: 10:1 main blocks [Re: F-18 5150] #137829
03/27/08 06:28 AM
03/27/08 06:28 AM
Ocean Springs, MS
Capt_Cardiac Offline
Ocean Springs, MS
Here is a pic of my 10:1 mainsheet. i have a few other views I can post or send to you if you want more. The 10:1 really requires a tapered sheet since the roving is extensive however, mine moves very easily.
Capt Cardiac
Ocean Springs Yacht Club
Sailor
Nacra20 - Flight of Ideas #5
Re: 10:1 main blocks [Re: Capt_Cardiac] #137830
03/27/08 08:35 AM
03/27/08 08:35 AM
california
california
do yopu have a good pic of both blocks? im interested in how the top one is tyed in and how the bottom is set up.
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: 10:1 main blocks [Re: F-18 5150] #137831
03/27/08 12:46 PM
03/27/08 12:46 PM
SE Pa. or Chesapeak Bay
HMurphey Offline
HMurphey  Offline
You will be taking in/letting out ALOT of sheetline w/ a 10x1 mainsheet stack. I just do exercizes that strengthen my arm muscles. I have one of those "squeezie/grip" exercizers that I carry in my car. When I am driving to work I do 100 reps each hand ... on the way home I do another 100 reps ...
Let's shake hands ...
HarryMurphey
H18mag/#9458, Fleet54/Div11
P19mx w/spin /#86, CRAC
Re: 10:1 main blocks [Re: HMurphey] #137832
03/27/08 12:54 PM
03/27/08 12:54 PM
mikekrantz Offline
mikekrantz  Offline
On the F18 we went from 8:1 to 10:1 and it made very little difference in the amount of sheet that you adjust. FWIW, we never cleat the main. Pull on enough downhaul so that the main leach is soft enough to fall off in the puffs.
Re: 10:1 main blocks [Re: HMurphey] #137833
03/27/08 01:37 PM
03/27/08 01:37 PM
Note to self.... stay off the roads in Chesapeak Bay ... the drivers there are exercising
Re: 10:1 main blocks [Re: mikekrantz] #137834
03/27/08 01:48 PM
03/27/08 01:48 PM
Toronto, Ontario
pitchpoledave Offline
Toronto, Ontario
Mike, what are you using on the Infusion for spreader rake and diamond tension?
Re: 10:1 main blocks [Re: pitchpoledave] #137835
03/27/08 02:00 PM
03/27/08 02:00 PM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
Let the crew saw the main. Its not like they do any work anyways :P
Re: 10:1 main blocks [Re: ThunderMuffin] #137836
03/27/08 02:23 PM
03/27/08 02:23 PM
mikekrantz Offline
mikekrantz  Offline
I don't remember the spreader rake, whatever the setup guide was..
Diamond tension varies between 350 and 850 depending on the conditions. 550 is our base setting.
Re: 10:1 main blocks [Re: Capt_Cardiac] #137837
03/27/08 05:19 PM
03/27/08 05:19 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
The problem with putting a double on the cleat flange on this carbo lower block...you'll blow out the plastic side plates with the added loading:
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: 10:1 main blocks [Re: F-18 5150] #137838
03/27/08 05:33 PM
03/27/08 05:33 PM
here ya go....
Re: 10:1 main blocks [Re: Tornado] #137839
03/27/08 06:03 PM
03/27/08 06:03 PM
Santa Cruz, CA
SurfCityRacing Offline
Santa Cruz, CA
Here's two more versions of what I've seen for the 10:1.
Re: 10:1 main blocks [Re: F-18 5150] #137840
03/28/08 03:35 PM
03/28/08 03:35 PM
2017 F18 Americas Site
Dan_Delave Offline
Dan_Delave  Offline
I use the Stock Harken on the bottom and added a 40mm Double to the metal becket. I used to use a triple with a double on the top until it broke. Harken would not warranty it because they said I over stressed it. Now I have a 5 sheave (57mm) for the top. I use tapered lines so it will run through the blocks easier. You do not want to run the line from the cleat to one of the sides on the top. That will **** the top and make it harder to sheet. Keep the first run on one of the middle sheaves.
I have made an illustration to show how I prefer running the line: Lacing 10:1 for the Main Sheet
I do cleat the main while my crew, Eileen, uses the downhaul(16:1) to depower us when needed. If I have a guy crewing on the boat then the main cleats go up and they can muscle it to their hearts content without it cleating.
Later,
Dan
Re: 10:1 main blocks [Re: Capt_Cardiac] #137841
03/28/08 03:44 PM
03/28/08 03:44 PM
Thats one nice tapered sheet you have there... must have been $$$
Re: 10:1 main blocks [Re: PTP] #137842
03/28/08 04:19 PM
03/28/08 04:19 PM
Minneapolis
Mpls_Nacra Offline
Mpls_Nacra  Offline
Minneapolis
hey, do you have an illistration for a standard lacing? 8:1 (i think)
Dave Foster
Minneapolis
Nacra F16
Re: 10:1 main blocks [Re: PTP] #137843
03/28/08 04:40 PM
03/28/08 04:40 PM
here ya go....
Thats a 12:1 actually...
Re: 10:1 main blocks [Re: Tony_F18] #137844
03/28/08 05:04 PM
03/28/08 05:04 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
And, you may run into clearance issues if you are runnig a lot of mast rake...the distance between the upper & lower can get limiting when needing to honk on.
My current setup:
Here's some serious line tapering:
A lot of the T's now use cascaded systems running inside the boom. Uses much smaller/lighter blocks and runs freer than a non-cascade traditional setup.
here ya go....
Mike Dobbs
Re: 10:1 main blocks [Re: Tony_F18] #137845
03/28/08 05:04 PM
03/28/08 05:04 PM
yeah, sorry
skip a couple sheaves and it'll be 10:1
0 registered members (), 20,053 guests, and 1,598 spiders.
Most Online22,490
Yesterday at 08:14 AM
