Nacra F18 Mast Rotation #138150
03/28/08 05:34 PM
03/28/08 05:34 PM
Falmouth, MA, USA
RTodd Offline OP
RTodd  Offline OP
Falmouth, MA, USA
One of the rigging manuals that I've come across has the following:
"The Nacra F18 is equipped with two lines that hold mast rotation on
downwind legs when spinnaker is raised."
My boom has a jam cleat on either side, and I found one picture that shows lines running forward toward the mast from these cleats, so I assume they are part of this rotation aid. I haven't found anything yet that suggest where the lines attach to the mast. Anyone know? A picture would be even better...
Thanks,
-Robert
Robert Todd
Capricorn F18 #151
Falmouth, MA
Re: Nacra F18 Mast Rotation [Re: RTodd] #138151
03/28/08 09:16 PM
03/28/08 09:16 PM
Wilmington,NC
Dlennard Offline
Dlennard  Offline
Wilmington,NC
Robert,
The lines go from the cleat on the boom to the diamond wire turn buckle on the front of the mast. I liked to run the line through the U shackle at the top of the turnbuckle and tie a not in the end(one each side). You really do not need to use the over-rotator unless there is not much wind and a lot of chop.
0 registered members (), 641 guests, and 43 spiders.
