| Anti Pitchpole Foil measurments #138491 03/31/08 03:33 PM 03/31/08 03:33 PM |
Joined: Sep 2007 Posts: 224 Cincinnati, Ohio Tri_X_Troll OP
Posts: 224 Cincinnati, Ohio | Anyone have a pair of anti pitchpole foils? I need a couple measurements. I'm going to attempt to fabricate a pair of my own using some thin gauge stainless steel. ![[Linked Image]](http://img370.imageshack.us/img370/7782/82755353ga4.png)
Ryan - H16
I prefer to go sailing because baseball, football, tennis, and golf only require 1 ball!
| | | Re: Anti Pitchpole Foil measurments
[Re: Mary]
#138493 04/01/08 10:54 AM 04/01/08 10:54 AM |
Posts: 224 Cincinnati, Ohio | This is true, but I figured that since I can make some for less than $5, that I might try them out.
Ryan - H16
[Re: Clayton]
#138497 04/03/08 07:20 PM 04/03/08 07:20 PM |
Posts: 224 Cincinnati, Ohio | Probably true....though I wonder how sharp the ones on the catalogs are? They look to be thin steel....I could do something with a rubber strip around the edge.
Ryan - H16
[Re: Tri_X_Troll]
#138498 04/03/08 11:54 PM 04/03/08 11:54 PM |
Joined: Jun 2006 Posts: 110 Northern California, USA RyanMcHale
Posts: 110 Northern California, USA | Here are mine, Pics @ http://www.whiskeytownsailing.org/Foils.htm. They are made of 1/8” Aluminum, mounted via 3/8” solid aluminum rod, drilled and tapped for ¼ X 20 Stainless screws. Thin automotive vinyl ‘U channel’ protects the hull. And to respond to Mary’s concerns, no, they don’t make it worse, it makes it a lot better, Hobie 14’s are ‘Pitch-Pole’ machines, and mine has a full battened jib to help it be even more over powered, that and slowing down “Is Not An Option”!!! PM me if you have questions.
Ryan McHale Hobie 14 (battened jib)
[Re: RyanMcHale]
#138499 04/04/08 08:31 PM 04/04/08 08:31 PM |
Posts: 224 Cincinnati, Ohio | very nice, Ryan.
About what kind of angle do they need to be mounted at, in relation to the deck?
Ryan - H16
[Re: Tri_X_Troll]
#138501 04/05/08 06:21 PM 04/05/08 06:21 PM |
Posts: 110 Northern California, USA | very nice, Ryan.
About what kind of angle do they need to be mounted at, in relation to the deck? Ryan, I've never stuck a protractor up against them (and the boat's at the lake) I just eyeballed it, I'm guessing 25 to 30 degrees to the deck, I don't think its very critical (as long as port and starboard hulls match) as they just help you have a little more time to head up, ease the main or move weight to the rear (AKA, pay attention), any or all may help prevent you from swimming instead of sailing! What boat are you sailing, 16s are a little more forgiving than 14s. Re: Hobie 1616, Yep, managed to hit the dock one day, (yeah I know real sailors don't hit the dock!) bent the one that hit the dock, but because everything is OVER BUILT, I bent the plate back (didn't even crack the paint!!!) and no harm no foul!!! I think it's about sailing and having fun! <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
512
guests, and 601
