| Clean dirty hulls #138650 04/01/08 07:04 AM 04/01/08 07:04 AM | Anonymous
| Anonymous
Unregistered | What is a good method for cleaning the hulls prior to doing gelcoat repair/spraying?
Of course I'm going to wash them 1st but the dirt and water stains can be stuborn. | | | Re: Clean dirty hulls
[Re: ]
#138651 04/01/08 07:37 AM 04/01/08 07:37 AM |
Posts: 12,310 South Carolina | What is a good method for cleaning the hulls prior to doing gelcoat repair/spraying?
Of course I'm going to wash them 1st but the dirt and water stains can be stuborn. Sandpaper....seriously - about a 180 grit. The fresh layer of gelcoat needs a surface to grip onto. Also wipe down thoroughly with a dewaxer BEFORE sanding so you don't rub wax deep into the surface.
Jake Kohl | | | Re: Clean dirty hulls
#138652 04/01/08 08:38 AM 04/01/08 08:38 AM |
Joined: Oct 2006 Posts: 119 Bernhards Bay, N.Y. popeyez7
Posts: 119 Bernhards Bay, N.Y. | Use acetone first. If theres any wax or other stuff it won't get sanded INTO the gel coat. use plenty of acetone. Acetone,sand,acetone again, then I used a slightly damp ''white'' clean rag~rinse with water & do it again, and if ya want use acetone again, go ahead it won't hurt. If ya have serious trouble with stains, use ''ON/OFF ACID''~~ be sure to wear a good heavy rubber glove. It will burn ya, turn grass brown, smoke, and make ya Gagg!!! Thats what I did before I painted my cats... 3 of them and they look great.........I did use a 80 & 100 grit- 3 coats of paint, no grit marks.. It won't hurt to try 180 grit, see what it looks like !!!! GOOD LUCK!!
~~Don't fear the ''SPEED''~~ Fear the''ADDICTION'' ~17,18 Hobies, ~Jet boat~Speedster 150 ~2 Kayaks~ ~~~~VIETNAM VET. 69-71~~~~
[Re: ]
#138655 04/01/08 01:46 PM 04/01/08 01:46 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | If they've been waxed recently I would clean them first with FSR (Oxalic acid) or snobol( hydrochloric acid). Snobol cheaper. If it's been a year then I wouldn't worry about removing it other than washing the hulls with Dawn. I wouldn't use acetone. Old Gelcoat is pourus and the acetone will only wash the wax deeper into the surface. I would sand with 80 grit. Sprayed gelcoat covers 80 grit sanding scratches so what's the point of using finer grits?? Why work harder than you have to. Someone posted this a while back. Do some reading and pratice on something smaller before tackling the boat. gelcoating
[Re: catman]
#138657 04/01/08 02:05 PM 04/01/08 02:05 PM |
Posts: 12,310 South Carolina | I was going to provide a link to my website - Bottom Job Part 1 ... but apparently it has pooped again.
EDIT;my host is finally upgrading Team Seacats to a new server - should hopefully see some additional performance improvements....back up soon.
[Re: jswoerner]
#138660 04/01/08 04:50 PM 04/01/08 04:50 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | With respect to the hull below the waterline. The people who owned the boat before me docked it so they painted the bottom with an anti-fouling paint that is faded and has a rough texture. Since I trailer in and out I was going to sand it off and refinish and wax the bottom. Someone told me that the boat will actually go faster with a slightly rough surface below the waterline. Is this true? It won't go faster with the bottom paint you describe above. You'll be fine if you just remove the bottom paint,Etc. The bottom paint can be some nasty stuff to breath so protect your lungs from the dust.
[Re: jswoerner]
#138661 04/01/08 04:51 PM 04/01/08 04:51 PM |
Posts: 291 | Be cautious sanding anti fouling paint. Pestacides in the paint can be very harmful to you and your pants. I recomend using a stripper vs sanding. No dust that way.
EDIT:Pestacides in the paint can be very harmful to you and your PETS. Your pants will be okay either way. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
[Re: JACKFLASH]
#138662 04/01/08 05:29 PM 04/01/08 05:29 PM | Anonymous
| Anonymous
Unregistered | Try this before spending a lot of money. My H-17 had set outside for about 3 years or more of none use and had that green mold all over it. I got a $1 can of Bon Ami at local grocery store and a stiff bristle toilet brush. Made the boat look like it was brand new. Paste of it even got out rust stains!!
Try it, all you will loose it $1 plus tax.
Doug | | | Re: Clean dirty hulls
[Re: jswoerner]
#138664 04/01/08 07:51 PM 04/01/08 07:51 PM |
Posts: 1,187 38.912, -95.37 | What about yellow hulls? After removing the old stripes revealing the original color, the exposed gel has darkened. Somewhat surprising to me, guessed would be lighter/faded from oxidation. Cleaning them before sanding and/or rubbing compound, any bleach type product is a bad idea, right? Use a wax remover only?
[Re: arbo06]
#138666 04/03/08 03:38 PM 04/03/08 03:38 PM |
Posts: 60 Oklahoma City | barkeepers friend works great!!!
non abrasive to fiberglass
Gordon
Macgregor 222 Nacra 5.5sl E-Scow 1975 Hull #1
2,582
guests, and 492
