| Whisker pole? #139120 04/04/08 01:05 AM 04/04/08 01:05 AM |
Joined: Aug 2003 Posts: 241 Largo, Florida papayamon2 OP
Posts: 241 Largo, Florida | I was sailing this week and, during a noontime calm, found myself heading into a channel against an outgoing tide. The wind was so light that I couldn't make a bit of gain against the tide until I finally let out my spinnaker, much to the amusement of a nearby motor boat. At any rate, the spinnaker did the trick and got me going, although I had to hold the clew by hand out to the side over the water to get the spin to fill; otherwise, it would collapse and luff. I've been in that situation a couple of times now, and I was wondering if anyone ever uses any kind of whisker pole on a cat to hold the clew out in such cases. If so, what specifically do you use? I was thinking that something telescoping would be nice so that it could be stored easily, but I haven't happened accross the right thing yet. Of course, a good breeze is handy for holding the clew out, too, but that isn't always available...
Thanks, Kevin Trac 14 | | | Re: Whisker pole?
[Re: Keith]
#139124 04/04/08 03:44 PM 04/04/08 03:44 PM |
Posts: 291 | Wouldn't the weight pulling down of the sail be a turn off? I would think you would have to support the weight other wise it will close off the roach of the chute.
| | | Re: Whisker pole?
[Re: papayamon2]
#139126 04/05/08 12:12 AM 04/05/08 12:12 AM |
Posts: 851 US Western Continental Shelf | Try this. Remove the mainsheet from the boom so that you can force the boom all the way out to the shroud. Fasten that boom to the shroud. (works far better if you have a square toped main sail!)
Now the main will be blocking the jib. Furl the jib. (or wing and wing it, using the tiller stick as a whisker pole, IF going dead down wind)
Don't use the paddle as a whisker pole; instead, use the paddle to propel the boat. (elbow grease) The paddle works far better as a paddle than as a whisker pole.
That's my emergency approach to ultra light weather.
GARY
Santa Monica Bay Mystere 6.0 "Whisk" <--- R.I.P. | | | Re: Whisker pole?
[Re: papayamon2]
#139127 04/05/08 07:20 AM 04/05/08 07:20 AM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | I think you should just head up a little to keep the sail flying and gibe a couple more times. I don't think I would try the fishing pole. The last thing you want is a sudden shift snapping the pole which could result in body or boat damage.
746
guests, and 173
