Page 3 of 3 1 2 3
Re: F16 info for light weight crew [Re: PTP] #140137
04/20/08 01:35 PM
04/20/08 01:35 PM
I have sailed the blade 1-up in those conditions. Maybe on purpose 1/2 of that time. It is amazing how easily you can depower it and go. I max downhaul, limit rotation, drop trav about 6-10 inches. prepare to swim on gybes though <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
If you re-center the traveler and make a point to gybe through a smaller arc, I think you'll swim less. It seems to work for me.
we've talked about this alot... my impression is keeping it centered all the time during a gye really runs the risk of rounding you up hard though...
In the end... whatever works!!
". . .gybe through a smaller arc," If you end the gybe dead down wind, with the main sheeted in and the travel centered, it's almost like being head to wind.
Re: F16 info for light weight crew [Re: fin.] #140138
04/21/08 04:38 AM
04/21/08 04:38 AM
Tornado_ALIVE Offline
Agreed.... A must.
Re: F16 info for light weight crew [Re: Tornado_ALIVE] #140139
04/21/08 04:05 PM
04/21/08 04:05 PM
Hamburg
Smiths_Cat Offline
Smiths_Cat  Offline
Hamburg
I will be on the water this weekend and forecast predicts pretty much the same conditions, however we have not the high waves.
Week-end is over <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" />. We had fantastic weather. Sunshine, blue sky and on-shore winds. Bit cold for the more sensitive fellows. But the wind was not that strong as predicted. Saturday was 4-5Bft with gusts in 6, but we took the T. When I took the Javelin on Sunday it was something like 12kts and some gusts reported to be 18kts with some old swell. That is a bit 'disappointing' if you expect something close to 20. For sure it is better to start sailing a new boat this way, but I was mentally adjusted to danger.
I had the impression that the boat could handle even more wind. Downwind the boat is a blast (well it felt like that, not much out there to compare those days) with and without the hooter. It indicates nose-diving early, and I actually never stuffed it that day. Due to the high mast and the short hulls, I expected some bad behaviour in waves, but it didn't (as long as you keep longitudinal trim). Only problem was, that all the sheets are to long, the trampoline looked then chaotic and I was trailing some of them most of time.
Hope you had great sailing as well.
Cheers,
Klaus
Re: F16 info for light weight crew [Re: Gato] #140140
04/24/08 12:42 AM
04/24/08 12:42 AM
Central California
ejpoulsen Offline
ejpoulsen  Offline
Central California
I am located in San Jose, CA.
Can you define "very windy conditions" ?
30 knots in Santa Cruz. Photo attached from before the wind got extreme.
For somebody whit the sea as profession, that doesn’t look 30 knots at least not on the photo. The sea surface looks different at 30 knots.
And a small thing but important, it’s no good to speak about being out in +25 knots on a forum where people whit very different skills are reading the posts. There is no difference what craft you are sailing, when the wind gets up to 30 knots things change and everything gets more difficult. So at least my point of vu is that there is no need to give the Coast Guard more job than they have by announcing to unskilled sailors that it’s safe to take a craft out in 30 knots.
You're right. At the time of the photos the conditions were at about 12 knots. That's why I wrote, "Photo attached from before the wind got extreme." Later on in the day conditions got much more brisk with whitecaps and wind chop on top of the sea swell--all the typical things you'd expect for "sea state." The windward mark for the races was a sea buoy out in the middle of Monterey Bay with a wind meter, and gusts of 30+ knots were recorded. It was not fun, but my point was that the boat can deal with it. The racing was curtailed and we came in.
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Page 3 of 3 1 2 3
