Outboard motor for cat #140315
04/17/08 03:49 PM
04/17/08 03:49 PM
Slovenia
I
igorn Offline OP
igorn  Offline OP
I
Slovenia
have a question, will be this 2,5 HP four stroke motor enough for fx one and 2 adults+ 4 yo child onboard ?
yamaha motor
Re: Outboard motor for cat [Re: igorn] #140316
04/17/08 03:55 PM
04/17/08 03:55 PM
I want to put an electric outboard on my Blade F16 when it is done. Why would you want a petrol engine? Silent, efficient, clean and low maintenance electric outboards seems like a much better option unless you are going long distances.
Depending on what you want, I think a 2.5HP should be enough to get respectable speed out of your boat under motor. The 5HP I had on my lapstrake 16 foot launch when growing up was a good choice and a FX1 is far easier driven and much lighter.
Re: Outboard motor for cat [Re: Rolf_Nilsen] #140317
04/17/08 04:11 PM
04/17/08 04:11 PM
Slovenia
I
igorn Offline OP
igorn  Offline OP
I
Slovenia
i was looking for electric , but you need a big batery ,and they are kind of weak, or am wrong?
Re: Outboard motor for cat [Re: Rolf_Nilsen] #140318
04/17/08 04:13 PM
04/17/08 04:13 PM
Why on earth would you put an outboard on a high performance cat?
Re: Outboard motor for cat [Re: igorn] #140319
04/17/08 04:36 PM
04/17/08 04:36 PM
Atlanta
bvining Offline
bvining  Offline
Atlanta
Why on earth would you want a motor on a 16ft beach cat? I can understand putting a motor on a 27-30ft cat, but not on a F16.
How about a couple of decent paddles?
Re: Outboard motor for cat [Re: bvining] #140320
04/17/08 04:53 PM
04/17/08 04:53 PM
Maybe a sculling oar? Works back and forth from the transom.
Re: Outboard motor for cat [Re: igorn] #140321
04/17/08 04:53 PM
04/17/08 04:53 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
Not sure why you need any motor on a sailing cat...with just over a knot or two of breeze the motor will be dead weight!
But, that size motor is more than enough for pottering around a harbor. We've got a special project craft made out of a SuperCat 19 platform with over 600 lbs of weight on it that we power using a 2 Hp fourstroke Honda. Runs around the harbor very nicely. And we don't have boards/rudders...motor mounted off of one transom...yet the craft still steers quite well just by turning the outboard.
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: Outboard motor for cat [Re: Tornado] #140322
04/17/08 05:08 PM
04/17/08 05:08 PM
Slovenia
I
igorn Offline OP
igorn  Offline OP
I
Slovenia
sorry if i ofendet any one.i dont like the idea of motor on sailing boat (this size)
but have a son is 3 1/2 years old and must think safty over everythink else. on the see i must first take my wife and son to a mile distant shore (sand and wather 20 -150 cm of deph) and then i can go sailing all day <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Re: Outboard motor for cat [Re: igorn] #140323
04/17/08 05:11 PM
04/17/08 05:11 PM
Re: Outboard motor for cat [Re: Tony_F18] #140324
04/17/08 05:57 PM
04/17/08 05:57 PM
Some people have to traverse a long, narrow channel to get to the open water, and a small motor can be a big help.
We used to live on a canal, and with a Laser I could tack up or down the channel, but it would have been difficult with a cat. Paddling or sculling would be preferable, but probably not doable for me with a stiff headwind.
Re: Outboard motor for cat [Re: Tony_F18] #140325
04/17/08 06:23 PM
04/17/08 06:23 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
My PT had paddle friendly dagger boards. Steering with my foot and paddling at a sustainable rate I would travel about as fast as a kayak.
This is an image of a man out on an old boat of mine.
He is with his young son.
He was traveling substantial distance and the outboard was effective and little problem.
Re: Outboard motor for cat [Re: Tony_F18] #140326
04/17/08 06:27 PM
04/17/08 06:27 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
This image is of an old boat of mine I ran into out in the isalands.
The guy had a 3/4 year old son with him and was covering long distance.
This boat was designed 30 years ago by some German dude and home built.
He and his partner did big miles in the med for weeks at a time. It has big hatches.
This young man said the motor was a great addition and he had no trouble with it.
Re: Outboard motor for cat [Re: warbird] #140327
04/17/08 06:30 PM
04/17/08 06:30 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
Also, here is another image of the boat showing the alli outboard bracket. A simple weld and hey presto.
BTW. I would not want the hassle of batteries out in the wet.
Re: Outboard motor for cat [Re: warbird] #140328
04/17/08 07:46 PM
04/17/08 07:46 PM
Atlanta
bvining Offline
bvining  Offline
Atlanta
I can understand Mary needing a motor to get out of a narrow channel, but Igor, a small electric motor isnt going to do squat if the weather comes up and you've got a 3 year old on board. I've got a 6 year old and a wife that prefers the beach, and we dont go out as a family unless its perfect, flat water, under 10 knots, tide going the right way. If you get the 3 year old and wife in some weather, they wont want to sail with you no matter how big a motor you put on the cat.
Bill
Re: Outboard motor for cat [Re: bvining] #140329
04/17/08 07:56 PM
04/17/08 07:56 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
Still can't quite equate having a motor with making the cat safer.
If it is rough enough to need to drop the sails fully and motor...then it is too rough to even be on the boat in the first place. A motor will not help in those conditions.
If having no wind is the concern, then take a paddle or two. Cat's more quite well while paddled. Also take a marine radio for emergency calls.
Mike Dobbs
Re: Outboard motor for cat [Re: Tornado] #140330
04/17/08 08:01 PM
04/17/08 08:01 PM
TeamChums Offline
TeamChums  Offline
Ok, I fess up. On my old H21se I had an outboard on it for going to the islands (Catalina and such). When you are coming back accross through shipping lanes, it really helps when you have no wind. I had to leave Catalina once at 5 am to get to Marina Del Ray with no wind we made 6-7 knots the whole way on the motor alone. It was a 2hp Honda.
Lee
Lee
Re: Outboard motor for cat [Re: TeamChums] #140331
04/17/08 09:21 PM
04/17/08 09:21 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
The 2 HP Honda's are a great little motor. Very simple design and easy to rebuild if a friend gets flipped going over the reef and lets it sit for two months before asking why it's seized up.
He gave it to me and $150 later I've got a great motor to use with the junior sailors.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Outboard motor for cat [Re: hobie1616] #140332
04/18/08 12:29 AM
04/18/08 12:29 AM
Slovenia
I
igorn Offline OP
igorn  Offline OP
I
Slovenia
i never dare to go out with my son if the weather is not PERFECT !
i need a motor because the wind is dead in the evening and i dont want to padle after all day sailing , call me lazzy, but whean am on vacation with fammily this little trip is priority (if i want peace) and then i can do what ever i want.
Re: Outboard motor for cat [Re: igorn] #140333
04/18/08 01:24 AM
04/18/08 01:24 AM
That is exactly the thing Igorn. I want an outboard on the boat to be able to use it as a regular motorboat. In my case I want to take the family over to some small islands just outside the club on quiet summer days. Paddling with the wife onboard is simply not an option and neither is relying on wind. The days we are going to do this will be days with no or very little winds. Less than 1m/s.
With a small outboard the platform can be used for a lot more than "only" sailing.
Re: Outboard motor for cat [Re: warbird] #140334
04/18/08 04:50 AM
04/18/08 04:50 AM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
I would also call your attention to this attachment. Check in front of the port main beam.
That is a hatch cover...hinged..part of the boat. About the size of an average chilly bin.
This boat went like stink on a reach and was good enough on all points of sail yet it had heaps of buoyancy and easy storage etc etc.
The fact is we don't give enough though to multi-use in cats.
1 registered members (Damon Linkous), 2,534 guests, and 340 spiders.
