Free to good home #141434
04/28/08 04:57 PM
04/28/08 04:57 PM
Atlanta
bvining Offline OP
bvining  Offline OP
Atlanta
I'm cleaning out the basement. Anybody need some beachcat wheels. These came with the HT and I modified them to fit the Acat, so they are Acat width now.
Re: Free to good home [Re: bvining] #141435
04/28/08 05:18 PM
04/28/08 05:18 PM
I wish you lived in Ohio. <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" />
Re: Free to good home [Re: Mary] #141436
04/28/08 05:25 PM
04/28/08 05:25 PM
Atlanta
bvining Offline OP
bvining  Offline OP
Atlanta
Sorry, I dont live in OH.
And they have been claimed.
Re: Free to good home [Re: bvining] #141437
04/28/08 06:22 PM
04/28/08 06:22 PM
Orlando, FL
tback Offline
tback  Offline
Orlando, FL
Don't need the wheels ... how about the hockey skates!
USA 777
Re: Free to good home [Re: tback] #141438
04/28/08 07:58 PM
04/28/08 07:58 PM
Lake Murray SC
FasterDamnit Offline
Lake Murray SC
Crap. Yes. But not at the current shipping rates...
Re: Free to good home [Re: FasterDamnit] #141439
04/28/08 08:06 PM
04/28/08 08:06 PM
Panama City, Florida
Redtwin Offline
Redtwin  Offline
I'll take the case of Smirnoff Ice!
Rob V. Nacra 5.2 Panama City
Re: Free to good home [Re: FasterDamnit] #141440
04/28/08 08:07 PM
04/28/08 08:07 PM
bill should post his recipe for homemade beach wheels once every couple months. I cooked up a set last year and they work well.
Re: Free to good home [Re: bvining] #141441
04/28/08 08:52 PM
04/28/08 08:52 PM
2017 F18 Americas Site
Dan_Delave Offline
Dan_Delave  Offline
Yes! I will pay the shipping.
Dan DeLave
ddelave "at" aol "dot' com
Re: Free to good home [Re: PTP] #141442
04/29/08 02:53 AM
04/29/08 02:53 AM
Netherlands
DennisMe Offline
DennisMe  Offline
Netherlands
Do you have a link somewhere, I'm very interested in DIY beach wheels! Especially ones with a proven track record!
Re: Free to good home [Re: bvining] #141443
04/29/08 07:29 AM
04/29/08 07:29 AM
Looks like you need to have a fire sale on shoes too! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: Free to good home [Re: DennisMe] #141444
04/29/08 07:44 AM
04/29/08 07:44 AM
hopefully bill has the recipe, I can't find it. The only "hard" part is making the cradles but you can use large PVC pipe or use casting material (water activated fiberglass) coated with epoxy resin molded directly on the hulls.
Re: Free to good home [Re: PTP] #141445
04/29/08 08:05 AM
04/29/08 08:05 AM
water activated fiberglass casting material? Is that something from the medical industry (bet that's not cheap unless it's a job related subsidy).
You can easily mold cradles directly to you hull by turning the boat over, covering with plastic sheeting (to protect the hull), laying on carpet, then laying on fiberglass and resin. If you want to get really fancy, you can form up some clay or similar to support the carpet to form a lip shape around the edges.
Re: Free to good home [Re: Jake] #141446
04/29/08 08:12 AM
04/29/08 08:12 AM
yeah, I like that- job related subsidy <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
probably not cheap I guess (I just checked, 3x15 roll 150$ or so. the problem is that it has medical written on it somewhere. remove that word and the price drops by half I am sure)
Makes me wonder though about some type of mesh that can be used for the same purpose- but much much thicker than the standard glass cloth. I wonder how many layers of glass you could put together and wet out in one "pour"
The benefit of the standard beach wheels is that their cradles are very big and therefore don't pinch the hulls if you don't put them under the hulls directly straight. If the molded cradles aren't made somewhat wider and flared then you easily dent the skin (on lighter boats) just putting the wheels under. The HT cradles that came with the boat were brutal in the regard.
Re: Free to good home [Re: PTP] #141447
04/29/08 08:24 AM
04/29/08 08:24 AM
Depends on the resin used. If you use a good laminating polyester resin, you can probably lay out 10 layers of glass - no problem. Cheap Bondo brand resin, one or two layers tops (it will twist / warp with more so you have to gradually do layers at a time). With decent epoxy, you can do 10 layers no problem.
You could lay in towels or some other foam padding to give the additional room needed under the carpet for wider cradles. All it takes is a little tape to hold it in place.
0 registered members (), 391 guests, and 295 spiders.
