Re: Stealth [Re: johnfullerton] #141753
05/07/08 07:34 AM
05/07/08 07:34 AM
BEWARE!
527 and 528 and quite possibly all Stealth prior to around 540 will not have the acetyl inserts built in.
On my boat the solution was these:
They are plastic plasterboard (wallboard) inserts and I have epoxied them into the deck area. The straps are then simply screwed in using S/S 3mm self tappers.
Re: Stealth [Re: Jalani] #141754
05/07/08 01:14 PM
05/07/08 01:14 PM
US Western Continental Shelf
hobiegary Offline OP
Great foot strap information! I'll figure a way to add backing, even if I have to fish it in from the drain holes!
One way I am considering is to drill a hole, use an alan wrench to rout out the foam, and fill that with expoxied filler. Then use a plastic drywall toggle bolt that will span a portion of this filled area. Glenn Brown suggested this.
I guess that I could take a piece of backing that would be longer than the footstrap and narrower than the drain holes and pull it into position with strings. I could pre coat it with a bead of glue and tension the strings as a glue clamp. I could drill and tap holes, even before fishing it into position.
Here is a list of owners of Stealths that I have seen on Catsailor Forum:
scooby_simon 553
waynemarlow
MarkP
Jalani (John Alani) GBR527
John_Pierce
hobiegary
davidtugwell (Datchet)
MarkP (Mark Presdee) (Mumbles) GBR555
George_Malloch (Scotland)
johnfullerton (Geneva, Switzerland) 551
WesternJeff (South West UK) 545
Dermot (Dermot Mangan) (Dublin, Ireland)
Paul Warren (Datchet) used to own one
GARY
Santa Monica Bay
Re: Stealth [Re: hobiegary] #141755
05/08/08 04:45 PM
05/08/08 04:45 PM
UK
sssh Offline
sssh  Offline
UK
Hi
I have Stealth 556 based in the UK Midlands. I sail on Rutland Water the largest man made lake in Europe. Great sail this weekend at Bala in Wales. Winds 3knts gusting 33knts. Some effort needed.
John Terry F16 Stealth 556
Re: Stealth [Re: sssh] #141756
05/08/08 05:21 PM
05/08/08 05:21 PM
Hi
John,
I hear that Bala was "fun". Should see you at Rutland in a few weeks time.
Re: Stealth [Re: hobiegary] #141757
05/09/08 05:32 AM
05/09/08 05:32 AM
Dublin, Ireland
Dermot Offline
Dermot  Offline
Dublin, Ireland
'Fraid I'm a Spitfire Gary. (and a Shadow on order). There is one Stealth in Northern Ireland.
Dermot
Catapult 265
Re: Stealth [Re: Dermot] #141758
05/09/08 12:03 PM
05/09/08 12:03 PM
Scotland
George_Malloch Offline
Scotland
I have 502 which gets sailed at Port Edgar in Scotland, more or less underneath the Forth Bridges.
Stealth www.peyc.org.uk
Re: Stealth [Re: hobiegary] #141759
05/09/08 12:39 PM
05/09/08 12:39 PM
12
Re: Stealth [Re: hobiegary] #141760
05/09/08 12:42 PM
05/09/08 12:42 PM
scooby_simon 553
waynemarlow
Jalani (527 John Alani)
John_Pierce (aka john_p)
hobiegary (Gary) (528 Los Angeles, USA)
MarkP (Mark Presdee) (555 Mumbles)
johnfullerton (551 Geneva, Switzerland)
WesternJeff (545 South West UK)
sssh (John Terry) (556 UK Midlands, Rutland Water)
George_Malloch (502 Port Edgar in Scotland)
Alan_T (Alan Thomas) (North Kent England)
aaronyoung (London, UK) - Now sailing Tornado
Re: Stealth [Re: Jalani] #141761
05/10/08 06:20 AM
05/10/08 06:20 AM
couldn't resist it
Codblow Offline
Codblow  Offline
couldn't resist it
Its a Stealth , albeit 18 with enlarged f16 rig (not much )
0 registered members (), 11,351 guests, and 422 spiders.
