| Re: Nacra 5.5... general thoughts
[Re: BarePoles]
#142446 05/08/08 08:57 AM 05/08/08 08:57 AM |
Posts: 6,049 Sebring, Florida. | I had one, loved it. If it's in good shape and cheap, buy it! Or tell me where it is so I can buy it. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> Look closely at the bridal foil bar, be sure it has not been bent, check all the stainless fittings for rust and the wires for frays and rust. Check the dagger board wells for cracks at the back of the board slots on the hull bottoms. If they ran it aground at speed, there could be isses there. Does it come with a trailer and beach wheels? Check the mainsail at the outhaul track (boomless rig) see if it is pulling away from the sail too. Mine did that and I had to spend about $250 to get it fixed.
They are great boats, you can race them single handed with the main only if you like. They did have a Uni class for many years.
Blade F16 #777
[Re: Timbo]
#142447 05/08/08 09:16 AM 05/08/08 09:16 AM |
Posts: 10 | Thanks for the thoughts. I'm going by to have a look at it today to get an estimate on repairs. It does have a jib and a spin so that is a plus. Keep the thougts coming.
Dumb question, whats the bridal foil bar?
[Re: BarePoles]
#142448 05/08/08 09:49 AM 05/08/08 09:49 AM |
Posts: 6,049 Sebring, Florida. | The bridal foil bar is to spread the loads when carrying the jib, it gets the foot of the jib down lower without pinching the bows in too much. If your is a converted 5.5 Uni, it may have the Uni set up as well, which was more like an A cat, twin forestays up to a higher point. If the boat has been in saltwater for years your biggest fear will be corrosion. Look at all the metal parts closely, especially on the mast.
Blade F16 #777
[Re: BarePoles]
#142450 05/08/08 10:12 AM 05/08/08 10:12 AM |
Posts: 3,293 Long Beach, California | As the 1996 Nacra 5.5 National Champion crew, I am a bit biased - I loved the boat and miss the class. It was a well-balanced evolution of the 5.2 and could be driven very hard for its size and volume.
Check the sterns - they require periodic refinishing. Otherwise, all the typical used boat shopping stuff applies. If it is solid, you'll be happy with the purchase. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
[Re: ghhm43]
#142452 05/09/08 08:26 PM 05/09/08 08:26 PM |
Posts: 10 | Thanks for the info. I went and looked at the boat yesterday it looks pretty good except for one area. The aft port ama inspection port has been smashed and caused some fiberglass damage right around it, so i'm gonna have to do a little repair on it but otherwise looks solid.
Does anyone have any detail shots of the rigging of the boat, for I've never rigged a 5.5? Anything will help. Thanks.
[Re: DryUV]
#142455 05/10/08 10:45 AM 05/10/08 10:45 AM |
Posts: 6,049 Sebring, Florida. | I would think that with some small amount of tweaking you could even fit it into the F18 rule.
Blade F16 #777
[Re: Timbo]
#142456 05/10/08 07:28 PM 05/10/08 07:28 PM |
Posts: 10 | I would think that with some small amount of tweaking you could even fit it into the F18 rule. Intersting. What sort of things would need to be done? Sails? Other adjustments? Thanks. | | | Re: Nacra 5.5... general thoughts
[Re: BarePoles]
#142457 05/10/08 08:43 PM 05/10/08 08:43 PM |
Posts: 6,049 Sebring, Florida. | The standard Nacra 5.5 jib is too big for the F18 rules. You would need a F18 legal jib, spin and get a F18 main and boom to start to be competitive with them. Then add the jib self tacker.
If you could find an older Nacra F18 that had busted hulls, you could buy the entire rig/sails and transfer it to the 5.5, you might save some money over buying a new F18, it that's what you want to do. Or, just keep it and play with it until you decide you want a F18 (or something else), sell it and buy the next toy. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Blade F16 #777
[Re: BarePoles]
#142459 05/11/08 09:14 AM 05/11/08 09:14 AM |
Posts: 6,049 Sebring, Florida. | The Nacra 5.5 Sloop is a great boat -as is- and will give you a great fast ride. I used to sail mine solo without jib and then with another adult male my size, 190lbs. x 2, it has a wide range of useability. It is a great boat in high wind too.
Once you get comfortable with it, if you want to add a spinnaker, that will take you to the "next level" of cat sailing. But you don't need a spinnaker to have a good time on it as is. Adding a spinnaker will cost you money of course, ($1,000?) and add complexity and rigging time. If you can find someone who has spinnaker experience that will show you how to rig it properly, and sail it with you a few times, that will help a lot. If you have a place where you can leave it mast up, spin. pole mounted, etc. that will save you time and make it much quicker to get out on the water.
If you are going to race it in the Open Portsmouth class, forget the spinnaker for now, unless you are doing a long distance race with a downwind leg.
Blade F16 #777
[Re: BarePoles]
#142461 05/11/08 02:48 PM 05/11/08 02:48 PM |
Posts: 6,049 Sebring, Florida. | Hey, maybe it's my old boat, what color is the spinnaker? Mine was a yellow and purple Smyth huge spin. It had a multi colored main with number 465 I think. It was a 1994 if I remember right. Where did you find it?
Blade F16 #777
[Re: BarePoles]
#142463 05/11/08 06:07 PM 05/11/08 06:07 PM |
Posts: 6,049 Sebring, Florida. | The number should be on the transom of the starboard hull, unless there has been work done in that area. Someone else can tell you how to decipher the number, I have forgotten...
Blade F16 #777
14,964
guests, and 652
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online16,046 Yesterday at 04:24 PM | | |
