mast question #144730
06/03/08 08:12 PM
06/03/08 08:12 PM
M
mitch Offline OP
mitch  Offline OP
M
somebody with some tech knowledge please illuminate: how much does a main halyard that goes over the top and cleats at the mast base cause compression, how much of a problem is this, can it or will it break the stick? Locking the halyard at the top is tough on some boats, reefing is a problem etc. the Hobie 21sc just cleats at the base... with new nonstretch line is the simple halyard cleat at the base a viable option? thanks for input
Re: mast question [Re: mitch] #144731
06/03/08 09:45 PM
06/03/08 09:45 PM
Cincinnati, Ohio
Tri_X_Troll Offline
Tri_X_Troll  Offline
Cincinnati, Ohio
I don't know much about the ones that cleat at the base of the mast, but the ones that cleat at the top usually have a second slug for reefing. At least the older H16's did when they still had reef points.
I know I wouldn't trust the cleat at the base of the mast on my 16. It just seems very flimsy.
Re: mast question [Re: mitch] #144732
06/03/08 10:53 PM
06/03/08 10:53 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
I used New England 1/4" V100 as the main hlyd on my SC20, cleated off at the base. It would stretch a bit in the 1st 10 min, I'd release the dnhl, tighten the main hlyd again, and I'd be good for the day. Need a serious cleat(Schaefer jam cleat?) solidly attached. Preferably one fastener into the cast aluminum base)drill and tap?). Also need a solid sheave at the masthead because it'll be under a lot of pressure. I never perceived any issues with the compression, but the SC extrusion is pretty beefy.
Dave
Re: mast question [Re: davefarmer] #144733
06/04/08 01:55 AM
06/04/08 01:55 AM
Netherlands
DennisMe Offline
DennisMe  Offline
Netherlands
If I understand Newton's law (I'm always forgetting which one) it is that every action has an equal and opposite reaction.
I figure that means it makes no difference for compression where you cleat the main halyard. The loads on the halyard are no different, the mast must therefore provide the equal and opposite reaction. The only things I can see this affecting is mast top cleats will reduce halyard stretch and may help induce mast bend particularly in combination with rotation (but I'm not really sure on that).
Dennis
Re: mast question [Re: DennisMe] #144734
06/04/08 02:17 AM
06/04/08 02:17 AM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
On a mast with the sail hooked at the top, the halyard line is unloaded during sailing...so the main luff is the only force making compression on the mast...and most of that is from the downhaul force.
Now if you run a base cleat instead of the top hook, now you've got two forces acting to make mast compression...the loaded halyard and still the sail luff. Input force is still primarily the the downhaul, but you get 2:1 purchase (halyard + luff) compressing the mast.
The extrusion can easily take this, assuming you've got reasonable diamonds and don't get crazy with >16:1 downhaul purchase. Biggest concern will be the top sheave & it's mount pin...not usually designed for these kind of loads.
The base cleat needs to handle at least as much force as you can put on the downhaul line..plus some margin for gusts, etc.
Mike.
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: mast question [Re: mitch] #144735
06/04/08 06:55 AM
06/04/08 06:55 AM
It doubles. If you pull 100 pounds on the luff of a sail that is hooked at the top, you get 100 pounds of compression on the mast. If you pull 100 pounds on the luff of a sail where the halyard freewheels at the top and is cleated at the base, you get 100 pounds of compression from the sail luff and from the halyard = 200 lb of compression no the mast.
It still baffles me how the monohull world has yet to catch up to this novel concept (except for the America's Cup boats).
Re: mast question [Re: mitch] #144736
06/04/08 01:46 PM
06/04/08 01:46 PM
Asuncion, Paraguay
Luiz Offline
Luiz  Offline
Asuncion, Paraguay
The attached picture might help.
Luiz
Re: mast question [Re: mitch] #144737
06/04/08 02:08 PM
06/04/08 02:08 PM
Hamburg
Smiths_Cat Offline
Smiths_Cat  Offline
Hamburg
I am pretty sure, that the mast of most beach cats can handle the doubled load. But on some lightweight constructions (e.g. Acat) I would be careful.
However the luff tension acts not only as compression force on the mast, it bends it backwards as well, an effect which is normally desired. With a conventional halyard you will roughly double the bending for the same amount of downhaul tension, hence the leach will open more than usual, or with the same twist (leach opening), you will have less downhaul and with that a fuller sail. But maybe this aspect is of a lower importance if you don't sail races.
Cheers,
Klaus
Re: mast question [Re: Jake] #144738
06/04/08 03:44 PM
06/04/08 03:44 PM
Atlanta
bvining Offline
bvining  Offline
Atlanta
How would you propose to hook and unhook a fixed (non rotating) monohull mast? I suppose you could rig some sort of a trip line, to a mechanical catch at the top of the mast, but that seems more complex than a halyard to hold the sail up.
Bill
Re: mast question [Re: bvining] #144739
06/04/08 03:57 PM
06/04/08 03:57 PM
you could utilize a claw and bead system similar to the hobie16...
Re: mast question [Re: bvining] #144740
06/04/08 04:09 PM
06/04/08 04:09 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
There is s solution for hooking a mainsail without requiring rotation.
The simple cable with stopper system used on a lot of dinghy jib setups could be beefed up to hold the main. These use a catch fitting that the stopper engages in. The problem is how do you un-catch it when needing to drop sail?
Well, we use a locking box with an interesting geometry on Afterburner...the halyard is pulled through the box until a swaged on stainless slug passes into the box...then drops into a notch & locks in place. To disengage, we apply more tension to the halyard, pulling the slug further through the box until it clears the notch. It is now unable to re-engage in the notch as we release the halyard.
This exact same design lock fittng is downsized and used on Marstrom Tornado forstays for jib halyards.
Bill
Mike Dobbs
Re: mast question [Re: Tornado] #144741
06/04/08 04:54 PM
06/04/08 04:54 PM
claus Offline
claus  Offline
I would guess that the mast bending characteristics should be more or less in accordance with the load on the luff/halyard. If you modify the system, the mast will be bent back less or more, probably not desireable? Also, if the halyard is not in a rail (for example an a H16 you would have to run it outside the mast), if the mast is bent back, the distance from top to bottom gets shorter and thus the halyard tension would decrease.
Re: mast question [Re: ] #144742
06/04/08 06:12 PM
06/04/08 06:12 PM
Cincinnati, Ohio
Tri_X_Troll Offline
Tri_X_Troll  Offline
Cincinnati, Ohio
If I recall, the C-Scow uses a system similar to that of the hobie 16
Re: mast question [Re: bvining] #144743
06/04/08 06:27 PM
06/04/08 06:27 PM
Bill
Who said the mast shouldn't rotate?
Re: mast question [Re: Jake] #144744
06/05/08 06:55 AM
06/05/08 06:55 AM
Atlanta
bvining Offline
bvining  Offline
Atlanta
I'm not saying they shouldnt, I'm saying they usually dont.
Re: mast question [Re: Tornado] #165073
01/15/09 07:02 PM
01/15/09 07:02 PM
Los Angeles, CA
chrisun Offline
chrisun  Offline
Los Angeles, CA
I like this system. Works well. Easy to engage and disengage.
However, there was an interesting point made about compression on the sheave. Unfortunately this system does not unload the sheave when it is engaged. The halyard still carries the load over the halyard sheave.
C-Class USA75
