Need Instructions on the use of an EZ Step #145020
06/06/08 05:30 PM
06/06/08 05:30 PM
North of Los Angeles, Californ...
M
marshall Offline OP
marshall  Offline OP
M
Turns out I have a EZ Step device in the Catbox, when I recently brought home the P16 I bought.
This will hopefully solve my concern about being able to step my mast by myself!
I've seen the illustration on the sales ads for it, both on this site and Murray's. Now I know why I have a hand winch on my trailer, under the mast support.
But I really need the instructions (prefer scanned or PDF), so I'll know how and where to put the various straps and such.
Does anyone have the instructions? It'd be much appreciated.
My Prindle 16 is my first Cat and sailboat.
Thank you!
Re: Need Instructions on the use of an EZ Step [Re: marshall] #145021
06/07/08 09:59 PM
06/07/08 09:59 PM
Severna Park, MD
mmurphy384 Offline
mmurphy384  Offline
Severna Park, MD
I hate to be a downer, but I had one of those when I purchased my first catamaran (Hobie 16). I would have saved myself a whole lot of time by making arrangements to have a friend join me for all mast stepping ceremonies. I hope someone else can divulge the secret to making it work.
Eventually, I did my own one-man mast stepping system that worked well, though involved a little muscle.
Picture this:
Do whatever you can to remove anything that will cause any lines to catch (as in . . . leave the rudders off).
Get that mast attached to whatever ball/step you have in place and attach your side-stays. Attach your trap lines, but pull the ends off to the sides so they don't get in the way.
In the ideal world, you'd grab the forestay with your bear hands and lift it up. Simple, right? That's obviously not going to happen.
Here's where it gets a little tricky. Picture yourself getting to a piont where you're standing on the tramp, you have the mast started on it's way up and you have it resting comfortably (well. . . .) on your shoulder. The next thing you would wish for is some kind of line in your hand that runs toward the front of the boat, loops around the bridal (or preferably a block mounted on the trailer) and up to the forestay base.
Once you have the mast on an angle, you can start to pull on that magical line and heave all the way up. It gets easier with every foot of line you reel in. Oh . .. make sure you're wearing some gloves.
Things get a little dicey once you have the mast up . . . think about it . . becuase you have the mast all the way up . . . you're on the tramp . . . . and you would love it if someone were to walk by that could hook up the forestay. Well . . that might not happen. Instead, you have to tie off that line (perhaps around the base of the mast. . use a knot you can trust).
Next, grab one of those trap lines and walk up to the bridle/forestay area. Give a good tug on the trap line, release the forestay and hook it up to the bridle.
At this point, you should say a little prayer to someone that you didn't hurt yourself, anyone else and didn't damage your boat or any other local structures.
This isn't for the weak at heart or if your around any living soul. I wouldn't consider myself an expert, but I've done it a few times and it did work out ok (on a Hobie 16). Also, if it's at all windy, don't even try it. But then again, why would you be sailing a catamaran if it isn't windy???
You could do all of the above .. . . or . .. . just make sure a friend meets you to step the mast. That's the only EZ Step I know of.
Good luck.
Boatless and happy.
Re: Need Instructions on the use of an EZ Step [Re: marshall] #145022
06/08/08 07:34 AM
06/08/08 07:34 AM
Dunedin Causeway, FL
David Parker Offline
Here's the instruction book.
Take the time to set the lines up correctly and practice a few times. You'll find this works great and adds about 7 minutes to your mast-up time, all solo.
However, the P16 mast is light. Just push it up. Do a search on this topic and read the posts about towing your boat sterns first. This makes solo-stepping very easy. I've got some photos if you'd like.
EZ Step instructions in PDF
147527-EZStepper.pdf (19 downloads)
0 registered members (), 4,553 guests, and 295 spiders.
