Nacra 18 mast feet ? #145175
06/09/08 05:11 AM
06/09/08 05:11 AM
E
Erwankerauzen Offline OP
E
Hi Everybody
For those who are interest in fitting their own boat, I wonder if it is possible to adapt the Nacra F18 footmast on
other mast.
The tension system for the "diamond"/ spreaders is a quite similar of what was done by Greg Goodall years ago on his A-Cat, and it was clearly the smartest, lightest, cheapest solution. In addition it seems that you can adjust tension more easily, with only one bolt under the mast.
Has anybody a photo of the tension system inside, or has anybody already adapt such a footmast on another mast section ?
Thank you in advance & good wind
Regards
Erwan
Re: Nacra 18 mast feet ? [Re: Erwankerauzen] #145176
06/09/08 01:31 PM
06/09/08 01:31 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
I think that you mean Nacra Infusion not F18
If you modify a mast, remember that the mast must be re-sealed above the exit point of the diamond wires or it will fill up!
0 registered members (), 377 guests, and 35 spiders.
