Wind thing with boardless cat? #1455
08/07/01 11:13 AM
08/07/01 11:13 AM
Québec, Canada
CharlesLeblanc Offline OP
Québec, Canada
Yesterday, I tried a few times to do the wild thing with my boardless boat, an old Nacra 5.7.
<br>
<br>The wind was about 12-15 knots and the crew weight was about at 420.
<br>
<br>Needless to say, we are now very good at righting the boat!!!
<br>
<br>Question is it possible to do it with a boardless boat. It seems that each time that I was holding it for a few minutes, we would end up in the water: as soon as the winward hull was higher than 4-6 feet, I could not head down because my rudder was cavitating
<br>
<br>I had my crew sitting on the leward hull and I was sitting in the middle of the tramp. We were heading into a beam reach, ifting the hull and heading down slowly. The speed seemed to be much better than a normal downwinf hull. My bridle fly was pointing at close to 90deg to the boat.
<br>
<br>My mast is raked alot and I have a fairly strong weather helm but I did compensate the pull by raking my rudders forward to have a very slim pull. I am also thinking about decreasing the mast rake to have something more neutral.
<br>
<br>Anyways, at least the water was good
<br>
<br><br><br>Charles Leblanc [color:blue] Nacra 5.7 #123 </font color=blue>
1415- (27 downloads)
Charles Leblanc Nacra 5.2 #26
Re: Wind thing with boardless cat? [Re: CharlesLeblanc] #1456
08/07/01 11:47 AM
08/07/01 11:47 AM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
Try sitting further back to prevent the leeward bow from sticking in. Wild thing should not be a problem since on the Tornado, we pull the boards up while off wind and these boat likely invented the wild thing. It's tricky to master and capsizing is a real risk, but that's why it's the wild thing :)<br><br>Mike Dobbs
<br>Tornado KC 283 "Double Mint"
1417- (20 downloads)
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: Wind thing with boardless cat? [Re: Tornado] #1457
08/07/01 01:51 PM
08/07/01 01:51 PM
4 to 6 ft? You should have the windward hull just barley kissing the top of the chop. Since the crew is counter balancing your ability to get the hull back down is hindered. The hull out of the water at lower position means more speed.<br><br>
1421- (19 downloads)
Re: Wind thing with boardless cat? [Re: CharlesLeblanc] #1458
08/07/01 01:57 PM
08/07/01 01:57 PM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
A long time ago there was an article in the Sailing World (I think) that maintained the best advantage doing the wild thing was gained by boats that had good hull bouyancy. The premise was that sinking the one hull deep by raising the other ate into benefits of raising the hull in the first place (at least with respect to downwind sailing and the angles involved, etc.). The article was an analysis piece on hull designs used in the Little Americas Cup. Just an aside, not really answering your question, and maybe a point of interest for folks who were asking the same regarding Hobie-16s. It would seem the overall hull shape is more important than the simple fact of boardless-ness. I'd guess a 5.7 should do fine in wild thing mode.<br><br>Keith Chapman, Annapolis, Md.
<br>H-18
<br>Northstar 500 (monoslug)
<br>WRCRA - www.wrcra.org
Re: Wind thing with boardless cat? [Re: CharlesLeblanc] #1459
08/07/01 06:21 PM
08/07/01 06:21 PM
sail-s Offline
sail-s  Offline
At the Trapseat national several teams did the wild thing on their H16's with Trapseats. Those doing the Wild Thing (or a mild Wild Thing) made better time down wind than those who did not do the Wild Thing.
<br>
<br>
1426- (23 downloads)
Re: Wind thing with boardless cat? [Re: CharlesLeblanc] #1460
08/08/01 01:09 AM
08/08/01 01:09 AM
On my H16 I was able to do the wild thing once. I was never able to do it again after though.
<br>
<br>David<br><br>
1435- (18 downloads)
Re: Wind thing with boardless cat? [Re: CharlesLeblanc] #1461
08/08/01 08:23 AM
08/08/01 08:23 AM
Houston
carlbohannon Offline
Houston
The 6.0 with the boards up should be similiar and I don't have any problem.
<br>
<br>Part of the problem is the boomless main. Try setting your mainsail traveler to the upwind position, travel out about halfway and sheet in hard. If the boat pops up quickly travel out until the windward hull comes up slowly.
<br>
<br>Also you might try practicing in calm water. Anything over 2 foot chop and you will have a hard time telling if the problem is the waves or the boat <br><br>
1444- (17 downloads)
Re: David Why Only Once? #1462
08/08/01 03:25 PM
08/08/01 03:25 PM
sail-s Offline
sail-s  Offline
David - "On my H16 I was able to do the wild thing once. I was never able to do it again after though."
<br>
<br>David WHY only once?
<br>
<br>I do the Wild Thing regularly on my H16. So I am just wondering why you have only done it once.<br><br>
1464- (19 downloads)
Re: David Why Only Once? [Re: sail-s] #1463
08/08/01 03:43 PM
08/08/01 03:43 PM
Driver problems, not boat problems. It worked that one time, and I never seemed to get it to work before or after that. That and I only had the H16 for a year before I got a N5.8. If I went back to the H16 I am sure I could wild-thing it better.
<br>
<br>David<br><br>
1465- (19 downloads)
Re: Wind thing with boardless cat? [Re: carlbohannon] #1464
08/08/01 05:57 PM
08/08/01 05:57 PM
Québec, Canada
Québec, Canada
Thank you for the positive comment
<br>
<br>I can summarize by something like: Driver error, try to practice more.
<br>
<br>Just a few explaination:
<br>
<br>We did do it for a few hundred yards at the time but we capzised every time because my rudders would cavitate when I tried to head down once the windward hull would get higher than 4-6 feet. I was trying to balance the cat to about 1-2 feet above the water.
<br>
<br>Water was calm, 1-2 feet chop, nothing much. The wind was a bit unstable but nothing to justify the capsize
<br>
<br>I will decrease my rake on the mast to try to decrease the weather help. This should give me a few more degrees of safety before they start cavitating.
<br>
<br>Now I am only waiting for some ind to try it again
<br>
<br>Thank you again for all of the comments.<br><br>Charles Leblanc [color:blue] Nacra 5.7 #123 </font color=blue>
1473- (21 downloads)
Re: Wind thing with boardless cat? [Re: CharlesLeblanc] #1465
08/08/01 08:14 PM
08/08/01 08:14 PM
Arkansas, USA
Kirt Offline
Kirt  Offline
Arkansas, USA
Charles-
<br>Do you have the ORIGINAL 5.7/5.0 rudders? NACRA upgraded the rudders in late 80's or early 90's and made them larger- should help. Also, as an old 5.0 sailor I would agree with the comment to have your crew weight BACK- getting the bows more or less out of the water and the rudders IN the water. My 5.0 used to get kind of "squirrelly" in heavy air downwind due to the great effect on center of lateral resistance (CR) when the boat heals (as in a puff) when the CR would suddenly move from it's "normal" position forward as the bow dug in and the rudder and skeg came out of the water! Once I knew it was coming and tended to do that I just dealt with it. But to do the "Wild Thing" effectively you have to be able to control the boat well since you are basically "balancing" it, similar to flying a hull upwind and unless you can turn quickly and with (relatively) little drag IMO it won't pay off playing the rudders. I would never try it on my old P 18 with stock rudders since they cavitate at speed downwind going mild!
<br>What you MIGHT try would be to get the hull flying and play the MAINSAIL rather than the rudders (or have you crew do so) having the crew ease the traveler in and out slightly to balance the boat while you keep the rudders more or less straight.
<br>I KNOW this isn't "How you are supposed to do it.", but those "rules" were written by sailors on board boats!
<br>Let me know if/how it works!
<br>
<br>Kirt<br><br>Kirt Simmons
<br>Taipan #159, "A" cat US 48
1478- (18 downloads)
Kirt Simmons Taipan #159, "A" cat US 48
Re: Wind thing with boardless cat? [Re: Kirt] #1466
08/09/01 07:00 PM
08/09/01 07:00 PM
Québec, Canada
Québec, Canada
Hi Kirt,
<br>
<br>I have the big rudders and I tried the mild thing today because I had no crew available.
<br>
<br>Under the mild thing, once I pick up speed, I can feel that my rudders have a pull on them. Moving farther back did help to sink the rudders and they seems to respond better.
<br>
<br>I still have to change the mast rake to try to decrease the weather helm and try again to see how it affects my ability to steer the boat on a run.
<br>
<br>Thank you for the comment<br><br>Charles Leblanc [color:blue] Nacra 5.7 #123 </font color=blue>
1512- (16 downloads)
Re: Wind thing with boardless cat? [Re: CharlesLeblanc] #1467
08/13/01 04:14 PM
08/13/01 04:14 PM
Long Island, NY
Ed Norris Offline
Ed Norris  Offline
Long Island, NY
Dear Charles,
<br>Sorry I missed you last month; I got up to Vermont and didn't have your contact info w/me!!!
<br>Just a thought on your helm problem; is your rig at all loose? Seems to me, (and I hope the *real* sailors out there will instruct me here!!) that a loose rig, off the wind, will induce more-than-usual weather helm, by shifting forward *and* leeward, moving the CE somewhat leeward, too, which might contribute to weather helm, no? Also, what's your jib doing in all this, can you firm it up some w/out backwinding your main?
<br>
<br>I repeat my invite to you to come down to Great South Bay. My fold out sofa is always available to a fellow catsailor wishing to try 15kts all day every day.
<br>
<br>Regards,
<br>Ed<br><br>
1588- (20 downloads)
Sail Fast, Ed Norris
Re: Wind thing with boardless cat? [Re: Ed Norris] #1468
08/14/01 12:00 AM
08/14/01 12:00 AM
Québec, Canada
Québec, Canada
Hi Ed,
<br>
<br>Nice to hear from you.
<br>
<br>My rig is very tight. I should loosen it because in my case, a very tight rig doesn't give me anything more.
<br>
<br>My weather help is because my mast is raked all the way back. I will rig a way to mesure the angle of attack of my rudders while I am sailing but from the informations in CATAMARAN RACING IN THE '90, I really think that I am already running with a 3-4deg angle
<br>
<br>As far as balancing the CE, with the mast raked all the way back and the sails tuner OK, my CE is behind my CLR and is trying to rotate the boat into the wind. I am simply waiting for another day with normal wind because last time that I was out, we had difficult condition with 3-4feet chop and wind in the 25knot range with gusts.
<br>
<br>On the day of the wild thing attempt, we had the jib was not too tight because we were trying to get the main running very well and I did not want to risk stalling the main. The main was a bit tight and the jib was a bit more open. The slot was looking OK but the problem was really than when balancing the boat on one hull, the boat would sometine hike too much and I then could not get the boat to head down. The boat would head down with less hike but with more hike it simply did not work.
<br>
<br>Anyways, I will try again soon and tell you about it
<br>
1593- (18 downloads)
Re: Wind thing with boardless cat? [Re: CharlesLeblanc] #1469
08/14/01 04:59 PM
08/14/01 04:59 PM
Long Island, NY
Ed Norris Offline
Ed Norris  Offline
Long Island, NY
Okay, Charles, I get it now...
<br>I only mention the jib 'cause, I sometimes forget to sheet it in a little, off the wind, as the apparant wind moves forward. It's kinda a toss up; on the one hand, a hard jib induces lee helm, or reduces weather helm, but on the other, it contributes to burying the bow, which, as you point out, lifts your rudders.
<br>
<br>Like you, I"m a great believer in Rick's logic, regarding CLR/CE and weather helm... in Cat Racing For the 90's, he mentions that, although some truely fast skippers don't agree with him, he feels that on symetrical hulled boats, weather helm is far less valuable than on asymetrical hulled boats, and the drag of the rudders through the water may quite likely make any weather helm a bad thing in symetrical hulled boats.
<br>
<br>I really see his logic clearly when he suggests to look at your crossbar to see if if is centered when the boat is going to weather. Regardless of the "feel" of the tiller, if the ruders aren't straight, then you've got drag, and should adjust your ce/clr accordingly. Rick makes it sound so obviuos!!!
<br>
<br>Good luck with your next attempt, Charles, I wish I could fly along with you!!!<br><br>
H-16 wild thing [Re: sail-s] #1470
08/15/01 01:47 PM
08/15/01 01:47 PM
Connecticut
Eric Anderson Offline
Connecticut
I am not a Hobie 16 sailor. However, I have had plenty of chances to watch Wally, Cliffy, BobO, Susie Kortz, Dan K and others. I have never observed any of them wild thinging downwind on a Hobie 16.
<br>
<br>I have observed most of them wildthinging on Hobie 20's, Inter 20's and tigers. Since the above dudes constitute very good H 16 sailors, I doubt that others are wildthing successfully if the best 16 sailors are not.
<br>
<br>Eric<br><br>
Re: H-16 wild thing [Re: Eric Anderson] #1471
08/15/01 03:02 PM
08/15/01 03:02 PM
I still maintain that I DID do it once. The wind was right, the waves were small, and the stars and moon lined up correctly...
<br>
<br>David
<br><br><br>
1649- (16 downloads)
Re: H-16 wild thing [Re: Eric Anderson] #1472
08/20/01 02:59 PM
08/20/01 02:59 PM
sail-s Offline
sail-s  Offline
Your Comment Eric: I have had plenty of chances to watch Wally, Cliffy, BobO, Susie Kortz, Dan K and others. I have never observed any of them wild thinging downwind on a Hobie 16.
<br>
<br>You have not been to a Trapseat event then, because the top Trapseat sailors do the Wild Thing quite often. I do not watch Wally and those guys so I would not know about them. As a matter of fact the first time I ever saw someone do the wildthing on a cat (H16) was at the Trapseat Nationals in Redding California at Wisky Town Lake. When I saw them doing the wildthing I went around asking other sailors why they were lifting one hull while sailing down wind. Still on the H16 I think it is more of a mildthing than a wildthing but same principal.<br><br>
1787- (18 downloads)
Re: Wind thing with boardless cat? [Re: Kirt] #1473
09/04/01 01:23 PM
09/04/01 01:23 PM
Charles,
<br>I have to agree with Kirt. On my N5.0, in 20 knots, I'm far less worried about time loss due to rudder drag, than from time loss due to righting the boat. We have found that at lower wind speed the N5.0 can be heeled effectively and sailed fast the mild or wild thing way, but in higher wind, it helps to move back,and keep the bows up and out of the water a bit. I've also found that sheeting in the main/and or jib slightly , while steering down, prevents that squirrly steeringand cavitation whereby you lose the steering completely, and practice righting the boat again. Sheeting in slightly seems to decrease the heeling force which seems to occur when the sails are made fuller. Any thoughts?
<br>
<br>Harold<br><br>
Re: Wild thing with boardless cat? #1474
09/04/01 01:58 PM
09/04/01 01:58 PM
Québec, Canada
Québec, Canada
Hi Harrold,
<br>
<br>Thank you for the suggestion "sheeting in the main/and or jib slightly , while steering down, prevents that squirrly steeringand cavitation "
<br>
<br>I used to do that when I was windsurfing but I have not really used it while riding my cat.
<br>
<br>I am getting a chance to put my boat back in the water next week, If it works, I will try it again.
<br>
<br>My main concern was that my rudders were cavitating and it was really the first time that I experienced that. Now, with all the discussions, I will decrease my mast rake and play with the main a bit more.
<br>
<br>I really like to keep the main sheet tight, I will probably decrease the tension just a bit and play with the traveller. I will ease the mainsheet tension just in order to help the traveler to move more freely.
<br>
<br>The problem is that used to be sailing in the Mississiquoi Bay of Lake Champlain and I will be sailing in the St-Laurence gulf in very cold water. I will still try it but only on fairly warm days (no need to run after trouble)
<br>
<br>Also, I will probably put my chute back on the boat so the wild thing might not be as interesting as before.
<br>
<br>I wanted to learn the wild thing because my previous sailing location has many fast boats like the P19, P18-2, Mystere 6.0 and Hobie20 and I am always looking for new ways to keep up or pass them<br><br>Charles Leblanc [color:blue] Nacra 5.7 #123 </font color=blue>
2240- (15 downloads)
0 registered members (), 19,133 guests, and 1,208 spiders.
Most Online22,490
13 hours ago
