| Re: Shackles? Can someone advise me.
[Re: dacarls]
#147796 07/03/08 10:54 PM 07/03/08 10:54 PM |
Joined: Sep 2007 Posts: 224 Cincinnati, Ohio Tri_X_Troll OP
Posts: 224 Cincinnati, Ohio | When I upgraded to the 6:1, I found that the bottom block wouldn't fit in the traveler and I had to add the shackle......Do I need to upgrade my traveler? I'd really be happy with some of these, if I could find them anywhere. I could buy the standard "D shackles" ....... was hoping to just find the cheap stamped ones and buy a couple spares. The problem is that I haven't been able to find them. Oh well. I guess I'll just order some of the standard D-Shackles. What's $16 for a couple. ![[Linked Image]](http://i19.photobucket.com/albums/b161/Tri_X_Troll/Boat/DSC01902.jpg)
Ryan - H16
I prefer to go sailing because baseball, football, tennis, and golf only require 1 ball!
[Re: Tri_X_Troll]
#147797 07/04/08 07:03 AM 07/04/08 07:03 AM |
Posts: 1,884 Detroit, MI | When I upgraded to the 6:1, I found that the bottom block wouldn't fit in the traveler and I had to add the shackle......Do I need to upgrade my traveler? The older, larger Harkens have a post that's a bit too wide for the top plate of the traveller car. Either grind a flat on either side of the post (doesn't take much), or open up the "ears" on the top plate a bit with a couple of pairs of pliers. Make it fit. You do not want a shackle on the lower end of the main sheet. This is what comes with the boat on the top: ![[Linked Image]](http://img.alibaba.com/photo/200363102/PLATE_BOW_SHACKLE.summ.jpg) | | |
284
guests, and 65
