mainsheet #148015
07/03/08 09:35 PM
07/03/08 09:35 PM
Central California
ejpoulsen Offline OP
Central California
What would any of you recommend for a new mainsheet?
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: mainsheet [Re: ejpoulsen] #148016
07/03/08 09:55 PM
07/03/08 09:55 PM
Trey Brown. <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
Re: mainsheet [Re: ejpoulsen] #148017
07/03/08 10:01 PM
07/03/08 10:01 PM
Salsa, been two years now on the H16, Rick's right, great stuff.
Re: mainsheet [Re: _flatlander_] #148018
07/04/08 07:40 AM
07/04/08 07:40 AM
virginia beach, VA
dsltrc Offline
dsltrc  Offline
virginia beach, VA
just don't forget the chips <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Jason DiPietro supercat 19
Re: mainsheet [Re: _flatlander_] #148019
07/04/08 07:43 AM
07/04/08 07:43 AM
Salsa on the H-17
Bzzz on the H-16
Swiftcord on the Tiger
Marstron on the H-14
I like the Salsa best - after it's broken in a bit (too slippery when new)
Bzzz is a close 2nd.
Swiftcord is nice, but $$$ and it wears too fast.
Marstron is cheap, hard on the hands and wears out way too fast.
Re: mainsheet [Re: ejpoulsen] #148020
07/04/08 10:47 AM
07/04/08 10:47 AM
Mark P Offline
Mark P  Offline
I can sell 8mm Maffioli Evolution Swiftcord at £3.50/m converting to $6.94 Thats a really competitve price here in the UK as it normally retails at around the £4.15 mark. How does that compare to your US prices?
MP*MULTIHULLS
Re: mainsheet [Re: Mark P] #148021
07/04/08 07:11 PM
07/04/08 07:11 PM
Annapolis Performance Sailing
8 mm Swiftcord: $2.01 / ft = $6.50 / m
Cheaper if you get it from their sale bin.
Re: mainsheet [Re: mbounds] #148022
07/05/08 10:19 AM
07/05/08 10:19 AM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
Robline racing sheet.
Best stuff ever.
Re: mainsheet [Re: mbounds] #148023
07/05/08 11:35 PM
07/05/08 11:35 PM
Issaquah, WA, USA
H17cat Offline
H17cat  Offline
Issaquah, WA, USA
Switched to 5/16" Salsa on my H-17. Works great, after two regattas. West Marine, about $1.00 ft.
Caleb
Re: mainsheet [Re: H17cat] #148024
07/06/08 12:56 AM
07/06/08 12:56 AM
Central California
Central California
Thanks for all the input so far.
I like the looks of several material mentioned and I'll need to handle them to decide.
What about diameter?
3/8" or 5/16"?
8mm or 9mm?
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: mainsheet [Re: ejpoulsen] #148025
07/06/08 02:18 AM
07/06/08 02:18 AM
Hamburg
Smiths_Cat Offline
Smiths_Cat  Offline
Hamburg
Hi all,
is there any rational reason, why a main sheet should contain dyneema?. On large boats with winches I understand it, but on a beach cat... Diameter would be around 8mm or more and you will not pull with more than 50kg on it, which is 1/30 of the breaking load of a simple polyester 8m sheet. Stretch would be about 8%*1/30 = nothing, you will sail it anyway from the hand and not cleated... So why dyneema <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />
I use simple plain 8m polyester, it doesn't kink, holds in the cleat and on the ratchet, but it doesn't look Gucci.
What about the spi sheet? Here I looked around for the lightest stuff for 8mm diameter and not water absorbing. I found 8mm life line (the yellow - red stuff), easy to splice, light and with 0.70€/m also cheap.
Is there any other property of dyneema (other than strngth and low stretch)?
Cheers,
Klaus
Re: mainsheet [Re: Smiths_Cat] #148026
07/06/08 06:16 AM
07/06/08 06:16 AM
Light weight, low water absorbancy.
Polyester soaks up water like a sponge.
Re: mainsheet [Re: Smiths_Cat] #148027
07/06/08 06:29 AM
07/06/08 06:29 AM
Hobart, Tasmania, Oz.
Dazz Offline
Dazz  Offline
Hi all,
Cheers,
Klaus
Bear in mind most mainsheets are 8:1 or even 10:1 so your 50 kilo's now equals 400-500kilo's.
On a two man boat where the crew has 2 hands to use (and legs), you may see more like 100x8 kilo's!
C2 AUS 222 by Goodall design
"Darph Bobo"
Re: mainsheet [Re: H17cat] #148028
07/06/08 07:31 AM
07/06/08 07:31 AM
RickWhite Offline
RickWhite  Offline
Caleb
Ouch! West Marine? What about www.OnLineMarineStore.com right here on this site?
As for size, since Salsa is so easy on the hands I use 1/4" (6mm) on the Wave and F16.., really runs through the blocks easy. I would never go to 3/8" though,
Rick
Rick White
www.onlinemarinestore.com
Re: mainsheet [Re: RickWhite] #148029
07/06/08 08:33 AM
07/06/08 08:33 AM
Dazz Offline
Dazz  Offline
"Darph Bobo"
Re: mainsheet [Re: RickWhite] #148030
07/06/08 01:56 PM
07/06/08 01:56 PM
Santa Cruz, CA
SurfCityRacing Offline
Santa Cruz, CA
Ouch! West Marine?
Rick
6mm Salsa from Online Marine Store is $.97 per foot.
https://store.catsailor.com/pc/viewPrd.asp?idcategory=550&idproduct=15783
From Big Box Marine it's $1.15
http://www.westmarine.com/webapp/wcs/sto...;classNum=11452
This is just one small example of how your little guy can save you some dough on your sailing parts. I'm surprised more people haven't learned this yet.
Re: mainsheet [Re: Dazz] #148031
07/06/08 02:41 PM
07/06/08 02:41 PM
Hamburg
Smiths_Cat Offline
Smiths_Cat  Offline
Hamburg
Hi Dazz,
on a non-cascading system the sheet load is never higher than the input load. The 8x or 10x load is at the shackle of the blocks.
In terms of weight and adsorbed water, it is probably in the order of a few hundred gramms. On a spi sheet, this is an argument of course. However PP material is even lighter (at same diameter) than pure dyneema, doesn't take water as well, so for a spi sheet PP should be the material of choice?
Cheers,
Klaus
Re: mainsheet [Re: RickWhite] #148032
07/06/08 02:50 PM
07/06/08 02:50 PM
Issaquah, WA, USA
H17cat Offline
H17cat  Offline
Issaquah, WA, USA
Ouch! West Marine?
Sorry Rick. I needed it right away, it was available and on sale in Seattle.
Caleb
Re: mainsheet [Re: H17cat] #148033
07/06/08 07:57 PM
07/06/08 07:57 PM
Dazz Offline
Dazz  Offline
My Bad.
Its a distrubuted load, there may be 400 kilo's of load on the rope, but its shared by 8 peices of rope.
The biggest selling point for me, as rick has pointed out is the texture.
can anyone bring up http://www.onlinemarinestore.com/ for me its a dead stick.
"Darph Bobo"
Re: mainsheet [Re: mbounds] #148034
07/08/08 11:21 AM
07/08/08 11:21 AM
brucat Offline
brucat  Offline
Salsa on the H-17
Bzzz on the H-16
Hey Matt,
Can you elaborate on the differences that make one line better for one boat model than another?
1 registered members (FredL), 343 guests, and 59 spiders.
