| Re: Spinnaker boat, lee helm
[Re: Rhino1302]
#148733 07/08/08 12:37 PM 07/08/08 12:37 PM |
Joined: May 2002 Posts: 1,037 Central California ejpoulsen
Posts: 1,037 Central California | It seems to me that the N20 rudders are smaller than the 5.8 rudders. Very different shape, though. I'd be more inclined to give the N20 rudders a try than the 5.0 rudders.
I'll have to start playing with the daggerboard settings. I would guess leaving them down will produce more lee helm, but help get the windward hull out of the water. Are you referring to the original or newer N20 rudders? The original are much slimmer than the later ones.
[Re: Rhino1302]
#148735 07/08/08 01:12 PM 07/08/08 01:12 PM |
Posts: 12,310 South Carolina | Didn't know that there were two designs. The only N20 I've seen in person is Dave Spain's boat, which I think is fairly old. There are actually three different I20 rudders: The original "pin head" The "butterknife" (which came on boats for only three or four months - but was common on '04 and '05 F18s) The "spade" - current fat, clover leaf looking rudder blade.
Jake Kohl | | | Re: Spinnaker boat, lee helm
[Re: Rhino1302]
#148737 07/08/08 03:14 PM 07/08/08 03:14 PM |
Posts: 1,037 Central California | Didn't know that there were two designs. The only N20 I've seen in person is Dave Spain's boat, which I think is fairly old. Spain's are generation 1, the narrow ones.
[Re: ejpoulsen]
#148738 07/08/08 03:16 PM 07/08/08 03:16 PM |
Posts: 12,310 South Carolina | Didn't know that there were two designs. The only N20 I've seen in person is Dave Spain's boat, which I think is fairly old. Spain's are generation 1, the narrow ones. I still prefer those rudders - they do stall but because they are sensitive to proper sail trim...you can learn a little by learning to keep them from stalling.
#148739 07/08/08 03:34 PM 07/08/08 03:34 PM | Anonymous
| Anonymous
Unregistered | how do you tell when a rudder stalls? | | | Re: Spinnaker boat, lee helm
[Re: ]
#148740 07/08/08 04:00 PM 07/08/08 04:00 PM |
Posts: 1,152 tampa, fl | you move the tiller and nothing happens! <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" />
If your havin girl problems i feel bad for you son I got 99 problems but my beautiful wife ain't one | | | Re: Spinnaker boat, lee helm
[Re: ksurfer2]
#148741 07/08/08 04:03 PM 07/08/08 04:03 PM |
Posts: 5,590 Naples, FL | you move the tiller and nothing happens! <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" /> And your crew yells "W T F" as you careen out of control... Usually happened to me when reaching too hot with the spin up and trying to drive down too quickly..
[Re: ]
#148742 07/08/08 04:25 PM 07/08/08 04:25 PM |
Posts: 12,310 South Carolina | how do you tell when a rudder stalls? You feel it - it's pretty dramatic...you turn and the only thing that happens is a really huge rooster tail at the back of the hulls. With it blowing about 12 to 15, sail upwind and try to bear away sharply without easing the mainsail and observe the stalling. Do this on a crowded start line trying to duck a boat and observe the odor coming from your crew's shorts. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> If you're really cooking - like downwind with the chute up in waves, you can feel the rudders start to lose traction if you turn too sharply.
#148743 07/08/08 06:14 PM 07/08/08 06:14 PM |
Posts: 1,037 Central California | If you're really cooking - like downwind with the chute up in waves, you can feel the rudders start to lose traction if you turn too sharply.
...and you're heading for a spinout--been there done that.
[Re: ejpoulsen]
#148744 07/08/08 07:26 PM 07/08/08 07:26 PM | Anonymous
| Anonymous
Unregistered | | | | Re: Spinnaker boat, lee helm
[Re: ejpoulsen]
#148745 07/09/08 12:30 AM 07/09/08 12:30 AM |
Posts: 1,459 Annapolis,MD | Our gen 1 rudders would loose it upwind in waves. Very annoying. Take a wave, then rooster tales and no helm. Step to the back of the boat, goof a little with the main sheet, they recatch and you retrim.
We're using the gen 3 rudders right now. So far I like them. They change the feel of the boat, it is far less twitchy than before. They haven't cavitate/ventilated yet, but we haven't yet hit the right conditions. Whether they are as fast is always the question in the back of our minds, but so far I don't have any hard evidence that they aren't. | | | Re: Spinnaker boat, lee helm
[Re: Rhino1302]
#148746 07/09/08 03:23 PM 07/09/08 03:23 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | Instead of grinding why don't you just use a spacer under the top gudgeon, washers or a delrin block. ( move the top back ). This way you can play around with rake easily. You can also re-drill the piviot hole.
[Re: catman]
#148747 07/09/08 03:36 PM 07/09/08 03:36 PM |
Posts: 308 Reno NV | Instead of grinding why don't you just use a spacer under the top gudgeon, washers or a delrin block. ( move the top back ). This way you can play around with rake easily. You can also re-drill the piviot hole. The spacer might be a good idea, it never occured to me. It would tilt the tiller arms up, though, which might cause a problem. I don't think the pivot hole can be moved, not enough meat in the casting. | | | Re: Spinnaker boat, lee helm
[Re: Rhino1302]
#148748 07/09/08 04:01 PM 07/09/08 04:01 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | I have re-drilled mine and your right the farther back you move the head the less support there is. However the Nacra 6.0 rudders I have are built quite strong. I have experimented with a few different rudder types in the Nacra castings and have ripped all of them off. Each time I put the old 6.0 rudders back on and go sailing.
Alum. rudder arm are very easy to adjust (bend) down once you find the rake your looking for.
[Re: catman]
#148749 07/09/08 07:35 PM 07/09/08 07:35 PM |
Posts: 12,310 South Carolina | Instead of grinding why don't you just use a spacer under the top gudgeon, washers or a delrin block. ( move the top back ). This way you can play around with rake easily. You can also re-drill the piviot hole. But if you put spacers under the top pivot block, you're not changing the relationship between the rudder's center of lift and the pivot axis - the distance from the center of lift of the rudder and the pivot axis is what changes the load on the helm. Since this geometry would stay the same, it would have no affect on the helm since you're just angling the whole assembly.
#148750 07/10/08 11:27 AM 07/10/08 11:27 AM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | But if you put spacers under the top pivot block, you're not changing the relationship between the rudder's center of lift and the pivot axis - the distance from the center of lift of the rudder and the pivot axis is what changes the load on the helm. Since this geometry would stay the same, it would have no affect on the helm since you're just angling the whole assembly. I'm not so sure that's right. Here's how I see it. With the boat level and rudder down, measure half way up the rudder pin make a mark. Now with a level held vertically at that point draw a line down the rudder. Now space the top gudgeon and use the level again. I think you'll find there is more blade in front of the mark on the rudder pin. You have moved the center of the pivot point back in relation to the blade and the blade forward so a little goes a long way. If that doesn't make sense then I'll go by the fact that Robbie's T is set up that way. <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" />
#148752 07/10/08 03:02 PM 07/10/08 03:02 PM |
Posts: 921 Alachua, FL | There are several dynamics involved here. Traditionally moving more foil area ahead of the pivot makes the boat feel less heavy on the helm up to the point where it gets too sensitive and squirrely. I’m not sure if that really changes the relationship of airborne and waterborne forces very much.
Think of a windsurfer where raking the sail forward or aft accomplishes the steering. There is a perfect place where everything is balanced and the boat (board) goes straight, with no helm pressure at all. I would think that this is what you are trying to achieve by changing mast rake. The placement of underwater foils plays into this equalibrium.
Both ways of moving the rudder accomplish the same when figuring points of lateral resistance. Tilting the pivot shaft with shims at the transom will not affect rudder balance and sensitivity. Sensitivity is what comes from tilting the blade forward or aft of the pivot point.
Of course mast rake also affects other things, such as the slot and sail angle of attack which may have a greater impact on absolute boat speed and ability to point.
What does Wouter say?
Jack Woehrle Hobie Wave #100, Tiger Shark III HCA-NA 5022-1 USSailing 654799E Alachua FL/Put-In-Bay | | |
439
guests, and 28
