| Re: Changing the stays or trap wires
[Re: Timbo]
#149493 07/27/08 06:29 PM 07/27/08 06:29 PM |
Posts: 9,582 North-West Europe | Simple answer is.
Use wire for the stays and diamonds, synthetic line is just practical here/
But use lines for the trap-lines. There is absolutely no reason not the use line here. Cheaper, lighter, simpler, less wear on the batten pockets and safer (can be cut in emergency)
[Re: Smiths_Cat]
#149494 07/27/08 06:42 PM 07/27/08 06:42 PM |
Joined: Jun 2004 Posts: 502 Port Noarlunga, SA, Australia Darryn
Posts: 502 Port Noarlunga, SA, Australia |
a plastic cover to protect the sail.
Sticky back sailcoth on the batten pockets where the stay rubs works fine for this, replace when it gets worn through which is every year or so for me. Elasticity in side stays while sailing is just wrong, might as well go back to cotton sails. Darryn Mozzie 1782 | | | Re: Changing the stays or trap wires
[Re: Darryn]
#149496 07/28/08 09:15 AM 07/28/08 09:15 AM |
Joined: Mar 2005 Posts: 322 South Australia Marcus F16
Posts: 322 South Australia | Sticky back sailcoth on the batten pockets where the stay rubs works fine for this, replace when it gets worn through which is every year or so for me. The 3M gunnal non slip is also good for protecting the batten pockets & last quiet a few years
Marcus Towell
[Re: Marcus F16]
#149497 07/31/08 07:44 AM 07/31/08 07:44 AM |
Posts: 186 Chattanooga, TN | I talked to Mike Krantz at Layline, and he felt that line for the traps was OK (his word) but that for the stays unless you go with the carbon stuff ($$$$) then he felt there is just to much creep. I have to believe that he would know since he could use any line he wanted on his F18 or A cat and still has wire on them. So for now think will stick with wire.
Jody
Jody
Blade F16 724
Plays with Sharp Objects
[Re: jody]
#149498 07/31/08 08:33 AM 07/31/08 08:33 AM |
Posts: 6,049 Sebring, Florida. | My concern is not about the small amount of weight you save, but the amount of wind drag you add by going from skinny wires to fatter line, and then add the risk of creep, and the risk of failure if something sharp rubs up against it. You would have to be constantly checking them for wear and nicks, etc. I would think.
I like the lower maintenance of wire because I leave my mast up most of the time. If I were keeping the boat on a trailor with the mast down and all stays coiled neatly in the box, maybe I wouldn't worry about using line instead of wire. Of course I could stop drinking beer and I would lose more weight than by switching to line too. <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" />
Blade F16 #777
[Re: Rolf_Nilsen]
#149500 07/31/08 08:49 AM 07/31/08 08:49 AM |
Posts: 6,049 Sebring, Florida. | Well, it's a small increase but an increase anyway, and if it's blowing 20, going upwind, I'd rather not have any increase in drag up there. I count 3 stays plus 4 trap lines, so there are 7 fatter lines vs. 7 skinny wires.
Blade F16 #777
[Re: Timbo]
#149501 07/31/08 02:01 PM 07/31/08 02:01 PM |
Posts: 186 Chattanooga, TN | My origanl reason for the line over wire was just easy of storage as we have to travel to all the regattas, but at the expense of creep and worse preformance I can handicap myself there with stupid stuff, so will have one less beer, and keep the wire for now.
Jody
Blade F16 724
16,742
guests, and 824
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online22,490 7 hours ago | | |
