| Re: Can any of these haul a boat /trailer?
[Re: David Ingram]
#149714 07/17/08 10:22 AM 07/17/08 10:22 AM | Anonymous
| Anonymous
Unregistered | I use to pull my Hobie 16 by in early 80's with a Toyota Tercel, with a loaded sailbox . Engine about the size of a sewing machine. Hills were a problem sometimes, but I always got to the regatta.
Doug | | | Re: Can any of these haul a boat /trailer?
[Re: Rolf_Nilsen]
#149717 07/17/08 10:39 AM 07/17/08 10:39 AM |
Posts: 2,718 St Petersburg FL | That would be for automatic transmissions, right? We only ever towed with a manual transmission. You can install a transmission cooler on manual transmissions. Usually automatics are already equipped with an oil cooler that is integrated into the radiator. | | | Re: Can any of these haul a boat /trailer?
[Re: Rolf_Nilsen]
#149719 07/17/08 11:32 AM 07/17/08 11:32 AM |
Posts: 1,187 38.912, -95.37 | We've found it easier to cut in half the recommended service intreval on transmission fluid is easier than installing aftermarket coolers and can give you an earlier indication of problems, or one forming.
Research and find out what gears are actually overdrive (in some newer manuals, 4th as well as 5th gear), less than 1:1, and avoid using them under load (up any grade). Same is true for automatics, be careful of the lockup to overdrive, if you notice the transmission shifting in and out of overdrive excessively, turn off the "O/D" or shift in to 3rd or Drive.
[Re: waterbug_wpb]
#149720 07/17/08 11:34 AM 07/17/08 11:34 AM |
Posts: 164 fort Myers, FL | Jay, sent you a pm!
Arie Hobie 16 111812
[Re: arievd]
#149721 07/17/08 11:50 AM 07/17/08 11:50 AM |
Joined: Nov 2003 Posts: 749 Santa Cruz, CA SurfCityRacing
Posts: 749 Santa Cruz, CA | I have to post this every so often: One boat, two trailers, two boxes, and I think there's a coupla kayak stuck in there. This guy does 1000 mile round trip deliveries for me once to twice a month. Two boats and 5 kayaks is the max so far. 32 MPG +or- he says. | | | Re: Can any of these haul a boat /trailer?
[Re: SurfCityRacing]
#149722 07/17/08 11:53 AM 07/17/08 11:53 AM | Anonymous
| Anonymous
Unregistered | I have to post this every so often: One boat, two trailers, two boxes, and I think there's a coupla kayak stuck in there. This guy does 1000 mile round trip deliveries for me once to twice a month. Two boats and 5 kayaks is the max so far. 32 MPG +or- he says. We use to double stack ALL the time WHEN 200 boat regattas were common. DUH never see those days again <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/mad.gif" alt="" /> | | | Re: Can any of these haul a boat /trailer?
[Re: ]
#149723 07/17/08 01:08 PM 07/17/08 01:08 PM |
Joined: Mar 2008 Posts: 55 Ft Myers Beach, FL walkefmb
Posts: 55 Ft Myers Beach, FL | I've used a 1989 VW Cabriolet to tow my T on a breakdown trailer repeatedly(500+miles 1 way). Trailering is less a function of H.P. and more closely related to braking the load. You don't want to be pushing through a stoplight if you are unprepared or underbraked( by neglect or design).
cedar tornado classic, sunfish, 1972 morgan 27 optidad
[Re: walkefmb]
#149724 07/17/08 01:16 PM 07/17/08 01:16 PM |
Posts: 4,119 Northfield Mn | You don't want to be pushing through a stoplight if you are unprepared or underbraked( by neglect or design). This is the thing that most people forget that scares me when towing anything. It doesn't take many downhill grades, or tight twisty down hill corners to start losing brakes on a little car. It takes caution to do so safely. Brakes and suspension are more of a determining factor in what a vehicle can carry than power. | | | Re: Can any of these haul a boat /trailer?
[Re: ksurfer2]
#149725 07/17/08 01:48 PM 07/17/08 01:48 PM |
Joined: Dec 2001 Posts: 5,590 Naples, FL waterbug_wpb OP
Posts: 5,590 Naples, FL | I have heard that installing a trailer hitch on some small cars will void the warranty. Better check the fine print! Dude, these cars are less than $10,000 NEW. They don't even come with Cruise Control for pete's sake.So I'd figure a 2 year old model would run about $6,000. I'd consider them as "disposable" (good American attitude there), and if I blew the engine after four years, I'd probably just drop another one in pretty cheap. A 1.6L 4banger is not too expensive. And being that small and simplistic, I don't imagine they'd be too tough to work on. I agree that any modification would most certainly void the warranty. But how good are warranties anyway these days? I haven't read the fine print on any lately.
[Re: waterbug_wpb]
#149726 07/17/08 01:57 PM 07/17/08 01:57 PM |
Joined: Jan 2007 Posts: 71 Lake Norman, NC Special_Treat_P182
Posts: 71 Lake Norman, NC | I agree that any modification would most certainly void the warranty. But how good are warranties anyway these days? I haven't read the fine print on any lately. I wouldn't doubt that in the manual for any one of those cars it would say, "maximum towing capacity 1,000 pounds". And then in the warranty details it would say, "towing any trailer voids the vehicle warranty." | | | Re: Can any of these haul a boat /trailer?
[Re: waterbug_wpb]
#149727 07/17/08 02:06 PM 07/17/08 02:06 PM |
Posts: 308 Reno NV | Dude, these cars are less than $10,000 NEW. They don't even come with Cruise Control for pete's sake.So I'd figure a 2 year old model would run about $6,000.
Have you considered the 4 cylinder Ford Ranger? They're pretty cheap, and get pretty decent milage. I didn't intend to tow with mine, but with the price of diesel fuel this year I've been using it exclusively. | | | Re: Can any of these haul a boat /trailer?
[Re: bvining]
#149729 07/17/08 03:16 PM 07/17/08 03:16 PM |
Posts: 5,590 Naples, FL | Dodge seems pretty overpowered (and overpriced) although much better looking than the compacts.
These midget cars get 35-40 mpg highway (not with trailer). And since I won't be hauling a trailer that much, I'm not sure I'd need something as big as the Dodge.
Maybe a Neon or something.
As far as accidents, unless I'm driving an Expedition, I figure I might as well get squashed outright rather than be permanently disabled for the next 40 years.
[Re: waterbug_wpb]
#149730 07/17/08 03:47 PM 07/17/08 03:47 PM |
Posts: 12,310 South Carolina | can you get trailer hitches for those cars? Might be a factor.
I still haven't figured out how to break it to Bonnie that the VW Jetta wagon is getting a hitch...maybe I quietly install it one weekend and act like it's always been there? <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Of course, she'll probably read this next week.
Jake Kohl | | | Re: Can any of these haul a boat /trailer?
[Re: waterbug_wpb]
#149731 07/17/08 04:03 PM 07/17/08 04:03 PM |
Joined: May 2002 Posts: 1,037 Central California ejpoulsen
Posts: 1,037 Central California | Checking to see if any of these cars could effectively haul a cat/trailer. This will be a disassembled cat, so the width of the trailer will be around 7 feet, not the 8'6" like the "normal" cat trailers.
I guestimate the trailer, cat, and equipment will be around 900-1000 lbs. max.
Here's the choices:
Chevy Aveo - 103hp - 107 ft. lbs. torque Kia Rio - 110hp - 107 ft. lbs. torque Toyota Yaris - 106hp - 103 ft. lbs. torque Honda Fit - 109hp - 105 ft. lbs. torque
I own an Honda Fit. DO NOT ATTEMPT to tow anything with it, not even an a-cat, not even an opti.
[Re: Robi]
#149733 07/17/08 04:13 PM 07/17/08 04:13 PM |
Posts: 404 Chattanooga, TN | I tow a double stacked trailer (non aluminum, two blades, one sail box and one truck box) with my Nissan Sentra...standard 5 speed, no AC....and get 20-25 mpg's. (without I get 32-34mpg) NO problems! The trailer hitch was a birthday present to myself. <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Joanna
Blade F16 "Too Sharp to Touch" | | |
2,545
guests, and 502
