| Re: Raised the rear beam
[Re: bvining]
#150044 07/20/08 08:02 AM 07/20/08 08:02 AM |
Posts: 2,921 Michigan | looks great. we did the same on our ht last year but used some aluminum tubing which turned out to be about as lite as murray's custom carbon ones once we drilled out some holes. it does make a worl of difference... especially if you sail heavy at all. I remember I could barely breathe there was so much spray from the rear beam with me on the tramp and a 230 lb dude on the wire with the spin up.
no foot straps?
[Re: ThunderMuffin]
#150046 07/20/08 02:50 PM 07/20/08 02:50 PM |
Joined: Sep 2007 Posts: 531 Lake Murray SC FasterDamnit
Posts: 531 Lake Murray SC | The boat is just a bit wider than before...
So are you sheeting from the leeward cleat? Looks very trick.
And what did you use to bed the tube on the deck?
E-Scow 24' ULDB
[Re: bvining]
#150048 07/20/08 08:27 PM 07/20/08 08:27 PM |
Posts: 976 France | I changed up the travelor setup and its working well. You can cleat and uncleat under pressure, and you can cleat the main out to the end of the travelor and not worry about the main "autogybing" when you dont want it to.
I like your traveller setup. I have a classic old school centered cleat and it's hard to manage from the wire, I feel that your system could be far better. Have you tried to add really thin pigtails to the blocks on the traveler? If you make them the same length as half a rail it would provide instant centering (pull until the block touch the cleat), reduce the amount of needed control line and most importantly remove the need for you to mark the middle with this ugly red tape on your nice looking carbon beam <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
[Re: ThunderMuffin]
#150049 07/21/08 07:45 AM 07/21/08 07:45 AM |
Posts: 1,226 Atlanta | Back in my beanpole days I could fall through that gap in the tramp. Are you planning on addressing that? At some point, yes. | | | Re: Raised the rear beam
[Re: FasterDamnit]
#150050 07/21/08 07:47 AM 07/21/08 07:47 AM |
Posts: 1,226 Atlanta | So are you sheeting from the leeward cleat? Looks very trick. And what did you use to bed the tube on the deck? Yes, sheeting from the leeward cleat while on the wire, a flick of the line and it cleats and uncleats very nicely. I need to find a way to keep it neat and organized. Some sort of bungee system, I havent quite got that far yet. I glued the beams down with epoxy and then added a bead of 5200 around the edges. Mostly just to cover the epoxy that oozed out of the seam. | | | Re: Raised the rear beam
[Re: Rolf_Nilsen]
#150053 07/21/08 07:58 AM 07/21/08 07:58 AM |
Posts: 1,226 Atlanta | I am also wondering how you like the tramp? Seems a bit short at the sides. Is there a kick-up mechanism on those rudders? How does it work? I like the tramp, I widened the boat to 8'6" so the tramp is a little skinny on the sides, it seems fine, I might add a piece at the back to fill that open area. I have a kickup set up that is really just two lines and two clam cleats, one of them is an auto release. The red line holds the rudder up, the amsteel line goes though the casting and into the rudder by the bottom pintle and holds it down. I spliced a cover on the amsteel so it would cleat better and that goes in the auto release clam cleat. It works well and is pretty easy to setup. I had this setup on my first HT and it worked great. I'll take more pictures and post them. | | | Re: Raised the rear beam
[Re: pepin]
#150054 07/21/08 08:07 AM 07/21/08 08:07 AM |
Posts: 1,226 Atlanta | Have you tried to add really thin pigtails to the blocks on the traveler? If you make them the same length as half a rail it would provide instant centering (pull until the block touch the cleat), reduce the amount of needed control line and most importantly remove the need for you to mark the middle with this ugly red tape on your nice looking carbon beam Thats a neat idea. I like the system, but it needs bit more tuning to make it really slick. | | | Re: Raised the rear beam
[Re: Tony_F18]
#150055 07/21/08 08:15 AM 07/21/08 08:15 AM |
Posts: 1,226 Atlanta | What happens when you tack/gybe when you don't have the traveler centered? Do you have to reset it to the new tack? Yes, but I think if you are going up wind and tack, you'll have the travelor centered, so you wont have to touch it. And down wind, you could leave both sides at the same adjustment, so I dont think you'll have to fuss with it on each tack/gybe, but I havent worked with it much yet, so I could be wrong. | | | Re: Raised the rear beam
[Re: davefarmer]
#150057 07/21/08 12:00 PM 07/21/08 12:00 PM |
Posts: 1,226 Atlanta | Both beams were $800 from Forte. www.forterts.com Talk to Tony, he's got the specs. I like the widening very much, the HT felt less twitchy. I was going to go wider, but worried about being able to trailer it legally, so I went with 8'6" I cant remember the traveler cost, but you probably could reuse the current traveler. | | |
2,599
guests, and 227
