| A-class, "hydrofoils not permitted" violated? #150229 07/22/08 11:39 AM 07/22/08 11:39 AM |
Joined: Jul 2001 Posts: 256 North Europe, Sweden, Uppsala Hakan Frojdh OP
Posts: 256 North Europe, Sweden, Uppsala | The "banana boards" continue to show excellent speed in higher wind strength. At the "IDB Warnemünde" Bob Baier, which sails a "Nikita" with banana boards, had the scores 1, 1, 3, 1, 4.
But one thing is interesting, are the "banana boards" are hydrofoils or not? If they are the rule "hydrofoils are not permitted" are violated which means that the should have a DSQ.
The purpose of the "banana boards" are both to work as normal centerboards but also to lift and stabilize the boat a bit, and I would call such a device hydrofoil. It is hard to define how much lift a centerboard must give until you start to call it a hydrofoil but if you sail the "banana board" boat at 20 knots a bet the hulls are lifted!
The "banana boards" that the open 60 trimarans use actually lift the bow of the leeward hull at high speeds and that MUST be called hydrofoils or?
/hakan | | | Re: A-class, "hydrofoils not permitted" violated?
[Re: Hakan Frojdh]
#150230 07/22/08 01:24 PM 07/22/08 01:24 PM |
Posts: 3,528 Looking for a Job, I got credi... | The "banana boards" continue to show excellent speed in higher wind strength. At the "IDB Warnemünde" Bob Baier, which sails a "Nikita" with banana boards, had the scores 1, 1, 3, 1, 4.
/hakan I guess as the boats were measured at the latest event and allowed to sail they are not hydrofoils!!!!!!
F16 - GBR 553 - SOLD I also talk sport here | | | Re: A-class, "hydrofoils not permitted" violated?
[Re: scooby_simon]
#150231 07/22/08 01:36 PM 07/22/08 01:36 PM |
Posts: 12,310 South Carolina | It's going to be interesting to see how that turns out - certainly the rule could use some additional clarification. Again though, one sailor having good results isn't much of a definitive test.
Jake Kohl | | | Re: A-class, "hydrofoils not permitted" violated?
[Re: Hakan Frojdh]
#150233 07/22/08 03:25 PM 07/22/08 03:25 PM |
Posts: 1,307 Asuncion, Paraguay | But one thing is interesting, are the "banana boards" are hydrofoils or not?
It is quite difficult to get rid of hydrofoils in a sail craft, they are needed to keep forces in balance. Any underwater device capable of generating dynamic lift is a hydrofoil. Even the hull generates dynamic lift. Common daggerboards (straight, vertical and with symetrical section) generate a vertical lift component when the boat heels: upwards if the hull has a bow up attitude, downwards with a bow down attitude. Rudders also generate a vertical lift component when the boat heels: downwards with weather helm; upwards with lee helm. What can possibly be banned in a class are "appendages that generate a dynamic lift force component along the axis perpendicular to the plane defined by the waterlines of the two hulls".
Luiz
[Re: Luiz]
#150234 07/22/08 04:07 PM 07/22/08 04:07 PM |
Posts: 1,226 Atlanta | appendages that generate a dynamic lift force component along the axis perpendicular to the plane defined by the waterlines of the two hulls Ok, so if my foils lift the boat in another plane, other than perpendicular, then I'm ok? As you mentioned, all foils generate lift. Its going to be near impossible to regulate good lift vs bad lift. Furthermore, the original intent of the hydrofoil rule was meant to prohibit was lifting both hulls clear of the water at the same time. If thats the intent, and thats what the rule is meant to prohibit then banana boards are legal. Bill | | | Re: A-class, "hydrofoils not permitted" violated?
[Re: bvining]
#150235 07/22/08 04:09 PM 07/22/08 04:09 PM |
Posts: 12,310 South Carolina | appendages that generate a dynamic lift force component along the axis perpendicular to the plane defined by the waterlines of the two hulls Ok, so if my foils lift the boat in another plane, other than perpendicular, then I'm ok? As you mentioned, all foils generate lift. Its going to be near impossible to regulate good lift vs bad lift. Furthermore, the original intent of the hydrofoil rule was meant to prohibit was lifting both hulls clear of the water at the same time. If thats the intent, and thats what the rule is meant to prohibit then banana boards are legal. Bill That's what I remember too - like I said, a little clarification in the rule may be in order.
#150236 07/22/08 09:21 PM 07/22/08 09:21 PM |
Posts: 1,307 Asuncion, Paraguay | appendages that generate a dynamic lift force component along the axis perpendicular to the plane defined by the waterlines of the two hulls Ok, so if my foils lift the boat in another plane, other than perpendicular, then I'm ok? That's what I remember too - like I said, a little clarification in the rule may be in order. Exactly, the current wording actually banned daggerboards, rudders and hulls - and nobody noticed it. The new definition would ban "appendages that generate a dynamic lift force component along the axis perpendicular to the plane defined by the waterlines of the two hulls." This bans everything that generates lift more or less in the same direction the mast points - even when the boat heels. The banana boards generate a lift component in this direction, so they would be banned. Normal daggerboards and rudders are aligned with this "mast" direction, so they don't generate any lift component in the direction "perpendicular to the plane defined by the boat's waterlines", so they are allowed.
Luiz
[Re: bvining]
#150237 07/23/08 02:11 AM 07/23/08 02:11 AM |
Posts: 256 North Europe, Sweden, Uppsala | They've restricted the underwater foils by max beam in the up and down position and restricted them underwater by not getting closer than 1.5m under the static waterline. The class doesnt need more rules.
If you check the rules at ISAF or at the A-cat webpage there are no rule or measuring guideline that bans that the foils get closer than 1.5 meters. You can have them as close as you want! /hakan | | | Re: A-class, "hydrofoils not permitted" violated?
[Re: scooby_simon]
#150238 07/23/08 02:16 AM 07/23/08 02:16 AM |
Posts: 256 North Europe, Sweden, Uppsala | I guess as the boats were measured at the latest event and allowed to sail they are not hydrofoils!!!!!! Someone must file a protest against the boat and as far as I know no one has bothered yet. But now the situation is a bit different and we might see protest from other sailors at the next big regatta. /hakan | | | Re: A-class, "hydrofoils not permitted" violated?
[Re: Luiz]
#150239 07/23/08 02:37 AM 07/23/08 02:37 AM |
Posts: 3,528 Looking for a Job, I got credi... | appendages that generate a dynamic lift force component along the axis perpendicular to the plane defined by the waterlines of the two hulls Ok, so if my foils lift the boat in another plane, other than perpendicular, then I'm ok? That's what I remember too - like I said, a little clarification in the rule may be in order. Exactly, the current wording actually banned daggerboards, rudders and hulls - and nobody noticed it. The new definition would ban "appendages that generate a dynamic lift force component along the axis perpendicular to the plane defined by the waterlines of the two hulls." This bans everything that generates lift more or less in the same direction the mast points - even when the boat heels. The banana boards generate a lift component in this direction, so they would be banned. Normal daggerboards and rudders are aligned with this "mast" direction, so they don't generate any lift component in the direction "perpendicular to the plane defined by the boat's waterlines", so they are allowed. But their Daggerboards are NOT vertical and so they DO generate lift in that direction. Hulls do not have VERTICAL sides and so they also create some lift (very small amount) in that direction also. Very difficult rule to word correctly unless they specifically ban bendy boards.
[Re: Hakan Frojdh]
#150240 07/23/08 02:43 AM 07/23/08 02:43 AM |
Posts: 3,528 Looking for a Job, I got credi... | I guess as the boats were measured at the latest event and allowed to sail they are not hydrofoils!!!!!! Someone must file a protest against the boat and as far as I know no one has bothered yet. But now the situation is a bit different and we might see protest from other sailors at the next big regatta. /hakan But if a boat has passed measurement it's an A class; I'd expect you could protest that a boat no-longer is in the same state as it was when it was measured, but how can you protest that a boat that has a valid measurement cert is not an A class?, could open a massive can of worms if a boat is declared a valid A class (or any other class that "allows" them), and then protested and then declaired NOT at valid A class - this would potentially negate all measurement certificates and all measurement at the event for this class. I would have expected that when the measurer originally measured this boat, if they had convcerns, they would relay it to the class administration and they would have decided if these boats were valid A classes. A decision could be made at a later date to ban them.......
[Re: Hakan Frojdh]
#150242 07/23/08 03:57 AM 07/23/08 03:57 AM |
Posts: 9,582 North-West Europe | "hydrofoils are not permitted"
Maybe it is just me but this rule is never going to work. Afterall "hydrofoil" is nothing more then a "waterborn foil" as rudderboards and daggerboards are too. In effect a ruling this simple pretty much disallows all waterborne foils on the A-cat or is incapable of differentiating between traditional rudderboards/daggerboard and vertically lifting foils or parts thereof. I never understood why this class voting in this rule as I never understood how it could be defended in a real protest for an independent jury (not containing any A-cat officials who thought up this rule) Wouter
[Re: Hakan Frojdh]
#150243 07/23/08 04:20 AM 07/23/08 04:20 AM |
Posts: 9,582 North-West Europe | If you see an A-class sweeping by on the downwind in speeds around 15-20 knots ...
It has been a while since I've been witness to such a situation. ever since the introduction of asymmetric spinnakers on cats we've considered spinnakerless boats on downwind legs as stationary obstructions. But I'll promise to look the next time an A sweeps by on the downwind leg, might take a while I'm afraid as I don't go over that often ! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> Wouter
[Re: bvining]
#150244 07/23/08 04:21 AM 07/23/08 04:21 AM |
Posts: 9,582 North-West Europe | Bill,
Why do hate the A-class so much ?
(The reply that was given the last time omeone made similar comments as you did here)
[Re: Hakan Frojdh]
#150246 07/23/08 04:45 AM 07/23/08 04:45 AM |
Posts: 9,582 North-West Europe | Hakan, Indeed, I don't envie the situation the A-class is in now. I'm sure it'll find a way out but some difficult times are ahead. This is going to be a disaster for the class unless the officials starts acting fast. And so far they have done NOTHING!!!
I'm not sure it will be a disaster, but I think we can expect the officials to be behind the curve on this one. I seem to recall that the same officials that came up with the "weak rule" are now the ones to correct the situation. In my life I haven't seen people cgo back on their initial opinion in a timely manner. Personally, I think the partial lifting foils are an area that is perfect for the A's. It is in line with all developments that they have done in the past, like the carbon mast. As always I believe this to be the strong point of the A's. Especially now when they are no longer the fastest boat on the water or even the fastest singlehander. Two items they used to be in the past. As is commonly known, I truly believe that disaster is around the corner when tehe A's allow themselves to become a tightly regulated (concervatively designed) single sail singlehander. In that attire it will fall behind the other classes that WILL incorporate more and more upgrades like the carbon masts and lightweight construction over coming years. With each upgrade the A's will have less of an advantage and eventually just fall behind. The only way to stay out in front is to develop new stuff and progress the design. That has been the only reason the A's have stayed ahead of the fleet for so long as the 60's A's would have been overshadowed by other classes by the 80's if they hadn't evolved. Personally, I think that fully lifting foils can be effectively banned, but partial foiling is impossible to ban without tightly regulating the daggerboard setup and limiting the boat to only one daggerboard set and a single rudderboard set. That will add alot of (detail) rules to the A-class rule set which is in direct conflict with the A-cat philosophy. So I think the way out it to go back a step remove to weak ruling altogether and introduce a single new rule that disallows full foiling (clear of water surface like the Moths). Then, let the development begin, with the A's having a new lease on life. Wouter
[Re: Hakan Frojdh]
#150248 07/23/08 07:21 AM 07/23/08 07:21 AM |
Posts: 12,310 South Carolina | DOOM! IT'S ALL BOUND TO FAIL AND FULL OF DOOM!
geeesh...get a life.
Jake Kohl | | |
1 registered members (FredL),
343
guests, and 59
