| Used Nacra 5.2 #150405 07/24/08 07:29 PM 07/24/08 07:29 PM |
Posts: 9 Midwest | Greetings all, Long time lurker just joined the boards.
A little about me, grew up in Southern California and cut my teeth crewing on H16s in Long Beach B fleet.
Havent sailed much since then but have off and on, want to get back into seriously now. Would like to race too.
Anyway, currently looking at a used 1980s Nacra 5.2 and have some questions. Its in generally decent shape and has some pluses and minuses:
Has 2 sets of sails one new (plus).
Has a 6x4inch hole repair in one of the hulls (minus). The owner states the repair is over 7 yrs old and doesnt leak.
Tramp needs to be replaced (minus) but not this season necessarily(minus).
The guy wants 1200.00 USD for it and trailer.
Any thoughts? Too much or good deal?
Should I trailer it level or at an angle (somewhat upwards at the front).
Thanks for any suggestions or input- Don
"Bite off more than you can chew, then chew it" Ella Williams
1983 Nacra 5.2
| | | Re: Used Nacra 5.2
[Re: Donald15]
#150406 07/25/08 01:09 AM 07/25/08 01:09 AM |
Posts: 757 japan | hi
i bought a 5.2 last year and have been loving it
this is the best place on the web for info about them, so start searching;o)
compared to the hobie 16 it has a lot more fore/aft stability with much more hull volume fore/aft of the beams
it will pitchpole but you can push it far more than the hobie
it's also slightly bigger all round but with about the same weight. however like the hobie16 you can't guarantee that you'll right it solo with just a righting line
as pretty much a dedicated racer when it came out in 1975 it has many more sail controls than the 16
a) mast rotation control b) jib luff tension c) full sized jib d) diamond wires
but the biggest performance gain would be the big daggers which allow much better upwind angles. don't forget to get them up before running up the beach, or it could be very expensive...
there were quite a few changes over it's 10? year production until it was eventually phased out by the nacra 5.5, which was slightly bigger all round again but LIGHTER
about 1984 it changed to swept spreaders and in about 1985 to foam cored hulls. hull number should tell you what year it is
$1200 seems a good price for a good boat on a trailer
mods to mine so far are rudder hold up cleats, so i can drag it backwards up onto the beach and fixed joints to stop the rudder crossbar rotating around and binding at some angles
over the winter i will reroute the jib block wires under the tramp and cuts slots in the tramp so the wire only comes above the tramp where it needs to be for the blocks
post some pics if you can
| | | Re: Used Nacra 5.2
[Re: DennisMe]
#150409 07/25/08 11:35 AM 07/25/08 11:35 AM |
Posts: 12,310 South Carolina | look for spider cracking of the hulls on the corners just in front of the main beam. This is a potential area for a catastrophic failure.
Jake Kohl | | | Re: Used Nacra 5.2
#150410 07/25/08 12:12 PM 07/25/08 12:12 PM |
Posts: 1,403 | If you're still in So Cal there is a nice one in Ventura - guy is asking $1,000.00 and is anxious to sell it. It's on Craig's List. http://ventura.craigslist.org/boa/761632614.htmlGood Luck
| | | Re: Used Nacra 5.2
[Re: Ventucky Red]
#150411 07/25/08 10:30 PM 07/25/08 10:30 PM |
Posts: 9 Midwest | Thanks for the pointers!
I know pretty much what to look for on a used H16 so Ill take that and the info here with me when I go to pick up the nacra this weekend.
Im in the Midwest right now and planning to go to Texas next summer, so the boat in SoCal is out of the question b ut thanks for the tip!
1983 Nacra 5.2
| | | Re: Used Nacra 5.2
[Re: Donald15]
#150412 07/30/08 01:19 PM 07/30/08 01:19 PM |
Posts: 9 Midwest | Ok I bought this boat.
Its all glass construction and the hulls seem solid. I pressed and knocked just about every sqaure inch. The seller and I stepped the mast and went through the rigging and all seems good. He states he replaced most of it within the past 5-6 yrs and has the older stuff to show for it.
Ill need to reinstall the traps as he removed them for rerigging.
It has 2 sets of sails as mentioned earlier, 1 set a new never been used main and jib made by Skip Elliot. They appear to be the exact same shape but stitched a little heavier.
The tramp will need to be replaced but its in working condition. It has the pole down the middle which I like.
It took 4 hours to drive home with it so the trailer past the test. The only problem was at or above 60mph it developed a cyclic vibration that will last approx 10 seconds then go away for about 6 seconds only to start the cycle over again. I stopped and checked the tie downs and tires/wheels and all seemed good to go. I moved the mast back on the trailer thinking wind might have been an issue but that didnt improve things much. Any suggestions? How fast do you guys tow?
Anyway, Im very happy overall. The wife is nervous as its much more boat than our previous H16! Pics will be in order soon- Don
1983 Nacra 5.2
| | | Re: Used Nacra 5.2
[Re: Donald15]
#150413 07/30/08 01:45 PM 07/30/08 01:45 PM | Anonymous
| Anonymous
Unregistered | Any suggestions? How fast do you guys tow?
Congrats on the purchase.. I personally would probably not drive at or above 60 mph. Those little trailer tires are rotating at 1milion revs per minute at that speed to keep up with your car tires.
| | | Re: Used Nacra 5.2
[Re: Donald15]
#150414 07/30/08 01:52 PM 07/30/08 01:52 PM |
Posts: 12,310 South Carolina | Ok I bought this boat.
Anyway, Im very happy overall. The wife is nervous as its much more boat than our previous H16! Pics will be in order soon- Don Tire balance will cause that. You are getting a harmonic between the two wheels that are out of balance and it's peaking every 10 seconds or so. I've got the same thing with my A-cat trailer that is getting fixed this week (new tires and paying for balancing). You can do a driveway "static" balance on the wheels yourself - it's not that hard to get it really close. You need some sticky-back wheel weights (automotive store like NAPA), chalk, and a jack. Jack up the trailer so the tire and wheel are suspended off the ground. spin the wheel lightly and let it come to a complete stop. Make a mental note of if and how badly it backed up before coming to a stop. Start adding weights to the top side temporarily sticking them in place with masking tape until you get the wheel to go around and stop on it's own in completely random positions. Now peel off the backing and apply the sticky weights where you had them taped.
Jake Kohl | | |
1 registered members (FredL),
2,799
guests, and 283
