| Re: Stuck Tramp
[Re: Ventucky Red]
#150579 07/25/08 01:42 PM 07/25/08 01:42 PM |
Posts: 1,200 Vancouver, BC | I suspect it's build up of brine salts jamming it. I've got no miracles to dissolve it. Hot water?
Also, check carefully along the track for bends etc...could be the issue.
BTW, I'm taking the T boat out on Sunday with a guy from work...will be his first time on a cat. Any chance we'll see you there?
Mike.
| | | Re: Stuck Tramp
[Re: tami]
#150582 07/25/08 03:19 PM 07/25/08 03:19 PM |
Posts: 1,403 | If you have a power sprayer, try to shoot into the track/tramp 'luff rope' and clean it out as best you can. Else take the boat to a car wash and use its sprayer. Thanks Tami - I am off to the car wash in a few, the boat needs a good soaking. I'll let ya know. | | | Re: Stuck Tramp
[Re: Ventucky Red]
#150583 07/25/08 04:14 PM 07/25/08 04:14 PM |
Joined: Oct 2006 Posts: 119 Bernhards Bay, N.Y. popeyez7
Posts: 119 Bernhards Bay, N.Y. | I had a stuck tramp,, then I kicked her out <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
~~Don't fear the ''SPEED''~~ Fear the''ADDICTION'' ~17,18 Hobies, ~Jet boat~Speedster 150 ~2 Kayaks~ ~~~~VIETNAM VET. 69-71~~~~
| | | Re: Stuck Tramp
[Re: Ventucky Red]
#150584 07/25/08 04:53 PM 07/25/08 04:53 PM |
Posts: 1,200 Vancouver, BC | If the power washer fails, take it to a car mechanic with an engine steam cleaner...the heat should help dissolve the salts while not being hot enough to harm the hull or alloy (blow torch will).
| | | Re: Stuck Tramp
[Re: Ventucky Red]
#150586 07/26/08 06:15 AM 07/26/08 06:15 AM |
Joined: Jul 2006 Posts: 1,147 Bay of Islands, NZ warbird
Posts: 1,147 Bay of Islands, NZ | I am having a bit of a problem getting the tramp of my 18-2. On the starboard (non lace side) the tramp does not want slide out of the track. I have doused it with soap and water, sprayed sailcoat down the track; as well as, silicone spray, & WD-40. Also tried pulling back and forth, tapping the aluminum track with rubber mallet but it just doesn't want to move. It doesn't appear to be hanging up on anything either. Any ideas? I just cut mine off neatly and had a new bolt rope sewn on....oh, did I tell you I totally munted the track getting the rope out and replaced it too? Looked so nice I replaced the track on the other side and now it all works fine... : ) Now, what I did not tell you was that I backed the boat up to a post and hooked the track to a big nail I drove in.....I then grabbed the stuck side with big grips and pulled my hardest which was when the nail gave way and I flew through the air before crashing into a rough concrete wall and falling over and down a ramp! : ) oh, so then I nailed it down really hard and got a ratchet "cometome" and pumped the crap out of it which succeeded in tearing the track off the boat. I suppose the bolt rope is still in that track at the dump.. : ) BTW yes I did heat it and freeze it and use soapy water and vinegar and water and other things first. Next time if a bolt rope wont budge I will just take the sharp blade to it and cut it off and replace the track before I rip all that skin off.
1,303
guests, and 36
