| Re: Main halyard latch at the top of the mast
[Re: Pascal]
#150699 07/28/08 06:24 AM 07/28/08 06:24 AM |
Joined: Sep 2007 Posts: 224 Cincinnati, Ohio Tri_X_Troll
Posts: 224 Cincinnati, Ohio | I would think it would be not be the best idea. It would probably cause some mast compression. Think about how much the mast flexes if you really pull down on the main halyard to uncleat it from the hook at the top.
I regularly raise mine while floating. It gets easier with practice. Turn it up into the wind and you almost have to plan in advance what side everything is going to be on. I'm light so I'll walk out on the hull and cleat it.
Ryan - H16
I prefer to go sailing because baseball, football, tennis, and golf only require 1 ball!
[Re: Pascal]
#150701 07/28/08 05:10 PM 07/28/08 05:10 PM |
Posts: 224 Cincinnati, Ohio | It can be done with practice. I usually trailer sail, so in light winds I'll pull up to a dock, point the boat into the wind, tie it to the dock and drop my sails.
Ryan - H16
332
guests, and 46
