| Re: rudder damage
[Re: davefarmer]
#150734 07/28/08 10:39 AM 07/28/08 10:39 AM | Anonymous
| Anonymous
Unregistered | I've been cutting discs out of the tops of cottage cheese containers. 2% or 5%?? just kidding, i purchase soup that comes in plastic storage containers from my local grocery store. the lids are a little thicker than i find in pre-packaged items like you mentioned and work well for me. | | | Re: rudder damage
[Re: Rolf_Nilsen]
#150738 07/28/08 04:37 PM 07/28/08 04:37 PM |
Posts: 713 WA, ID, MT | Yeah, that sounds good Rolf, there's plenty of extra room inside the castings and additional thickness and strength would be welcome. I'm sure this is a major stress point for the rudders, as they attempt to bend sideways under load. I'm also not so pleased with the hollow rudders and water intrusion. My thought is to fill that little hole down low, as well as the 2 I created for the hold down/lift lines, then maybe drill a small hole on the top of the rudder to minimize the amount of water that gets in. Has anyone completely sealed the rudders? I don't leave mine on the boat when stored, they might sit in the sun a few hours between sessions at most.
Dave | | | Re: rudder damage
[Re: bvining]
#150745 07/30/08 11:33 PM 07/30/08 11:33 PM |
Posts: 805 Gainesville, FL 32607 USA | The HT rudders look a lot like the white fiberglass Bimare A-cat rudders: These have composition foam top 1/3, corrugated (wavy- vertical) fiberglass middle 1/3, hollow bottom 1/3. Unfortunately I have seen a number of the insides of these fiberglass rudders, but not the carbon ones that don't break. Bimare Boards do tho.
BTW- I left my 1 year old carbon rudders with water inside in the back of my car- in the hot sun with tape on the little holes. Do NOT DO THIS. The heads swelled. I had to compress them in a vise, drill and put my Hobie 16 Quik-Fit rudder cam pins thru the rudder heads so they would fit between the castings. Bad Juju.
455
guests, and 43
