| Re: Hobie Wave Traveller
[Re: WightWave]
#151360 08/04/08 09:42 AM 08/04/08 09:42 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | I think the big advantage of a traveler on a Wave is for sailing off the wind in a breeze. You can let out the traveler but then sheet in to reduce the twist at the top of the sail, thereby reducing pitchpole tendencies.
It is a short boat to begin with, and the mast is set very far forward, so on reaches and downwind, you don't really want all that twist at the top of the sail.
A traveler would also make jibing less precarious when it is windy. | | | Re: Hobie Wave Traveller
[Re: IndyWave]
#151362 08/04/08 11:01 AM 08/04/08 11:01 AM |
Joined: Nov 2003 Posts: 749 Santa Cruz, CA SurfCityRacing
Posts: 749 Santa Cruz, CA | The kit should be available from any Hobie dealer, but probably not a stocked item.
True, we all can get them. I've installed 3 so far and it really adds a dimension of sail control that the wave is lacking. As Mary said it really helps the sail not collapse on itself off the breeze. | | | Re: Hobie Wave Traveller
[Re: SurfCityRacing]
#151364 08/04/08 11:22 AM 08/04/08 11:22 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | The kit should be available from any Hobie dealer, but probably not a stocked item.
True, we all can get them. I've installed 3 so far and it really adds a dimension of sail control that the wave is lacking. As Mary said it really helps the sail not collapse on itself off the breeze. The sail does not collapse on itself off the breeze -- on the contrary, it becomes very full and powerful, especially up at the top, and makes the boat want to (or actually to) pitchpole because of all that power up high. | | | Re: Hobie Wave Traveller
#151367 08/04/08 01:59 PM 08/04/08 01:59 PM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | You're right Mary. I was thinking Bravo. Got confused, plastic boat, colorful sail, single point mainsheet attachment. Sorry for the misinformation. J <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> Yes, I thought you must have been thinking Bravo. | | | Re: Hobie Wave Traveller
[Re: WightWave]
#151368 08/04/08 03:10 PM 08/04/08 03:10 PM |
Joined: Jul 2006 Posts: 1,147 Bay of Islands, NZ warbird
Posts: 1,147 Bay of Islands, NZ | Dear All,
I have been reading through the posts with particular attention to those discussions about the Hobie Wave. On one they taked about a Wave Traveller being available. I've had a look round and it only seems to be for sail from Backyard Boats (the online site for Hobie). However, there are no pictures of what it looks like. Does anyone have a picture of it?
Also, what are the advantages of having a traveller fitted rather than using the standard fixed position. I've got an old Club Wave - not sure how old it is but I'd guess about 1989.
Regards, Tim No traveler on a cat......stupid. Do anything to get one if it is allowed in any racing ect you might do. | | | Re: Hobie Wave Traveller
[Re: Mary]
#151370 08/05/08 10:07 AM 08/05/08 10:07 AM |
Joined: Aug 2007 Posts: 342 Indianapolis, IN - Midwest USA... IndyWave
Posts: 342 Indianapolis, IN - Midwest USA... | The sail does not collapse on itself off the breeze -- on the contrary, it becomes very full and powerful, especially up at the top, and makes the boat want to (or actually to) pitchpole because of all that power up high. Okay Mary, you've made me question my understanding of sailing again. I thought the reason the traveller helped was by keeping power ON the top part of the sail when reaching. It seems to me that when bearing off, as you let the Wave's sail out, the top of the sail twists farther away and spills the wind, thus losing power. I thought the purpose of the traveller was to help keep the sail flat as it is eased, thus keeping air in the upper part and MORE power in the sail. I thought the normal twist was part of the design to naturally de-power the sail as the sheet is eased, thus keeping the resort-rental-customer safer and LESS likely to capsize or pitch-pole.
What - Me Worry?
2006 Hobie Wave 7358 "Ish Kabibble"
737
guests, and 426
