Re: multi-stack trailers [Re: Don_Atchley] #151391
08/05/08 01:07 PM
08/05/08 01:07 PM
Wouldn't that put a lot of stress on the sides of the hulls?
Hard to tell exactly but it looks like the sides are sharing the load with the beams, and the boats may be slightly tilted to the center? Not an idea Hobie 16 sailors are going to take off and run with <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" />
Re: multi-stack trailers [Re: Don_Atchley] #151392
08/05/08 01:19 PM
08/05/08 01:19 PM
srm Offline
srm  Offline
That was my thought too. Seems to me you would want to spread the weight between the lower and upper hulls. And I don't see any structure that keeps the boats from falling over. All I see is that they are all tied together. Of course it's pretty difficult to see details from the picture.
sm
Re: multi-stack trailers [Re: srm] #151393
08/05/08 08:55 PM
08/05/08 08:55 PM
If it is spread out over enough area it wouldn't be any worse than sitting on the bottoms.
Re: multi-stack trailers [Re: Karl_Brogger] #151394
08/06/08 06:38 AM
08/06/08 06:38 AM
You have to be aware of where the bulkheads are but still you have a foam core all along the sides - most cats are solid fibgerglass right along their keel line. You can ding and dent the side unlike you can the bottom.
If they were mostly supported by / at the beams, that would probably be OK.
Re: multi-stack trailers [Re: Jake] #151395
08/06/08 06:55 AM
08/06/08 06:55 AM
And maybe support the side on memory foam.
1 registered members (Damon Linkous), 4,145 guests, and 742 spiders.
