| Re: Hobie Jib
[Re: WightWave]
#151543 08/05/08 08:19 PM 08/05/08 08:19 PM | Anonymous
| Anonymous
Unregistered | Tim, you are asking how to improve the performance of your wave's jib (without any money), but you haven't even used it? ... something is wrong here!
Try it! it will improve the handling/sailing of the boat. If you cant upgrade your hardware (which you dont need to do)... improve your skill set.... it is free.. just sail more, talk with others, sail with others...(who know what their doing). | | | Re: Hobie Jib
[Re: WightWave]
#151545 08/07/08 04:09 PM 08/07/08 04:09 PM | Anonymous
| Anonymous
Unregistered | i dont know anything about the Wave But Matt does. He states that jib is small and not to powerful as to teach people how to use it... sound PERFECT for you... a person who doesnt know how to use a jib and should start with a small, easy to use one.
you have to ask others who know more about the wave platform for more spacifics on your cat. | | | Re: Hobie Jib
[Re: ]
#151546 08/07/08 07:10 PM 08/07/08 07:10 PM |
Joined: Nov 2003 Posts: 749 Santa Cruz, CA SurfCityRacing
Posts: 749 Santa Cruz, CA | Hey Wright, Since you've got it, might as well use it. It will ad a little performance and as Matt said will give the crew something to do. There are basically 3 main parts: the bow spreader, sheet cleats and sail. It's all very easily installed and removable if you don't like it. PM or email me if you need installation instructions. Here it is: http://www.hobiecat.com/support/pdfs/38999001.pdf
| | | Re: Hobie Jib
[Re: WightWave]
#151548 08/08/08 07:34 AM 08/08/08 07:34 AM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | As Matt said, it will help in training. But, it won't make the boat perform better. The reason is that there is no way to get luff tension on the jib. It attaches to the spreader with the halyard running to the mast turning block. If you put much load on the halyard you will bend the spreader bar. As a result the jib will not let you point as high upwind and will only be a help on a close reach to broad reach. I might help in tacking, but the boat normally tacks so fast you don't need it anyway.
By the way, No one is knocking the quality of the Hobie Factory sails. It just happens that this jib kit is not effective in making the boat perform better. Same with the spinnaker.
In Wave racing throughout the country the Hobie sails are winning lots of races against the after-market sails. Rick | | |
574
guests, and 30
