| Re: Interesting Info to Share
[Re: Wouter]
#152660 08/27/08 04:01 PM 08/27/08 04:01 PM |
Posts: 3,528 Looking for a Job, I got credi... |
.... thus you need to (maybe) sheet IN or BARE-OFF (but only if the hull is in the air, or you cannot sheet in any more).
Wouter, your sentence is incomplete <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Interesting Info to Share
[Re: Matt M]
#152661 08/28/08 05:53 AM 08/28/08 05:53 AM |
Joined: Mar 2005 Posts: 322 South Australia Marcus F16
Posts: 322 South Australia | Also be very aware that buy easing the sheet or traveler in conjunction with bearing off in a gust, you open up the sail and present a big flat area of sail dirrectly in front of the wind 8.5 meters up in the air. This is the perfect recipe for stuffing the bows in every big gust.
Matt, There are many theories & none of them necessarily right or wrong & each sailor does need to explore their limits. Maybe experiences are best shared..... Why dont you share what occurance caused your big nosedives in the first two windy races at the Zandvoort GC races where your transoms were pointing at the sky.? <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" />
Marcus Towell
[Re: Marcus F16]
#152662 08/28/08 06:27 AM 08/28/08 06:27 AM |
Joined: May 2006 Posts: 954 Mumbles Y.C Wales U.K Mark P
Posts: 954 Mumbles Y.C Wales U.K | I'll never forget one of John Pierce's quotes; 'The mainsail doesn't know that you're going downwind' Think about it.......it makes a lot of sense considering the amount of apparent wind which can be generated when sailing a F16 sensibly. MP*MULTIHULLS | | | Re: Interesting Info to Share
[Re: Marcus F16]
#152663 08/28/08 07:29 AM 08/28/08 07:29 AM |
Posts: 548 MERRITTISLAND, FL | Also be very aware that buy easing the sheet or traveler in conjunction with bearing off in a gust, you open up the sail and present a big flat area of sail dirrectly in front of the wind 8.5 meters up in the air. This is the perfect recipe for stuffing the bows in every big gust.
Matt, There are many theories & none of them necessarily right or wrong & each sailor does need to explore their limits. Maybe experiences are best shared..... Why dont you share what occurance caused your big nosedives in the first two windy races at the Zandvoort GC races where your transoms were pointing at the sky.? <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" /> Thanks Marcus. <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" /> My multiple swimming experieces at Zandvoort were exactly why I was posting to this thread. I'm light and if I twist off the main in a gust where the apparent wind goes aft, it is not possible for me to save it, generaly making my crew very unhappy. I know there are a lot of techniques for each person and boat set up that will all work, and I did not mean to make it sound different. Just adding my caution from some big wind bad expereinces. M | | | Re: Interesting Info to Share
[Re: Gilo]
#152667 08/28/08 04:55 PM 08/28/08 04:55 PM |
Posts: 183 | In my experience the technique for sailing with the spinaker is different for singlehanded and 2 up.
One thing that remains the same though is that you steer the boat for max VMG then trim the sails accordingly.
In non hull flying conditions this is about 'feel' and the only way to get this is with experience
For hull flying conditions it is a bit easier,
For single handed, sit on the windard hull set the traveller in the middle, then set the main so that the top leeward tell tail is flying most of the time (80% will do)then cleat it and forget it it, a bit of experience will tell you where to put it, but don't fiddle with it just sail the boat with the rudder and spinaker.
Then steer and play the kite to keep the hull up. Keep the steering small as the rudders act like brakes, let the hull fly up and down quite a lot so that you can avoid big rudder movement.
Since the steering is the most important (you cannot loose the tiller) and you must hold the spinaker sheet in your other hand you can do no more.
For double handing it's much easier, position the crew between the lower hull and trapezing, moving them up as the wind increses, 2 extra hands means the helm can play the main as well as steer, just use one armfull of sheet to smooth out the steering, (steering is slow so try to do the minimum) the crew can also smooth out the gusts by moving a small amount in response to gusts and lulls, every so often look up and check that the leeward top tell tails are still streaming, it's better to be under sheeted than over sheeted.
Remember though the speed comes from the steering in all conditions KEEP THE RUDDERS AS STILL AS YOU CAN!! | | | Re: Interesting Info to Share
[Re: john p]
#152668 08/29/08 04:18 AM 08/29/08 04:18 AM | Anonymous
| Anonymous
Unregistered | In my experience the technique for sailing with the spinaker is different for singlehanded and 2 up.
Remember though the speed comes from the steering in all conditions KEEP THE RUDDERS AS STILL AS YOU CAN!! Sounds like my experiences John. I would just add, that the last thing you want to be doing is playing the main sheet when you are on the edge <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" />. If you ease too much main the flow in the head will stay or become attached as you bare away causing the bows to drive down. When you are on the edge you want the head of the main to stall as you bare away so it depowers. This is why cleating the main works. Playing main is only for when you are looking for power. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" /> | | | Re: Interesting Info to Share
[Re: ]
#152669 09/04/08 07:59 AM 09/04/08 07:59 AM |
Posts: 81 singapore | hey guys, much more experimenting over the weekend with sailing the viper downwind with the kite up in a local regatta with about 10 cats on the water, 8 of which were in the F16 configuration. 1 other taipan4.9 and one nacra inter 17 Scott McCook our local cat guru has added a whole lot of updates on downwind sailing and mast rotation for anyone who's interested. The blog can be found here http://boatsbikesboards.wordpress.com | | |
1,303
guests, and 36
