| Re: main sail issues
[Re: WindyHillF20]
#153312 08/25/08 11:58 AM 08/25/08 11:58 AM | Anonymous
| Anonymous
Unregistered | Are you racing with this setup?
I personally wouldn’t make structural changes to my mast to get a telltale to flow correctly when you know the sail isn't correct for mast. | | | Re: main sail issues
[Re: ]
#153313 08/25/08 12:05 PM 08/25/08 12:05 PM |
Joined: Apr 2003 Posts: 440 Graham, NC WindyHillF20 OP
Posts: 440 Graham, NC | Yes, I don't race much but do from time to time. Was at the Outerbanks this weekend racing I-20s and 1 F18. Or should I say following?
[Re: mikekrantz]
#153317 08/25/08 02:04 PM 08/25/08 02:04 PM |
Posts: 5,590 Naples, FL | Mike,
So you basically had the main attached to the mast at the top end (hook) and bottom end (downhaul connection)?
The bolt rope was outside of the mast track, correct?
[Re: mikekrantz]
#153318 08/25/08 02:21 PM 08/25/08 02:21 PM |
Posts: 3,906 Clermont, FL, USA | WOW! That is a lot of tension. How come you didn't go with more spreader rake?
Guess what I'm doing this weekend <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
[Re: mikekrantz]
#153319 08/25/08 02:39 PM 08/25/08 02:39 PM | Anonymous
| Anonymous
Unregistered | We found that we were carrying anywhere from 800 to 1,000 lbs of diamond tension to get some mainsails dialed in. Wholy shnikies' | | | Re: main sail issues
[Re: mikekrantz]
#153322 08/25/08 02:46 PM 08/25/08 02:46 PM |
433
guests, and 22
